All 4 tire low pressure warning - Bimmerfest - BMW Forums
Old 11-30-2010, 12:34 PM
Vanos4:12PM's Avatar
Vanos4:12PM Vanos4:12PM is offline
Mein Auto: 2005 e60 6sp black/black
So the day after thanksgiving it went from 76 degree's on Turkey day to 27 degree's Friday morning. Later that day (Friday) I started it up to go home and received a low tire pressure warning on the display that appeared that all four tires were low. (not sure if it was indicating all 4 tires because this is the first time I have seen this icon appear)
I assumed with the great drop in temp in such a short period of time caused this. Has anyone else experienced this? Needless to say, I pumped them up to all the correct PSI 32/35 at a gas station and reset the warning. In typical German engineering, I have heard the tire pressure monitoring system is very sensitive and just the slightest decrease in tire pressure will trigger the alert?
2005 530 6 speed/Sport/Prem/Cold black/black
2011 328i Sedan/6sp (lost to an accident and she is now at the big Roundel in the sky. )
1997 328i - gone "my first love"
BMWCCA # 367299
ED May 14, 2010
Old 11-30-2010, 12:42 PM
E92Submarine's Avatar
E92Submarine E92Submarine is offline
Officially Contaminated
Mein Auto: 2009 E92 335i
That's a big temperature drop. Not surprising at all.
Pressure = (nRT/V)
Everything on the right side of the equation stays constant except for T (Temperature). So from 76 to 27 degrees, that's about a 9% drop in absolute temperature and thus about a 9% drop in pressure. I guess it could cause all 4 sensors to go off if you were a little low in the first place.
It's been a few years since I've done any real math, so go easy if I fudged that up.
2009 E92 335i | 6MT | Black Sapphire | Black Dakota | Aluminum Trim | Premium | Sport | Heated Seats | PDC | iDrive | HD Radio | M-Sport Shift Knob |
Old 11-30-2010, 12:44 PM
Emission's Avatar
Emission Emission is offline
Automotive Monomaniac
Mein Auto: Schnelle Autos
Bingo.
- Mike
I am fortunate to have unique press cars delivered weekly, but I own:
'16 BMW X5 xDrive35i M Sport 8AT
'15 Volkswagen Golf TDI 6MT
'86 Porsche 911 Turbo 4MT
Gone, but never forgotten... my E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i.
Read my work as Editor-in-Chief for Autoweb and Autobytel!
Old 11-30-2010, 12:47 PM
energetik9's Avatar
energetik9 energetik9 is offline
energetik9
Mein Auto: 911 Carrera 4S
There is some allowance for change. I thought it was in the 10-15% range, but I have no basis for that. I have experienced something similar, but in one tire. As you mentioned, a big temperature variation and when I got back in the car, the warning went off. I went to the closest gas station and it was only a few pounds low.
My wife's Acura is very temperamental. Hers seems to go off often whenever the temperature changes. Drives her crazy....
Current - 2009 Carrera 4S
Current - 2010 128i convertible (wife's car)
Previous - 2009 M-sport 335i coupe
Previous - X5 3.0i with prem/sport
Previous - 2000 ///M roadster
Someone should invent a sarcasm font...
"In car rock, paper, scissors 911 beats Prius everytime."
Old 11-30-2010, 12:48 PM
LarkHouston's Avatar
LarkHouston LarkHouston is offline
Doing the best I can
Mein Auto: 2013 Porsche Boxster S
There is thread somewhere that goes into great technical detail as to how the sensors work, when they are triggered, etc. If you can find it, all your questions (and even some questions you didn't consider) about the TPMS will be answered.
2015 Audi SQ5
Recent Past:
2009 335i Coupe Dinan S3
2006 BMW Z4
Old 11-30-2010, 02:10 PM
jmh328 jmh328 is offline
Mein Auto: 2011 328i Coupe MT
On the morning of Nov.1st I got the low pressure warning on my Honda (just a few days before I was to pick up my BMW). The Honda does not indicate which tire(s) is low. It was 7 am and dark outside....too dark to check the pressure. Thought that maybe people were messing with the car on Halloween night. I remembered that my tire place opened at 7 am and drove the car there. They checked the pressure and found that all were low. It was the first really cold morning here and he inflated all the tires to spec. Problem solved.
Old 11-30-2010, 02:54 PM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
And don't forget that tires lose pressure slowly on their own anyway. The OP's tires were probably already low when the temperature change kicked in.
Sent from my DROIDX using BimmerApp
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
Old 11-30-2010, 03:03 PM
Tom K.'s Avatar
Tom K. Tom K. is offline
IIRC, the earlier thread on TPMS indicated two things: One, newer models and those with software upgrades will indicate which tire is low as opposed to the generic low pressure icon. And two, the low pressure warning apparently kicks in when approx. 20~25% of the pressure has been lost.
The one time I saw it, the pressure had gone from 35 down to 28 lbs.. Refilling the tire without resetting the system worked fine and the light has stayed off for the past 4,000 miles.
But tires should be checked manually at least monthly - especially as temps are dropping in many areas.
Tom
Old 11-30-2010, 05:27 PM
Inline Sixer's Avatar
Inline Sixer Inline Sixer is offline
smooth like butter
Mein Auto: '13 F10 535i | '14 F15 X5
Yup similar thing happened to my E93 -- but never in the X5 (bigger tire?). I got a low warning for my left front tire only, but my handheld digital gauge read 27 across ALL tires. I never understood why the TPM would pick out one tire.
Sent from my iPhone using BimmerApp
