Old 12-11-2010, 10:33 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Will the next person who replaces his expansion tank please cut it open & compare?
Will the next person who replaces his expansion tank please cut the old tank open and snap a photograph of the "natural" position of the second chamber?
See this thread for more complete details:
- Behr radiator and Behr expansion (aka surge) tank autopsy (1) (2)
So far, nobody has reported what the lower chamber does and how it operates in the photo below.
You may notice mine has a black 4-inch long slider that was locked in place (i.e., it could not slide in that position) by the black post coming down from the top of the tank.
What perplexes me is that oblong hole "looks" like the black post should have gone in that hole (to allow sliding perhaps?).
Point is, it would be very useful if the next person who replaces their expansion tank opens theirs up and snaps a picture of the position and nature of that hidden chamber so we can better figure out how it works and how it fails.
Thanks,
Bluebee
Old 12-11-2010, 10:41 PM
bluebee's Avatar
Even though my "slider?" was locked in place by the post, I could manually, with some force exerted, move the post so that it fit into the oblong hole, and then (only then), I could move the slider, as shown in the photo below.
So, I'm wondering, if this is yet another failure mode of the expansion tank (that the slider gets locked into position accidentally).
That's why the next person who replaces his Behr expansion tank should be asked to cut it open and show us what his second (hidden) chamber looks like.
Old 12-30-2010, 05:26 PM
bluebee's Avatar
Here is a clarification of the question based on confusion in this thread:
- Anyone seen a defective Behr Reservoir before (2002 530i)
The question is "what is the natural position of the black slider & black stalk".
When I opened my second chamber, the black stalk was "pinning" the black slider in place such that the black slider (an upside-down hollow cup that covers both holes in the bottom of the Behr expansion tank) could not move up.
However, it "appears" that there is a "slot" in the top of the black slider that should allow the black stalk to slide into it thereby allowing the black slider to rise to the top of the expansion tank.
My question is whether or not that black stalk and black slider are supposed to be in the 'locked' position they were when I opened my tank (see annotated photo below) or if the black stalk should go in the slot to allow the black slider to rise further into the top half of the expansion tank.
Old 12-30-2010, 05:45 PM
Meaux Meaux is offline
SnakeBit...
Mein Auto: 01 530i
I was going to offer you mine, but I can't seem to buy a New one that dosen't leak...
I just noticed the one pictured only has one hose connection... Mine has 2...
17 Honda Accord V6
17 Subaru Outback
72 Porsche 911T
01 Ford SVT Lightnin'...
Lazy Bum That Lives Off His Wife...
Old 12-30-2010, 07:00 PM
bluebee's Avatar
My Behr OEM expansion tank pictured has two hose connections on the bottom plus one sensor connection.
The top has the main opening plus a nipple.
Old 12-30-2010, 09:14 PM
SnakeBit...
Mein Auto: 01 530i
In post#3, I see only One hose connection... Jeeze, you folks will argue about anything...
Christ.
17 Honda Accord V6
17 Subaru Outback
72 Porsche 911T
Old 12-31-2010, 10:00 PM
bluebee's Avatar
I'm confused. What are we arguing about?
All I'm asking is for someone to open theirs up and snap a few pictures.
Old 01-05-2011, 08:44 PM
bluebee's Avatar
For the record ...
The "jtwoods5" expansion tank "blew up" yesterday ... so I asked him in this thread to cut it open to snap a picture of the position of the black surge float.
Originally Posted by jtwoods5 ... My expansion tank blew up yesterday
The pike530 expansion tank blew up 12-29-2010 ... so I asked him in this thread to cut it open to snap a picture of the black float position.
Papabear426 is replacing his expansion tank as reported today ... so I asked him in this thread to cut it open and post a picture for us.
Old 01-10-2011, 10:36 PM
bluebee's Avatar
Interestingly, today, cn90 over here pointed me to an old thread over here that explained how the (E46) coolant level sensor worked as shown below ...
In post #29, bidman explains:
"I am afraid Critter7r's 13 years in parts and service at 2 BMW dealers did not serve him well on this one. There is no such thing as a heating element in the coolant level sensor. There is no pocket of air for heating or cooling and no readings are taken, it is a simple magnetic float switch that operates around the outside of the tube in which the sensor sits. This is fitted to ALL the E46 models."
