Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 12-02-2010, 06:09 PM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
How to Change your Tranmission Fluid DIY
Wasn't much to put this together after making the mechatronics document.
Black 2002 BMW E65 / 745i 114K
My DIY's - New alternator, battery, CCVs, idler/tensioner pulleys belts, NGK Iridium spark plugs, , sway bar bushings, Front rear brakes, Valve Block, Head Gasket, Exhaust Gasket, Upper and lower Timing Gaskets, Valve Covers, exhaust valves, Timing Chain slide rails, Fuel Injector o-rings, pulled radiator, Intake Manifold Gaskets, water pump, Coolant Pipe/weep hole, oil pan gasket, vacuum pump, fan shroud, Vanos solenoid o-rings, and timed it with a timing kit.
Old 12-06-2010, 04:24 PM
1972arg 1972arg is offline
Mein Auto: 08 BMW 750I
Great Info and nice details of yours PDF'S. Thanks Wilson
Closed Thread
HTML code is Off
