E30 (1982 - 1993)
Old 12-11-2010, 11:47 AM
cmac2012's Avatar
cmac2012 cmac2012 is offline
Renaissance Dude
Mein Auto: Two 1987 325i, 430K, 211K
Master cylinder replace (brakes)
I just put on two front calipers but now I'm thinking my problem goes deeper. While I was bleeding, I felt some funny action in the pedal, a little popping feeling, like it's riding over something, has to be master cylinder I'm thinking. I like this car but I'm nearing 330K, not sure I need a top of the line new master.
Anybody know what re-mans are good and which to avoid? O'Reilly's has a "Cardone" brand, about $120, I'm guessing that's a no.
**EDIT** I'm almost embarrassed to add this part - I'm not even sure if this is ABS or not. It doesn't look like ABS systems I've seen in the past but I think it might be. I've not felt the ABS effect much but now and then I think I do.
Old 12-11-2010, 06:24 PM
ragtopE30 ragtopE30 is offline
Mein Auto: 1988 325i Convertible
If you look in your engine compartment just behind the D/S headlights you should see a squarish metal block with about 6 brake lines attached to it. It usually has a plastic cover that says ABS but regardless, if you have a mass of brake lines going into a contraption between the headlight and strut tower you have ABS.
Old 12-11-2010, 06:32 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
I've never felt the ABS pulse on my '87, however, I've never locked up a wheel...
I Timothy 2:1-2
Old 12-11-2010, 06:46 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
do an e32 upgrade.
http://www.e30m3project.com/e30m3per.../25mc/25mc.htm
that's what i'd do.
df
Old 12-11-2010, 08:41 PM
bimmeupscottiee's Avatar
bimmeupscottiee bimmeupscottiee is offline
Send a message via Yahoo to bimmeupscottiee
Mein Auto: 1987 325is
Or just delete the abs
"I knew a guy who bought a used car through a newspaper. Ten years later...bam...Herpes."
Old 12-11-2010, 09:02 PM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
Originally Posted by drivinfaster View Post
do an e32 upgrade.
that's what i'd do.
df
That's what I did. Gave me a stiffer pedal....
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 12-11-2010, 11:40 PM
cmac2012's Avatar
Renaissance Dude
Hmm, increased stiffness, could use some o' that now and then . . .
(you young whippersnappers just wait)
No but hey, all seriousness aside, that sounds intriguing. Yet one more reason why I should get the new used engine into my old Benz ('81 300SD). I need a daily driver so I can lavish more time on my Beemer which I'm going to run into the ground if I'm not careful. It's a little past the broke in stage now. I'm no longer going 1K between quarts of earl so I may actually have to get the valves done and get new rings in it one day.
Old 12-11-2010, 11:56 PM
cmac2012's Avatar
Renaissance Dude
I wondered about that. Do you have to plug up some lines? I rarely venture into icey realms - ABS is sorta as uselss as the proverbial **** on a boar hog around here.
