Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 12-22-2010, 01:43 PM
six_four_five six_four_five is offline
Mein Auto: 645CI
how do you?
Hey guys, Ive done a search which was unsuccessful.
I was wondering how do i pair my home link (the 3 buttons mounted under the rear view mirror) to my garage door/ garage door opener. thanks in advance! i have a lift master system but i cant seem to locate the "learn" button on the actual motor
1. 2004 645ci blk on blk coupe:
- 50% tint all the way around
- 22" Maya MRS 3 piece wheels
- magnaflow full catback system
- k&n filter
- All lighting is aftermarket...no stock bulbs!
- euro overlay
- tinted tails
2. 2006 Acura TL blk on camel - too much to list
Old 12-22-2010, 01:57 PM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
Put the garage remote close to the rear view mirror where the homelink buttons are located. Press the remote and while keeping it depressed, press the homelink button (3 of them so it depends on which one you want to use). Keep both buttons depressed until you see the homelink yellow led start flashing. It will then stop. It has now learned the frequency of your garage remote. Then try it and see if it works.
2008 650 Convertible- 6 Speed manual- Sport package- HUD- Lane Departure- Comfort Access- Merino Leather- HD Radio- SAT
Old 12-22-2010, 03:45 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Of the garage's I have linked to, both required me to press the button on the garage door opener (the motor, etc.) itself after linking the remote. It's a 2 stage code. That might be the issue you are experiencing. The manual explains this in a bit more detail. Good luck!
Old 12-22-2010, 05:23 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Here is a link for Lift Master manuals
Have you made it past step one - to get the HomeLink in the car to learn the Lift Master remote?
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 12-22-2010, 11:53 PM
Mein Auto: 645CI
i cant even seem to get that far
- k&n filter
- euro overlay
- tinted tails
Old 12-23-2010, 12:39 AM
Yorgi's Avatar
This is a summary from page 110 of the owners manual.
1. Turn on the ignition (insert key and press Start/Stop with foot off the brake/clutch)
2. Press and hold 2 outer memory buttons on the mirror until LED flashes to delete all programs
3. Hold your current remote ~2 inches away from memory buttons.
4. Press and hold both the open-door button on remote and one of the 3 memory buttons on the mirror. LED will flash slowly at first, as soon as LED starts flashing rapidly release both buttons. If LED does not start flashing rapidly after 15 seconds, alter distance and repeat.
Now after you get past this you need to read the instructions for your garage door opener for it to pair your Homelink remote.
On my garage openers, there is a "learn" button you press on the motor housing near the 60W light bulbs. You then have 60 seconds to press the memory button you just finished programming in the car. Once you do that the two are paired and you are done.
How many garage doors do you have?
'04 M3 - track
Old 12-23-2010, 05:12 PM
Mein Auto: 645CI
i have 2 doors, but im trying to program it to the main garage door (the bigger one)
- k&n filter
- euro overlay
- tinted tails
Old 12-23-2010, 06:52 PM
Yorgi's Avatar
If you are doing only one door you should be fine. Have you had any luck yet? If not where are you getting stuck?
'04 M3 - track
Old 12-23-2010, 11:32 PM
Mein Auto: 645CI
hey yorgi i cant even seem to get past the first step and i cant even locate my "learn" button. how crucial is a fresh battery in the garage door opener?
- k&n filter
- euro overlay
- tinted tails
Old 12-24-2010, 04:36 AM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is offline
Mein Auto: 2012 650 Coupe
This is spot on. Follow these instructions.
Nick / TopDownInFL (sans the "top down")
2012 650 Coupe - Alpine White / Black Interior / M Package / Premium Sound
Previous Bimmers:
2008 650i Convertible - Monaco Blue / Saddle Brown Pearl Leather / Premium Sound / Sport / Cold / Comfort Access / Lane Departure / HD Radio / Sat Radio
2004 645Ci Convertible - Reverse Sensors / Reverse Camera / Retro iPod
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 12-24-2010, 04:39 AM
The learn button is a good sized square button on the opener engine up at the ceiling. It may be on the side farthest from the garage door and/or inside the lighting compartment. I have a lift master and it is exposed on the side farthest from the garage door. It is a purple button on mine.
Previous Bimmers:
2005 545i Sedan
2001 330Ci Coupe
1995 318i Sedan
Old 12-24-2010, 06:57 AM
tampamark tampamark is online now
Mein Auto: 2006 650 convertible!!!
Can you post your garage opener model number?
I took a look at the online manual on LiftMaster's website. But there are several models, I just picked one at random. If they are consistent then the learn button is on the back side of the unit. Maybe you have to take the white light cover off, on this one it is the upper right from the light fixture.
Old 12-24-2010, 08:09 PM
Mein Auto: 645CI
I have a Lift Master Professional "Formula I" by the way thanks for all the help guys i really appreciate it
- k&n filter
- euro overlay
- tinted tails
Old 12-24-2010, 09:18 PM
The picture above is correct. The Learn button is on the back of the unit, upper right. I can't tell from the manual but you may have to remove the white plastic light cover.
