Old 12-14-2010, 05:50 PM
jjsvmax@aol.com jjsvmax@aol.com is offline
Mein Auto: 1998 m roadster
m roadster 1998 shifter feels sloppy
hello , i am new to the bmw owners. i bought a 1998 m roadster, i love the car.but the shifter dosent feel like it has a firm positive movement to it.are there bushings that can be replaced? and how hard is it to change shifters? it has 88 k miles , are there any potential problems that usually show up soon?
Old 12-14-2010, 09:06 PM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
There are a couple of plastic pieces in the shift lever assembly that can be changed. You can also change the rubber transmission mounts.
Here's the Real OEM page for all those pieces:
http://realoem.com/bmw/showparts.do?...13&hg=25&fg=05
If you're going to do all that, I highly recommend Rouge Engineering's Short Shifter Kit, and urethane transmission mounts; I assume they make them for the S52 Z3M.
DreamingWell.com Web Services
Old 12-15-2010, 09:58 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
Replace these two parts and it will not only be like new, it will be NEW.
Gearshift rod joint 1 25111222688 $15.10
Bearing, shifting arm 1 25111222015 $17.40
Bracket f shifting arm bearing
HG 41
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 12-15-2010, 10:01 AM
Mpire's Avatar
The Anti-Rice
Its the same transmission for all 6 cylinder Z3s so its all the same stuff.
The RE mounts and stuff are great, and highly recommended, but they won't take out the slop most people complain about. However, I would just buy everything they sell and install the new rubber parts while you are in there.
Old 12-16-2010, 10:17 PM
Mike Clark Mike Clark is offline
Mike
Send a message via ICQ to Mike Clark Send a message via AIM to Mike Clark Send a message via Yahoo to Mike Clark
Mein Auto: 2006 BMW M Roadster
If you transmission gearshift is not returning to neutral when leaving 5th gear check on this thread. A very common problem. There is a service bulletin on the subject. Requires removal of the transmission to get at the springs and pins. At your mileage, might as well replace the clutch if not done already and check the giubo.
http://www.bimmerfest.com/forums/sho...ission+springs
Mike
2006 M Roadster Imola Red
2000 M Roadster Imola Red (gone but not forgotten)
1997 Z3 2.8 Roadster Red (gone but not forgotten)
2008 328i Sedan Gold
