Old 12-20-2010, 05:26 AM
jnsogburn jnsogburn is offline
Mein Auto: 1986 Z4 Roadster
Exclamation Z4 false flat tire indicator light
Has anyone experienced and found fix to correcting false dashboard indicator lights for the flat tire?
Old 12-20-2010, 07:12 AM
Randy Forbes's Avatar
Investigative Tinkerer
Usually not a big deal, just requiring resetting the system. This assumes that you've already checked the air pressure, with a gauge, for each tire.
In the fall/winter when ambient temperatures drop, it's not uncommon for your a tire's pressure to go lower (moisture in the air inside a tire expands and contracts with the temperature swings).
Not sure if the Z4 system relies on the wheel speed sensors or transmitters inside the tire to monitor the pressure (I have cars that do it both ways) but if it continues to give you trouble, when you know the pressures to be correct, you should have the system checked out by someone in the know.
Welcome to the 'fest. I have to admit, you have one of the oldest (1986 ) Z4s that I've ever heard of!
Randy Forbes
2001///M Rdstr Steel Gray
Old 12-20-2010, 09:31 AM
Psygnosis Psygnosis is offline
Mein Auto: 2004 Z4 3.0i Sport
Early Z4's relied on the traction control system to monitor the tire pressure. 2006ish? they switched to sensors in the wheel. But if you've checked the tires and there fine, the next time you drive off, press the button to reset the flat tire indicator.
Old 12-20-2010, 05:40 PM
shipkiller's Avatar
shipkiller shipkiller is offline
Underway on Nuclear Power
Mein Auto: Me
See paragraph 2.1.5 below:
Tire defect indicator (RPA), DSC MK60
The tire defect indicator RPA is designed to monitor the tire status while driving. For this purpose, the ABS speed sensors determine the speed of the four wheels independent of each other. A calculation logic stage implemented in the DSC control module evaluates the received data and makes the corresponding information available to the driver as required thus informing the driver of a possible tire defect.
1. System structure
The tire defect indicator consists of the following components:
  • 4 ABS speed sensors (already fitted)
  • 1 DSC control module (already fitted)
  • 1 Wiring harness
  • 1 calibration button (RPA button)
  • 1 DME control module (already fitted)
  • 1 Lateral-acceleration sensor (already fitted)
  • 1 Yaw rate sensor (already fitted)
  • 1 Signal lamp
2. Functions
The main function of the system is to monitor the tire pressure while driving. The tire pressure to be monitored is determined by the driver. With the aid of the reset button the driver instructs the system to adopt the current set of wheels with the selected tire pressure as the set reference.
If the speed of a wheel changes as the result of losing air pressure, the control module sends a corresponding signal dependent on the pressure deviation to the driver information system (warning lamp and gong).
2.1 System statuses
The RPA system differentiates between 5 operating statuses:
2.1.1 ”Active” status
After ”switching on” the ignition and after a self-test, the RPA assumes the ”active” status. If the tire pressure corresponds to the pressure set by the driver minus a permissible tolerance, no message is issued to the driver.
2.1.2 ”Warning” status
The signal lamp lights up red and an acoustic signal sounds. The state ”Warning” (pressure drop of approx 30%) indicates that road safety is no longer assured. In the state ”Warning”, it is not possible to run the learning procedure. Pressing the RPA button for 4 seconds resets the RPA to the ”Active” state.
2.1.3 ”Inactive” status
The warning lamp lights yellow. In the ”Inactive” state, all RPA functions are shut down.
2.1.4 ”Fault” status
The warning lamp lights yellow. The ”Fault” state is created by a sensor fault detected by the DSC control module or RPA button actuation of more than 120 seconds. With ”Ignition On” as well as on starting diagnosis, the RPA becomes active again and then again reports a fault in the case of a sensor fault or a time-out of the RPA button signal.
2.1.5. ”Learning” (Standardization) status
The learning status is initiated by pressing the RPA button for 4 seconds. The warning lamp lights up for 12 seconds to confirm the start. The learning procedure must be run every time the tire inflation pressure is corrected or after a tire change. The driver is responsible for ensuring the tire inflation pressure is set correctly. The system cannot carry out a plausibility check. The system is able to detect a reduction in tire pressure of approx 50% of the cold air pressure after a minimum of 10 minutes. As the learning procedure progresses, the pressure difference detected as a tire failure reduces to approx. 30%.
2.1.6 New status
The warning lamp flashes yellow. In the case of new DSC control modules, all RPA functions are disabled. The RPA system is activated by initiating the learning procedure.
3. Diagnosis
The sensors used by the RPA system are already monitored by the ABS and DSC. The RPA will also signal a fault if the ABS and DSC detect a fault.
The following event triggers an additional entry in the fault memory:
  • Pressing the RPA button for longer than 120 seconds.
How does something immoral, when done privately, become moral when it is done collectively?
Furthermore, does legality establish morality?
Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of morel people. - Walter E. Williams
Old 12-20-2010, 06:50 PM
chickdr chickdr is online now
Mein Auto: '06 M Roadster Imola/Blk
I assume you have a 2006 Z4? Your sig says 1986.... Just press the reset light in the center console to reset.
Old 12-20-2010, 07:42 PM
Pants Pants is offline
Road Rager
Mein Auto: '06 Z4 SI
As per previous post.
After you inflate your tires you must depress the corresponding button.
It has a matching symbol, hold it down for a few seconds and the light on the dash will go out.
Old 01-11-2011, 09:38 PM
wideman wideman is offline
Mein Auto: BMW Z4 3.0i
How to reset my cars systems
I have a 05 Z4 3.0i and was driving home in the snow. The conditions were fine when I left from home. But on the way home as the rear wheels would start to slip the traction control would kick in as expected. However just before I got home it really started to slip and the dsc light, brake, abs and tire pressures lights all came on and stayed yellow. Even when the car was home and turned off, I turned it back on and the lights all came on yellow again. Can someone help me on how to reset this.
Thanks,
Werner
Old 01-12-2011, 05:30 PM
k.merkel k.merkel is offline
Now M52TU Powered!
Mein Auto: 1999 Z3 Coupe
Thanks,
Werner
Have you tried driving the car on a clear road? I suspect the DSC saw so much slip it presumed a fault occurred. As long as a component has not actually failed, the lights may go out when the DSC sees everything operating normally.
1999 Z3 Coupe, Arctic Silver/Tannin Red & Maple
Old 01-12-2011, 05:38 PM
shipkiller's Avatar
Mein Auto: Me
Another possible scenario is that you got a lot of snow or ice between the DSC sensor and the timing ring. This would attenuate or keep the sensor from reading the wheel speed.
This same issue happened on my sons car. Once the snow/ice melted away the DSC errors on his car when away.
Just a possibility...
