E30 (1982 - 1993)
Old 12-17-2010, 09:05 PM
e^2 e^2 is offline
Mein Auto: '84 325e, '00 323i
Codes
Is there any way to pull codes from an 84 325e? I think I might have a problem and I want to check. Can't find anything in searches.
Old 12-17-2010, 09:19 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
Nope... you cant stomp test any year prior to 88 i believe (someone will chime in with a better answer im sure)
what are your symptoms?
we can probably help if you list them
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 12-18-2010, 09:47 AM
e^2 e^2 is offline
My on board computer relay box is pulling power from the main relay which powers the fuel pump relay. And that computer relay box is getting a signal from the main computer. Everything is fine until I go to crank. That is when the power is pulled so I'm thinking there is a code and the computer doesn't want the car to start. I bypassed the computer relay box and the car runs and starts just fine but I want to figure it out.
