Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 12-02-2010, 06:12 PM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
DIY Changing out Mechatronics Sealing Sleeve
A leaky sealing sleeve will cause you to loose transmission fluid in your driveway. If the fluid gets low enough your car won't move. This doc takes you through the process of replacing the seal.
Black 2002 BMW E65 / 745i 114K
My DIY's - New alternator, battery, CCVs, idler/tensioner pulleys belts, NGK Iridium spark plugs, , sway bar bushings, Front rear brakes, Valve Block, Head Gasket, Exhaust Gasket, Upper and lower Timing Gaskets, Valve Covers, exhaust valves, Timing Chain slide rails, Fuel Injector o-rings, pulled radiator, Intake Manifold Gaskets, water pump, Coolant Pipe/weep hole, oil pan gasket, vacuum pump, fan shroud, Vanos solenoid o-rings, and timed it with a timing kit.
Old 12-17-2010, 05:56 PM
kensingtongals kensingtongals is offline
Mein Auto: BMW 745i and BMW 528i
Smile
Thanks for posting this on the forum... I have to do this on my bimmer as well!
I love having this to ask questions and get help!
Closed Thread
HTML code is Off
