E30 (1982 - 1993)
Old 03-21-2012, 09:43 PM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
my 88 325e is doing the same thing..
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 03-22-2012, 12:29 PM
downhiller's Avatar
livin large
no, your car is just being a demonic bastard. if it was my car, id just start hitting it until it worked correctly
Old 03-22-2012, 06:52 PM
OliverM3 OliverM3 is offline
Mein Auto: 1988 325is
Originally Posted by downhiller View Post
humidity happens all the time.
the biggest problem is the time it happens. try this, start the car, let it idle for 10 minutes then take it for a spin.
You may be right but if it works where do I look for a humidity problem?
any electrical component could be affected.
Though on that same note why would it run for 5 miles till it reaches operating temperature with no problems if a circuit or connector is wet?
Then clear 5 minutes after.
I did order a new DME just for fun figured I'd chip it anyway and keep a spare.
Old 03-22-2012, 08:15 PM
downhiller's Avatar
livin large
if you think about it, if the air around the engine is cooler during the first 5 minutes of drive, youll still have say moisture in the connections. then when the air within the engine compartment starts to warm up, it evaporates off that moisture. its really the only thing i can think of for being that consistent.
take your car to a witch doctor. get some funky voodoo goin on. maybe thatll kill that damn gremlin
Old 03-24-2012, 09:18 AM
I was intrigued by your idea of moisture. So this morning I broke out the garden hose started the car and hosed down the whole engine and engine compartment until the car reached operating temperature. Wires, Distributor cap injectors, fuse box, relay box, firewall, everything.
By the way the idle didn't change at all during this exercise.
Took it for a spin and there was no hesitation.
I don't know what this proves but I guess the wiring in the engine compartment seems to be ok.
The one odd electrical problem is the temp gauge when I floor it it drops back to the middle. Another thing tied to flooring the car on the same harness so it's possible that it's related. I already had the gauges out to replace the odometer gears so I did tighten the brass nut for the temp gauge.
Here's a video:temp.wmv
Old 03-24-2012, 06:28 PM
downhiller's Avatar
livin large
thats nice. almost like a vacuum gauge. now comes the question, is that due to the power draw or a bad connection in the dash
Old 03-29-2012, 05:20 AM
How about a short of some kind sending extra power to that dumb one wire sensor? Because the car is definitely not running hot but the gauge is resting on the last mark before red till you floor it.
so when you floor it it's exactly center where it should be normally.
Old 03-29-2012, 05:23 AM
Also first day to work with a new DME cross your fingers no hesitation at all but I think the car is just messing with me
Not really a new DME $50 used one on ebay but seems to start and run fine.
I have the old one in the glove box just in case this one decides to leave me stranded.
Old 03-29-2012, 06:11 PM
nope that's not it either I had hesitation on the way home.
I should just bag the e30 and get another M
http://www.eimports4less.com/detail-...d-8286084.html
50k but a lot less headaches
Old 03-29-2012, 06:52 PM
BmwMan92's Avatar
I <3 my E34
for sure.
Oliver have you tried a new tps?
Brandon
Old 03-29-2012, 07:36 PM
for sure.
Yup tps, cps, maf, idle control valve, o2, dme, temp (blue & brown)
Injectors, fuel pump, fuel filter, plugs, cap, rotor, wires, all hoses, injector harness.
All relays
I'm sure I'm forgetting something but I think that there's nothing left to replace.
Old 03-29-2012, 08:25 PM
BmwMan92's Avatar
I <3 my E34
i think so to.. mine just wont respond to throttle at all... no cel urgh.
Brandon
Old 04-01-2012, 08:08 AM
Woxof1 Woxof1 is offline
Mein Auto: 1987325ic
Possible stumble cure
I have been having similar issues and have tried many things. I adjusted the throttle plate per bentley and it fixed the problem. Check that the plate is just slightly open at idle, mine was closed and when tps sensed off idle, the throttle plate had to catch up resulting in stumble .
Old 04-08-2012, 08:18 AM
I could recheck that but I did adjust the throttle plate when I replaced the tps sensor.
my plate was so tight originally that it would stick a little because of the metal on metal contact.
Was your hesitation all of the time?
Old 04-08-2012, 11:02 AM
It stumbled only when engine not up to normal temp, once warmed up, no issues.
Old 04-12-2012, 05:46 PM
Replacing parts for a second time is my only option.
Everything leads me back to a bad fuel pump.
Even though I put in a brand new VDO fuel pump in the car it has to be defective.
These symptoms are the same as a failing fuel pump.
So I just ordered a genuine BMW fuel pump I really hope this fixes it because I'm out of ideas.
Old 04-29-2012, 08:51 PM
BmwMan92's Avatar
I <3 my E34
Any updates? I might be able to end your LONG journey very simply i'm sorry to say but at least your car with all the new parts will last for a very long time.
how is it going over there?
Brandon
Old 04-29-2012, 09:51 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
How bad is it?
Old 04-29-2012, 11:06 PM
BmwMan92's Avatar
I <3 my E34
Originally Posted by Tkaczuk View Post
How bad is it?
Read the thread.
Oliver
You don't need another fuel pump or any of these parts so if they are being repeat bought I'd return them
Brandon
Old 04-30-2012, 05:28 AM
The jury is still out on this one. I had a couple second sputter right after I replaced the fuel pump again but it hasn't happened since. I'm hoping that there was just some air in the line and that monster fuel filter that these things have.
It's down right now because of a battery issue I'm fighting with the store to get a replacement under warranty because it will no longer take a full charge.
That's what I keep thinking at least everything has been replaced so I wont have any problems for a long time once I fix this elusive one.
Did you have another idea?
Old 04-30-2012, 05:33 AM
Read the thread.
Oliver
It's usually just easier to ebay the part.
if the problem continues I'll know that there's nothing wrong with the VDO pump and I'll just ebay it.
I've done that will all of the other parts that I've replaced so far since they were not the problem.
It actually works out better sometimes between the restocking fee and shipping.
Old 04-30-2012, 08:14 AM
BmwMan92's Avatar
I <3 my E34
I have the same hesitation that he had which is worse than your but could be the same fix as you have tried everything else
its the pulley that the crank sensor reads.
If you get it done and still have it, its worth a try to fix the problem once and for all.
How long did you go without hesitation before your battery went bad?
http://forums.bimmerforums.com/forum...1600613&page=2
Brandon
Old 04-30-2012, 08:17 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
Just a thought after reading the posts. Have you done a compression test? I was having the same problems wit a ef honda hatch I had. Turned out on of my valves were bent in the head. It only acted up when it reached a certain tempature. I did a compression test with a cold engine then a warm one.. 150psi almost across the board... to 150- 150- 70-150 maybe not that bad but pretty bad nonethe less. after a head job it ran fine till I blew piston 3 2 weeks later lol.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 04-30-2012, 09:31 AM
I didn't really notice when doing my timing belt if the pulley was damaged but I don't think it was.
I'll take a look. I should have noticed though when it was off and sitting on the workbench.
And I drove around for two days and about 40 miles after the fuel pump but I haven't taken it to work which is the real test. For whatever reason it always acts up when I go to work must not like my job.
Old 04-30-2012, 04:06 PM
downhiller's Avatar
livin large
best excuse ever. sorry boss but, for some odd reason, my car just doesnt like bringing me to work.
