E36 (1991 - 1999)
Old 02-08-2011, 12:21 PM
JohnGutmannnn JohnGutmannnn is offline
Mein Auto: White 1995 325i
I want to pick up a bunch of maintenance parts for cheap so I am looking around pelican parts right now...I just want to confirm everything I am getting is correct. Also wondering what I should replace (smaller parts) since I have zero knowledge of maintenance done before I got the car.
Oil filter kit - Mahle - $7.25 (looks like it comes with O-rings and crush washers for the housing? hence kit?)
http://www.pelicanparts.com/cgi-bin/...20(1992-95)%20
I want to do AutoX and spirited driving without worrying about brakes but am not sure if the OEM Compound is ok to use, i figure OEM rotors are ok to use. I am looking at just autozone for brakes:
Front pads - Duralast - $30.99
http://www.autozone.com/autozone/par...=54439_0_1610_
Rear Pads - Duralast - $33.99
http://www.autozone.com/autozone/par...=54428_0_1610_
Front Sensor - PEX - $10.25
http://www.pelicanparts.com/cgi-bin/...9%2C%20Each%20
Rear Sensor - PEX - $9.50
Front Rotors - Duralast - $31.99
http://www.autozone.com/autozone/par...4_172993_2708_
Rear Rotors - Duralast - $25.99
http://www.autozone.com/autozone/par...7_172993_2708_
The brake job would cost ~$201
The oil changes would cost ~$45 each
Not sure if it is worth it to do the fuel filter, that would be about $26.
I should also clean the MAF while I am in there, any other ideas on what to do?
Old 02-08-2011, 12:28 PM
EROC_328 EROC_328 is offline
Mein Auto: '96 328is
Just FYI, you don't have to replace the wear sensors if they haven't triggered the dash light. If the light is on then you need new sensors.
Upgrading the pads is probably a good idea for doing autoX.
Sport pkg./ADR version II wheels/H&R sport springs/Bilstein shocks/K&N CAI/OEM M3 exhaust/Shortshift
Old 02-08-2011, 12:29 PM
Any recommendation on what pads to use? Also, the indicator on the dash IS on but I think it is only for the rear. I will just order both and see if I can save one of them that is on the car, and keep the new one as a backup.
Old 02-08-2011, 12:44 PM
I went with the pagid red pads from bavauto when I replaced my brakes. I know guys on here like the Aquebono (yea, I butchered that spelling) pads for their really low dust.
Old 02-08-2011, 05:58 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
I've heard great things about the Akebono Euro ceramic pads that FCP Groton sells. No personal experience with them though.
1998 BMW 328is
1966 Pontiac GTO
Old 02-08-2011, 10:15 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
I've got them on my car... Once I get it back and have them broken in (they have maybe 7 miles on them) I'll let you know how they are.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 02-13-2011, 08:58 PM
Anybody know if these would fit my 325i? I PMed him seeing if they are still available.
http://forums.bimmerforums.com/forum....php?t=1583689
Old 02-13-2011, 09:07 PM
nothing.
Mein Auto: ItAintUrShtYUCare?
missing link?
nothing.
Old 02-13-2011, 09:30 PM
Originally Posted by Eight Thirty View Post
missing link?
I added it 2 mins after you responded, I didn't notice it wasn't there >_<
Old 02-14-2011, 05:33 AM
crisscross's Avatar
crisscross crisscross is online now
Just living MY dream
Mein Auto: 1995 M3 Boston Green
The m3 brakes are bigger than the 325i, so they won't fit.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3 2000 TiAg 4.4l X5
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 02-15-2011, 07:24 PM
Got some 3/4" Hex drive lug nuts of ebay so I can finally get my wheels off....
Cost = $22.93
Will cost $20 for a garage with the key to swap the new lugs on.
Total Cost = $42.93
Old 02-16-2011, 07:03 AM
Did you get lug nuts or bolts? Most E36s require bolts not nuts unless someone has done a stud conversion.
I have a set of bolts if you need them because my car has studs on it. I believe they are 5mm longer than the stock bolts. I got them with a set of wheels I bought. Let me know.
