V1 Install - Bimmerfest - BMW Forums
Old 12-15-2010, 11:18 AM
1HOT BMR's Avatar
1HOT BMR 1HOT BMR is offline
Mein Auto: 2015 X5d/ 2016 X6M
V1 Install
I installed my V1 detector yesterday and I was ready to use Fuse #57, etc. following a similar thread here. In the process I discovered a power outlet under the glove box that works perfectly making the whole installation process much easier. The outlet is completely out of the way and it does not interfere with the passenger's leg room in any way. It is also a switched outlet so the detector goes off (eventually) when the power is turned off
Old 12-15-2010, 11:24 AM
Needsdecaf's Avatar
Needsdecaf Needsdecaf is offline
Everything's Bigger in TX
Mein Auto: 2007 MDX
Now THAT is some smart German engineering.
(and not shown in the manual either. Not at least the online version).
Old 12-15-2010, 12:20 PM
dunccfp dunccfp is offline
Mein Auto: F10
Looks like a phallic symbol......
Old 12-15-2010, 12:37 PM
Gator550 Gator550 is offline
Mein Auto: F10 550i
That's beautiful. Thanks! This will be done the first day I have my car.
Old 12-15-2010, 01:31 PM
jsf1993 jsf1993 is offline
Mein Auto: 2011 535xi
Very cool!
Old 12-15-2010, 03:31 PM
Chpqdk Chpqdk is offline
Mein Auto: BMW 545
It looks like a basic cigarette lighter outlet or did you have to hard wire it in using some additional equipment?
Old 12-15-2010, 03:39 PM
Zathris Zathris is offline
Mein Auto: 2011 550i Sept Build
Great Tip! Thank you!
-Zathris
2011 550i - ED Sept build & Welt pickup: Deep Sea Blue/Cinnamon Brown
ZAV,ZCV,ZCW,ZDA,ZDH,ZP2,ZSP,2TB,2VH,465,4NB,5DF,5D L,610,6NF,6UK
Old 12-15-2010, 04:03 PM
EvolutionTheory's Avatar
EvolutionTheory EvolutionTheory is offline
Mein Auto: 2004 325i
Sweet, can we see a pic of where you have the head unit mounted?
  • Planned: 2012 Space Gray 535i xDrive ///M Sport.
Old 12-15-2010, 04:20 PM
BimmerUKF10 BimmerUKF10 is offline
Mein Auto: BMW F10 535D MSport
My 535d does not have this outlet! Not sure if this is just a symton of UK build spec or a post september thing. My car is a week 45 build.
Old 12-15-2010, 07:28 PM
1HOT BMR's Avatar
It is just a basic cigarette lighter outlet.
It's mounted to the right of the rearview mirror on the passenger side of the windshield. There is an indentation on the headliner that allows you to install the V1 and avoid interference with the sun visor. I'll try to post a picture tomorrow.
My car is a 550i built on week 43.
This install is so much easier than getting the power from the fuse box and trying to find a suitable ground nearby. The cord is completely invisible running it down the passenger side pillar, behind the glove box and around the back of the lower glove box cover. It took me literally 20 minutes to do it
Old 12-15-2010, 09:59 PM
Mine is a week 37 550i US spec. I wish I knew that was there earlier, could have plugged the inverter in while in Europe. Fantastic find.
-Zathris
Sent from my iPod touch using BimmerApp
Old 12-17-2010, 05:25 PM
1HOT BMR's Avatar
Old 12-18-2010, 01:12 PM
650man 650man is offline
Mein Auto: 650i convertible
I plugged my radar detector into the outlet you mentioned on the passenger front side and mine stays on after I shut the engine off and lock the doors ? I was wondering if I missed something as you said that your radar detector automatically shuts off when the car is shut off ?
Old 12-18-2010, 01:48 PM
1HOT BMR's Avatar
Yes. It works like the rest of it so it takes about 3 minutes to shut off if the car is locked with the remote and about 6 minutes if you leave the car unlocked - times are my guess-timates
Old 12-21-2010, 05:54 AM
You are right but in my car it takes more like 15 minutes to shut down the cigarette lighter outlet under the dash, all the same it does work. Thanks for the tip.
Old 12-21-2010, 06:59 AM
Slaymaster's Avatar
Slaymaster Slaymaster is offline
Mein Auto: 2011 528i Sport Package
Great job! I had mine hardwired for $40 and the V1 is located on the left side of the mirror. The V1 shuts off when the engine is turned off. I used the under dash outlet for my cell phone adapter and leave my cell in the right drink holder.
BMWCCA Member #458528 www.bmwcca.org
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
Old 01-08-2011, 07:31 PM
gbates gbates is offline
Mein Auto: 2012 550ix
Tried installing my new V1 today. Followed your lead...power cord down the passenger side pillar. Found a spot where the pillar and dash met and was able to stick the power cord in and this was the end of my installation. How do you get behind the dash to fish the power cord? I took the fuse door out of the glove box and even dropped the lower air bag below the glove box. Help would be greatly appreciated.
Old 01-08-2011, 10:20 PM
1HOT BMR's Avatar
I don't remember exactly what I did but I do remember inserting the power cord at the lower end of the intersection of the dash with the door frame and then pulling it in from underneath. I had the fuse door removed because I was going to use a fuse to get my power but I did not remove any other parts of the glove box or any other area. I'll take another look tomorrow to remember how I did it and I'll try to make time to post a couple of pictures showing you where to pull the wire in.
Old 01-09-2011, 06:21 AM
bmwarchitect bmwarchitect is offline
Mein Auto: 03 BMW X5
Can you disconnect the detector body and store it if you don't want to use it when driving around town? Will there be a hanging cord or can you make it a neat appearance. Thanx.
Old 01-09-2011, 12:50 PM
1HOT BMR's Avatar
Wire routing pictures:
Old 01-09-2011, 12:56 PM
1HOT BMR's Avatar
You can easily disconnet the detector and store it. You can hide all the cord under the lining except the phone plug at the end. If you try to force the plug under the liner you might dislodge the liner from its anchor - not a good thing.
Old 01-09-2011, 01:09 PM
1HOT BMR - thanks!
I had the wire on the other side of the pillar. I also popped off the dash end cover (your last picture) and fed the wire behind the glove box to the power outlet as you did. Thanks once again.
Old 01-09-2011, 01:14 PM
Thanx for the info. I may consider one of these, seem pretty straight forward thanks to your posts. Nice work.
Old 02-13-2011, 08:30 AM
VaTech68 VaTech68 is offline
Mein Auto: 2017 430x Gran Coupe
V1 Install
Just took delivery of our white 535 xDrive yesterday to replace our 2006 525. So far, we love it. This morning I started looking for ways to hardwire my Escort 9500. On our other cars, I have used an Add-a-Fuse insert to piggyback on a circuit at the fuse box.
Thanks to your detailed instructions, this wiring approach looks like the best way to go. Now that you have been using this connection for several months, have there been any problems?
Thanks for sharing your approach.
Old 02-13-2011, 09:49 AM
The only problem that I have encountered, when using the passenger power outlet (under dash), is that the adapter tends to work itself loose over time. This shows up by not having power to the detector. Simply push up on the adapter and power is again restored.