Later, in post #32, valvtronicdude explains further:
"The coolant [level] temp sensor is a magnetic switch. if you remove the sensor no coolant comes out right it's a dry sensor. there is a float inside the jug with a magnet in it. when the coolant level is low enough the float sits down over the glass bulb of the sensor and the magnet of the float causes two contacts to touch each other inside the sensor and cause a complete circuit. The instrument cluster sees this complete circuit and then knows the coolant level is low."
The last post gives the switch a name:
"To provide enough warning time for coolant loss, the sensor needs to be located part way up the tank rather than at the bottom of the tank. By the time the sensor contact gets made at the bottom of the tank, all coolant has drained out.
Also for those interested, the proper term for magnetically activated switch/sensor is call a Reed switch/sensor
Old 02-02-2011, 12:04 PM
bluebee's Avatar
For the record, crs555 just replaced his expansion tank (except he accidentally lost the coolant level sensor) ... so I asked him, in addition to the others listed above (jtwoods5, pike530, papabear426) if he could slice open his old expansion tank (when he finds the missing sensor) to snap a few pictures of the position of the black surge float.
Old 02-15-2011, 10:01 PM
bluebee's Avatar
Here, for the record, is WHERE I suggest the next person cut the expansion tank open.
Note: So far, NOBODY has done the effort to help the team out; but I'm sure someone finally will.
Old 02-16-2011, 03:26 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
I will be overhauling a cooling system on a customers car on Saturday, and I will be able to post up some pics. I might actually have some laying around, if I do I will post up some pics.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 02-16-2011, 05:27 PM
bluebee's Avatar
Great. Especially if you have a few expansion tanks lying around.
The trick is to cut it horizontally about about where I cut it; then you crack it open; and report back as to the position of the BLACK slider and post assembly.
Note: We're talking the all-black side of the tank, not the white slider with the rod on one end and the level sensor on the other.
Thanks, in advance. For the team.
Old 02-20-2011, 07:55 PM
I have the expansion tanks, but my camera isn't working. I will post up some pictures as soon as I get another camera. I have one OEM tank, and one aftermarket Behr tank.
Old 02-20-2011, 10:26 PM
bluebee's Avatar
I'm told the OEM is Behr/Heat while the aftermarket is Behr/Hella.
Looking forward to the photographs!
What's important is the normal position of the black slider and the post that goes through (we think) the hole in the slider.
My black slider wasn't sliding; and the post was wedged on TOP of the black slider (i.e., not in the hole we think it belongs in). So that's why it's important to see a few more expansion tanks.
Nobody knows (yet) what this chamber accomplishes, in detail.
Old 02-24-2011, 06:07 PM
Ok, just got my camera fixed. Here are the pictures. I noticed that the OEM tank had the float pinned down and had a tab holding it in place as seen in the second picture. What caught my eye was that the Behr made in China did not have the float. I am pretty sure that the float is not supposed to move at all. It is wedged between the plastic rod and the bottom, and a tab holds it in place. When I broke off the stalk and undone the tab, the float just fell out. However, on the aftermarket one, the float was missing, but the plastic rod was still there.
OEM Expansion Tank
Here is a picture of the tab that holds the float in place
Here is another angle on the tab
The aftermarket Behr made in China without the float
A close up
The other half of the aftermarket tank
OEM Tank
Oem Tank
Bottom of OEM Tank, the hole which the float was sitting on
Old 02-24-2011, 10:16 PM
bluebee's Avatar
Expansion tank autopsy: Surge chamber & level-sensing chamber detailed
Ooooh. Very nice job!
You're the first person to actually do what they said they would (everyone else just talks - but you took action!). Thanks for doing the second known (to me anyway) Bimmerfest expansion tank autopsy (out of thousands replaced & thrown away).
Your slice down the middle was much neater than mine (what did you use?); and it was in the exact same spot (sparing the thin plastic wall separating the surge chamber from the level-sensing chamber.
Your level-sensing chamber looked almost exactly like mine, with the white float riding on the black stalk. The white float had the same magnetic disc in the center for the electrical level sensor reed switch. And the red bobber glued on one corner of the white float was the same as mine (only my bobber was white).
Interestingly, you too had to break the thin (but razor sharp) plastic bulkhead between the level-sensing chamber and the surge chamber (I cut my hands deeply breaking that plastic!).
