Idle Control Valve Location - Bimmerfest - BMW Forums
Old 12-28-2010, 05:59 PM
pbstrickland pbstrickland is offline
Mein Auto: 2001 740iA Sport
I have a 2001 740I and can't locate this valve, Do I have one? if so can someone tell me where it is?
Old 12-29-2010, 07:32 AM
balance balance is offline
Mein Auto: 97 740iL
I think the ICV is the big metal cylinder above the throttle body. You could just spray some carb cleaner in there to clean out any loose dirt, but this is usually only a temporary fix if the ICV is bad. Cleaning the ICV is usually only used to diagnose the problem, as in if you clean it and it runs better, change the ICV.
Old 12-30-2010, 07:39 PM
For future questions similar to mine, the 2001 740i does NOT have an ICV.
HTML code is Off
