Old 12-07-2010, 03:19 PM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2008 Z4MR
Z4MR - Battery Dead Help
Guys
What is the secret to getting the battery cover off? I took the 3 nuts off the top, got one of the bottom screws to back out, but the other two just spin. Is there a catch or something that unlocks the battery box?
Help!
Best regards
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 12-07-2010, 07:53 PM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
They're just 50 cent plastic pieces, rip them out. I use a door panel popper. The replacements BMW offers now don't have the phillips head part. They're just center tap expanding rivets; which are made to be destroyed.
DreamingWell.com Web Services
Old 12-07-2010, 09:17 PM
Thank you!!! I used plyers, small metal open end wrench and got them out enough to yank out. There was no way with the so called directions in the manual for that cover to flip over to the left like the diagram seem to indicate. I was concerned about ripping the cover, but I snatched hard enough to have a clean break on each of the plastic screws and no harm done.
I got the battery on the tender, hopefully by tomorrow evening it will have rejuvinated it enough to start up.
Best regards.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 12-07-2010, 10:47 PM
Ron Stygar's Avatar
19,585 Miles
Best regards.
Why didn't you do it under the hood?
Old 12-08-2010, 04:53 AM
wildag's Avatar
///M 'n it up!
Best regards.
Yea, sorry I didn't realize that was the goal. There is a positive battery post in the back center of the engine bay. Its under a plastic cover. Put the negative connection on the frame.
Old 12-08-2010, 06:33 AM
I checked on the car this morning and the battery tender did not do it much good. I don't like leaving a charger running unattended so I left the tender alone for the moment and will check on it again when I get home tonight. I looked at the jump start point and went duh too. The jump start point did not have any kind of cover on it, just a round metal piece on top of a black box. I'll put the charger hook up there if we don't see any improvement to night. Talked to my service guy at the dealership and he said if it don't charge up, call the BMW Service number and they will pick the car up free and bring it in. Part of the warrenty.
PS: Those screws needed go any way. I will put something different in there that I can actually get back out at a later point.
Thanks for the help.
Best regards.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 12-08-2010, 08:21 AM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
Lucky for you the replacement battery should be free. They are not cheap. I use a tender on mine for 24hrs once a month to keep it topped up since I don't drive much.
Old 12-08-2010, 08:26 AM
I know, I knew it was getting cold and should have already had it on the tender, it's one of those smart kind that you just leave hooked up and it shuts itself down. I also left my radar detector plugged in. I know, what a dope! And yes, I have had experience with those expensive BMW Batteries on the last car when the mice moved in on it.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 12-08-2010, 06:21 PM
Update, got battery charged up enough to crank the car and took a spin for 30 or so miles. And now she is back on the tender. That should do the trick.
Again, thanks for the help.
Best regards
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 12-10-2010, 10:17 PM
Mike Clark Mike Clark is offline
Mike
Send a message via ICQ to Mike Clark Send a message via AIM to Mike Clark Send a message via Yahoo to Mike Clark
Mein Auto: 2006 BMW M Roadster
Sometimes, I have let mine go 2 or 3 weeks without running, mostly in the summer time, and never had a battery issue. Always started and didn't need a battery tender. Just passed the 4 1/2 year old mark now so probably will need a new battery shortly. The battery died on my Z3MR when it was about 5 years old.
Mike
2006 M Roadster Imola Red
2000 M Roadster Imola Red (gone but not forgotten)
1997 Z3 2.8 Roadster Red (gone but not forgotten)
2008 328i Sedan Gold
Old 12-11-2010, 05:14 AM
Caddyshk Caddyshk is offline
Mein Auto: 2006 Z4MC #LL93158
I'm thinking of adding a new one in the spring at the 5 year mark. No issues - yet; just PM.
2006 Z4 M Coupe
2006 Z4MC - #LL93158
- SuperSprint Race - OE STB - Dave Z Modified CDV - Ground Control Coil Overs - Stoptech lines - Stoptech Pads - RE Clutch Stop - RE Transmission Mounts - LeatherZ M Shift Boot - ZHP Shift Knob
Old 12-11-2010, 08:27 AM
I have never ran in to the this issue either during the summer. Winter is rough on batteries and if you have something like a radar detector, ipod pluged in then the battery will get drained. It was my own fault, I am just glad it did not cost me a new battery.
From here on out the car goes on the battery tender when not in use and that should take care of any future problems.
Best regards
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 12-19-2010, 01:26 AM
da geez's Avatar
da geez da geez is offline
Escape Artist®
Mein Auto: MY 07 M Coupe
My car sits a lot - it's an 07 with only 7,000 miles and I see it every six to twelve months. My kids are supposed to keep it on the tender for me. but it always gets disconnected. I've been through two batteries and BMW has advised me - quite fairly, I believe - they won't give me another new one. If the car is going to sit, the battery should be disconnected. In the rush to the airport on the last day, I always forget this detail. So, I'm coming home at the holidays and wonder, what's the price of a new battery because I know I'll need one.
Telepath wanted: you know where to apply.
2007 Interlagos Blue M Coupe
2004 325i and I'm not sure what color it is except for dark silver.
Old 12-20-2010, 05:10 AM
BMW Batteries are expensive, $300!
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 12-20-2010, 08:28 PM
Drivewfo Drivewfo is offline
Enthusiast
Send a message via AIM to Drivewfo
Mein Auto: 2008 Z4 3.0si Roadster
+1 for Battery Tender Jr
BMWCCA Member
2008 Alpine White Z4 3.0si Roadster 6spd
2006 Silverstone II M5 SMG (gone)
2002 Alpine White 325i Steptronic (gone)
Old 12-20-2010, 08:34 PM
KenTenn KenTenn is offline
KenTenn
Can you get a battery at Auto Zone or some other parts store? I got one for my 3.0L there for <$150. Is the M battery different?
Ken Lewellyn
ZSCCA Area Rep - TN
'06 Z4M Roadster
'03 Z4 3.0L Roadster (Sold)
'00 Z3 2.3L Roadster (Sold)
Old 12-20-2010, 08:45 PM
Yes, Ken. You have to know the secret "M" handsake to get a "M" battery. Just kidding.
No, it's no different than the BMW battery I had in the 3.0. It's just $300 through the dealer. If insurance had not covered it, I would have bought a interstate or battery source premium brand.
Best regards
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 12-21-2010, 10:24 AM
Enthusiast
Do you have to register that battery with the Z cars like I had to with my M5?
BMWCCA Member
Old 12-21-2010, 11:08 AM
KenTenn
Best regards
That explains it - I bought my M used so I didn't get the secret M handshake. I know - I'll look on ebay for one...
Ken Lewellyn
ZSCCA Area Rep - TN
'06 Z4M Roadster
Old 12-21-2010, 06:45 PM
What is the current BMW OE replacement part # for a Z4M battery? I'm going to get some prices.
2006 Z4 M Coupe
Old 12-21-2010, 07:07 PM
krnnerdboy krnnerdboy is offline
Mein Auto: z4M
glad you got it figured out. I noticed that the M's are finicky w/ battery voltage. IE: cars HVAC, dcs, and ABS won't work unless at operating voltage. I also noticed that the CCA rating was higher than my Nissan Titan w/ Tow pack and HD battery/alternator it must be due to our high compression?
I changed mine w/ a 9lb odyssey and shaved nearly 40lbs off the back