Once that thin plastic bulkhead between the two chambers was broken, I was amazed to see that your black float was locked in the SAME POSITION that my black float was locked in.
Apparently this is the natural position of that black float! The black stalk "pins" it down, preventing it, apparently, from moving more than about an inch up from the bottom of the surge tank.
So, I guess I was wrong in assuming that the black float moves up and down that black stalk through that oblong hole in the one corner of the black float.
It's sad, but, even with this new found knowledge, I still can't, for the life of me, figure out HOW that second (surge chamber) chamber actually works.
Can you make sense of what the entire intent of that second surge chamber is and how it actually works?
ID:	267773   Click image for larger version
ID:	267774   Click image for larger version
ID:	267775   Click image for larger version
ID:	267776   Click image for larger version
ID:	267778   Click image for larger version
ID:	267779   Click image for larger version
ID:	267780   Click image for larger version
ID:	267781   Click image for larger version
Old 02-24-2011, 10:25 PM
bluebee's Avatar
Wait a minute!
I just realized that you cut apart TWO tanks! Is that right?
And, that the black float I'm talking about was in the OEM Behr tank's surge chamber.
But, if I understood you correctly, the Chinese tank didn't even HAVE a black float in the surge chamber.
Is that correct?
Old 02-25-2011, 05:07 AM
I replaced the expansion tank on the same car twice since the original cracked up due to age, and the customer brought in the aftermarket for me to put on. I put it on, and it cracked in a month, right across the side. So, I went ahead and put on an OEM tank. My customer noted that his heat became cooler with the aftermarket tank on, but when I put an OEM tank back on, his heat returned to previous temperatures.
The aftermarket tank caught my attention because it failed early, so I just thought I should cut it open just to see if it was the same as the OEM. I just took a hacksaw and carefully cut exactly where you pointed out. The black float seems to restricts the flow to the last chamber in the tank. Look at the last picture I posted, the port that I focused on was the one that it sits over. In the second to last picture, I took a picture where the float would normally sit, seemingly restricting the port.
I thought it was interesting also that the Chinese tank didn't have the float at all. The long plastic rod was there, and the hole for the tab was there, but the float was not.
Old 02-25-2011, 06:31 AM
bluebee's Avatar
I don't know HOW that expansion tank second chamber works, but, I remember somewhere (I think it was cn90) someone mentioned that the hoses at the bottom go to the heater core ... so ... maybe ... just maybe ... the lack of that "surge float" is what caused that problem???
I wish I understood how that second chamber, with the float and the two hoses, actually worked!
This IS strange. Why bother with the long plastic rod that goes half way down from the top, if the float isn't there below it? And why have the "tab" if there's no float?
Does it seem like the Chinese tank quality control "missed" the lack of the black float?
PS: You're GOOD with a hack saw!
Old 02-25-2011, 01:31 PM
I will watch out for more expansion tanks to chop up and analyze. I happen to have a OEM E46 tank, will that help?
Old 02-25-2011, 07:57 PM
bluebee's Avatar
It's always good to see what's different (e.g., that Chinese Behr missing the surge float) so we can figure out what goes wrong with these things!
Old 02-26-2011, 05:28 AM
So far, the only reason I have had to replace an expansion tank is when it cracks down the side, and it starts spitting hot coolant all over the engine bay.
It seems that the plastic gets brittle after so many cooling and heating cycles and pressure it just splits because it cannot handle the pressure anymore. Looking back, I just noticed that the Chinese tank had considerably thinner walls compared to the OEM tank, and that is probably the reason why it failed so soon ( 1 month).
I might get another expansion tank today off of a 1999 528i that has over 300k on it, all one owner.
Old 07-16-2011, 07:48 PM
bluebee's Avatar
Interestingly, today was posted some expansion tank autopsy photos showing extensive damage to the inner thin plastic walls:
- E39 (1997 - 2003) > Coolant Leak - Fixed
ID:	285410   Click image for larger version
ID:	285411   Click image for larger version
Old 07-16-2011, 08:56 PM
Fudman's Avatar
Fudman Fudman is offline
HOLY CR@P! I just ordered all my parts for a cooling system overhaul (I just turned 89K). And I ordered a Behr expansion tank!!! Now it looks like I need to check to see if any of my parts originated in China, even from reputable brands! And then return those that are. Cr@p!!!!!!
