Old 12-18-2010, 10:36 AM
jram jram is offline
Mein Auto: 2001 M Roadster
Post Mechanic says the ABS/DTC is defective
DTC is off . Mechanic says the ABS/DTC is defective however everything is working properly except the M is running without DTC mode on.
QUESTION: Could it be a FUSE that is defective and not the Unit itself since everything is working except the DTC. ABS is fine. IF SO which fuse is it? 2001 M Roadser.
Old 12-18-2010, 01:51 PM
RAD RAD is offline
RAD 330i
Mein Auto: 2001 330i
Dsc
Don't know about the M but went through this with my wife's 2001 3.0 Coupe. From your post I assume DSC light is on and ABS light is off. If so it could be the controller or the steering angle sensor but before you spend lots of money on any of these check and see if there is a low voltage code in the computer. This can cause the steering angle sensor to shut down and turn the DSC off. Resetting the steering angle sensor clears it up.
Old 12-19-2010, 02:59 PM
Rad, thanks for your response. But everything works except the DTC. ABS light is not on, brakes are steering etc. only DTC off light is on(if that makes sense) and DTC is not working, so vehicle is always in off DTC mode.
Old 12-20-2010, 05:49 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2008 Z4MR
Same thing happend on my 04 Z4. Mechanic found a bad sensor on the rear brake. Has that been checked on yours?
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 12-20-2010, 09:45 AM
RAD RAD is offline
RAD 330i
Any of the wheel sensors will trigger both ABS and DTC lights. If its only the DTC and the ABS works OK I would have them look at the steering angle sensor and if it is not reading correctly have them recalibrate it first - that may fix the problem.
Old 12-20-2010, 12:15 PM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: 128i, 330i, Z3 2.3, R56
Am I missing something here? I didn't think any Z3, including the M had DTC. DSC yes, DTC, no.
