Old 12-30-2010, 09:07 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
meantime polished my original xenon headlights if i already there
winter project
no hurry
Old 12-31-2010, 08:19 AM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
What did you use to polish the headlights?
Looks good!
Old 12-31-2010, 09:06 AM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
And if they look that good why did you purchase new ones again?
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 12-31-2010, 09:41 AM
the new kit go to the second car which has halogen and no auto level
to make it work first i need to install it on a car with xenon and auto level to keep auto level in max position and then swap
Looks good!
thanks
3M polishing kit
Old 01-08-2011, 08:50 PM
so its done
pictures are coming
Old 01-08-2011, 09:39 PM
First I marked headlights with correct xenon setup from another E39 so I can readjust my new headlights in the same way
My old Halogen headlights ( feel the difference ! haha )
were not really bad , i just polished them recently
One headlight arm was broken
I got it with new headlights so I replaced both
Fixed !!!
In process
New Xenon HD installed
We will skip coding section here
if somebody interesting
http://forums.bimmerforums.com/forum....php?t=1567928
... it took me some time to retrofit xenon and decode LCM module ...
Decoded and fully functional
No error message on cluster !
Now i need to clean my car and enjoy it
Halogen headlights are for sell !
Old 01-08-2011, 11:20 PM
the light is a bit purple i need to install my new Philips soon
Old 01-08-2011, 11:28 PM
Looks great!
How do you recode?
Are you still going to send me your old D2S bulbs?
Old 01-08-2011, 11:43 PM
told you
winter project
no hurry !
this will be my next project to change bulbs and send old to Jason
haha
coding is here
Old 01-09-2011, 01:22 AM
my Halogen facelift headlights for sell
Old 01-16-2011, 09:38 AM
ebay Item number: 220724306976
SOLD
Old 05-23-2012, 03:33 PM
jcvara jcvara is offline
Mein Auto: 01 525i
Awesome, So i'm about to do the swap on a 2001 525 and I want to know if there is such a thing as a headlight computer for these xenons to be installed correctly? Also, where would I be able to get the software to use my laptop? Any help will be greatly appreciated as I am going into this project head first.
Old 05-23-2012, 03:54 PM
Originally Posted by jcvara View Post
Awesome, So I'm about to do the swap on a 2001 525, and I want to know if there is such a thing as a headlight computer for these xenons to be installed correctly?
What is a "swap on"...?
For OEM Xenon HID's, there is a auto-leveler-servor that connects to the passenger side suspension.
There is also the 35w HID Hella ballasts and OEM D2S bulbs, and brackets to hold the ballasts.
Old 05-23-2012, 06:26 PM
Mein Auto: 01 525i
it's actually, "the swap" from halogen to hid but I know about the ballasts and brackets but there is a small white computer and a longer black computer that I see referred to xenon and hid's that I am wondering about. They are factory Hella hid's but will I need the other computers for them to run properly. What I would like to know is if these "computers" affect any kind of voltage input or wattage output?
These are the ones I'm wondering about...
Old 05-24-2012, 09:01 AM
Solo12 Solo12 is offline
Mein Auto: e39 530i e28 535is(Sold)
I think the white one is the computer/module for the leveling sensors.
The oem xenon setup in the US used level sensors that would adjust the lights up or down based on the load in the car (heavy bags in the trunk or 3 people in the back seat) or and perhaps if you were going up and down hills. Jason mentioned one of the sensors is on the rear suspension. I think there is another sensor up front somewhere, but I could be wrong.
Retrofitting the sensors is going to be a big job and I believe the wiring to connect the sensors to the proper computers is not there on a non oem xenon car. You would have to run the wiring yourself as well as install the correct computers/modules. I am not sure anyone has successfully done all that as it would be a lot of work for something (autoleveling) you do not really have to have.
The main issue as I understand it with recoding the LCM for xenons is so you won't get error msgs. telling you your bulbs are out.
I was under the impression that if you retrofitted hella xenons (with hella ballasts) into a halogen car that you would not get any warning lights as the car would not be able to tell the difference in voltage (how it knows if a light is burned out). That the issue with bulb out warning lights happens when you use some non oem ballasts.
I also posted this following question in your coding thread if you prefer to answer it there rather than mixing in a coding response here.
Champaign you have done a great write up, but would you or someone else list the pros/cons to recoding the car for xenons? Does recoding alter the voltage going to the lights/ballasts? It sounds like if you recode the car for xenons then you may run into the added issue that you have to make sure you also recode and tell the computer/module that there are no leveling sensors otherwise you can get another warning light. I ask because I am going to be doing an OEM Hella xenon conversion on my halogen car soon and you mentioned the xenon would not function correctly without the xenon coding. Would you be able to list out what would be missing or elaborate further?
E39 2003 530i: SP, CWP, PP, Manual, Sunshades, Split folding rear seats, 17" Style 42s
E28 1987 535is: Manual, Bilstein HDs, 16" Style 5v2 (from e38)[Sold]
Old 05-30-2012, 04:59 AM
You will have a warning light if you have high level cluster
Not relevant for the low level cluster
Coding link is mentioned in N60
Old 10-03-2012, 09:37 PM
Quest_908 Quest_908 is offline
Quest_908
Mein Auto: 01 530i and 04 aviator
champaign can u post picks of your old lights so i can see the difference mine look like the ones u posted so i would think i had HID but the low beams are amber like and my high beams are bright white so idk
Old 10-04-2012, 10:01 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
You don't have HID. To be sure, check to see if you have the ballast for the low beam. All facelift E39s have projector low beam, but that doesn't mean they all have Xenon/HID low beam.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
FS E39 Hella Celis Euro taillights WITH ballasts, for pre-facelift update.
FS OEM E53 X5 Tow Hitch http://www.bimmerfest.com/forums/sho...49#post9981849
Old 10-04-2012, 12:00 PM
this car was sold so i cant post you pictures but as TMV told you if you have ballast you have HID
easy to check
no HID
with HID -> see ballast from the right
Old 10-04-2012, 12:48 PM
Quest_908
do these aftermarket HID h7 upgrades with ballasts cause error codes, or can anybody recomend some aftermarket conversion that wont give me the warning lights
Quest_908
forgot....2001 530i
Old 10-04-2012, 12:59 PM
So it sounds like you have Halogen Hella. I used to have DDM Slim Digital Ballast for my H7 HID kit. Those trigger the bulb error on the cluster. I swapped them out with DDM Raptor regular ballast. No more error.
BTW, you need H7 bulb adapters for those H7 HID bulb to fit. They are everywhere (eBay) for about $10~$15