Old 02-16-2011, 10:06 AM
Definitely lug nuts, I can tell because the lugs nuts are from advanced auto parts. I don't know what is up with this car, its a bastard.
Old 02-20-2011, 06:56 PM
Figured out the driver side window is the switch in the center console, and got a another switch from a part out of bimmer forums, should have it in the mail soon. The switch was only $8 shipped.
...Oh and the lock cylinder on the driver side magically started working again. I don't know how, but it makes my car look way less ghetto around chicks now, so I am happy!
Old 02-20-2011, 07:32 PM
ZeGerman's Avatar
Warm Leatherette
That's all that matters in life.
1998 BMW 328is
1966 Pontiac GTO
Old 02-27-2011, 05:01 PM
Bought 4 of the same wheels as mine with tires on them today from Eight Thirty (franklyn) for $80, 3 decent tires, but I only need 2.
Might be trading EROC 12x1.5 lugs for wheels bolts!
Also brakes are so worn now they that they smell after driving, 0 pads on the rear and riding steel on steel FTW!!!!
Remaining issues:
-intermittent license plate light failure (have LED lights and resistors, just need to put them in)
-intermittent passenger low beam failure
-low beam bulbs are painted blue so they have a sh!tty light output
-annoying exhaust rattle that can only be heard from outside the car
-rear driver side door doesn't open from the inside handle (might be the child lock?)
Old 03-05-2011, 08:52 PM
Ughh...So bimmerfest apparently doesn't let you edit threads forever...so I gotta do this here:
LIST OF FIXES AND PRICES:
$100 - New key
$9.00 - Mobil 1 ATF to fix squealing PS Pump
$15.00 - Cabin Air Filter
$15.00 - K&N Filter refresh kit
$5.50 - New tail light bulbs
$23.00 - 4 New OBC back light bulbs
$22.93 - 20 Wheel Bolts
$30.00 - Labor to swap wheel bolts
$80.00 - 4 of the same OEM Rims with tires, since I needed a couple tires with tread
Total cost: $300.43
Remaining issues:
-Replace from drivers door door brake
-replace all the brake pads/rotors
Old 03-05-2011, 08:57 PM
crisscross's Avatar
Did you already check the wires running from the body to the trunk? They short out and cause the license plate lights to fail.
-Alan
Old 03-05-2011, 10:39 PM
No, not yet. I have been more worried about getting tires so the car would stay on the road, priorities . I have LED lights to put in back there anyways, so if I put those in and don't work it will give me a reason to check the wiring.
Old 03-06-2011, 07:26 PM
What is this metal pipe with 2 coolant hoses attached? Can I just connect the hoses together and delete this pipe?
I want to make the intake shorter so that the air filter isn't pushing into the headlight.
Old 03-06-2011, 08:44 PM
nothing.
http://forums.bimmerforums.com/forum...70#post2668670
nothing.
Old 03-09-2011, 11:39 AM
Well since I have to do the brakes on this, I figure I might as well replace as much as I can at once.
I want stainless brake lines for obvious reasons, I know of:
TMS Lines:
http://www.turnermotorsport.com/p-38...-approved.aspx - $125 for coated
BimmerWorld Lines:
http://store.bimmerworld.com/bimmerw...its-p1529.aspx - $120
Is there anything out there for a cheap price, or anyone know of anybody selling them used? There used to be a set of bimmerforums for $80 shipped used, but I missed out and they sold them already.
-John
Old 03-09-2011, 11:42 AM
nothing.
stainless is only good for looks isnt it?
nothing.
Old 03-09-2011, 11:50 AM
It stops rubber lines from flexing under pressure, at least that is the general consensus. I am assuming it is true, not sure is there is any independent research that has been done on this. I figure if I am doing all new pads and rotors then I might as well do new fluid since what is in there is probably FILTHY. I figure if I do all that, new lines aren't much to add on top of it. Besides it looks like the resale on them is good if I ever crash or get rid of the car.
Want to sell the brake set in your basement yet?
-John
Old 03-09-2011, 11:53 AM
nothing.
-John
how much for the WHOLE set......?
ill sell them to you for what the cost of a new set is.... because these are new... you just wont have to pay shipping...
nothing.
