E36 (1991 - 1999)
Old 12-17-2010, 11:10 PM
victoria-bmw victoria-bmw is offline
Mein Auto: 1998 323i
1993 318 Fuel Pump Relay Location
Can someone tell me where the fuel pump relay is on my 1993 318i
Old 12-17-2010, 11:12 PM
Gooby's Avatar
Gooby Gooby is online now
Kebab Lord / Sexy Sax Man
Mein Auto: 1995 M3
It's where all the other relays are!
psssst...
in the fuse box...
Old 12-17-2010, 11:16 PM
Why waste your time answering. I thought a good answer would be it's the green one located in the fuse box or here is the link to a diagram.
If you don't have the knowledge don't answer jerk
Old 12-17-2010, 11:19 PM
Gooby's Avatar
Mein Auto: 1995 M3
Well if you knew the answer why would you ask in the first place? Did you search like you were supposed to?
And I didn't know the relay was green. All what I knew is it's in the fuse box...
jerkette
Old 12-17-2010, 11:22 PM
Let someone who knows answer and don 't waste my time.
Really people like you degrade the value of this site.
Stay OFF
Old 12-17-2010, 11:23 PM
Gooby's Avatar
Mein Auto: 1995 M3
Old 12-18-2010, 01:13 AM
Killjoy's Avatar
Killjoy Killjoy is offline
OEM Hoe....
Send a message via AIM to Killjoy
Mein Auto: 1999 M3, 2002 tii
Stay OFF
Good to see you are contributing to the value of this site as well.
You asked a question, you got a semi-specific answer. By internet standards, that is damn good. So please, if you can play nice, stay at B'fest.com by all means. If not, then keep it to yourself.
Talk about biting the hand that feeds ya, eh Randy?
Originally Posted by Cmy_bimmer View Post
Oh your talking about THAT hole.. yeah thats an inspection hole
Old 12-18-2010, 10:40 AM
Here is the answer I got from another BMW forum ( one where people take answering questions seriously ) They don't spend time degrading good forums like bimmerfest the way KAPTIN KP does.
FOR ALL YOU INTERESTED FOLKS -- SEE THE GREAT POST AND INFO BELOW:
Pump is on the passenger side, both sides are pickups / sending units. First step would be to check the fuel pump fuse (located under the hood, drivers side). The inside of the fuse box cover will give you the position.
Next step would be to check the fuel pump relay. The relay is right next to the fuse box (towards the inside of the car). It is covered with a separate cover - there are three relays. From the front of the car going back they are the fuel pump relay (orange), DME relay (White), O2 Sensor relay (orange).
If you're not sure of how to jump the relay (eliminate that from the equation) then you should really think about if you want to do this (use your best judgetment): run a wire between pins 30 and 87. If your fuel pump starts running and your car starts up then you have a bad relay. Make sure you run a fuse in your jumper wire as you can cause a direct short if you jump the wrong pins.
Next step would be to test the power to the pump (not sure which wires). If you've got power to the pump and it's not running, you may have a pump problem.
As the previous poster said, a Bently is definatly worth the investment if you're going to work on the car yourself. This procedure is documented in the book.
Old 12-18-2010, 12:28 PM
nothing.
Mein Auto: ItAintUrShtYUCare?
Hello kind maam.......
You seem like a b!tch..... just saying....... maybe its the way you came across?
nothing.
Old 12-18-2010, 12:33 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: 1992 325is
I'd bet my car she didn't post this on bf.c
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 12-18-2010, 01:54 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Why do you think the OP is female? Their screen name is Victoria, but look at their location......
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 12-18-2010, 02:07 PM
Chris S Chris S is offline
Mein Auto: 1997 323i
the skirt, hair and all the girly bits?
Tinting, Phillips Vision Bulbs, NGK standard Spark Plugs, Yokohama S-Drive Tyres
Old 12-18-2010, 04:44 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
post and get an answer
get mad at that answer
then post the answer to your own question
well done
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
