Old 12-28-2010, 10:21 PM
humayyuns humayyuns is offline
Mein Auto: bmw 740 i
e38 check break lining messege
can someone tell me plzzzzzzz how to turn off check break lining messege on the e38 comptuer.i push the emergency break and releave it since then that message comeing up
Old 12-29-2010, 05:56 AM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
Linings = brake pads.
Once a sensor triggers, that sensor also needs to be replaced. There are two, one on the front driver's (USA) side and one rear passenger side. Replace the pads that are running low and the appropriate sensor(s).
It's on page 76 of this: Owner's Manual
Link: Sensor
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 12-30-2010, 11:29 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
Once you do replace your brake sensor(s), you'll either need to go thru some drive cycles for the error codes to go away. Or, I think you can turn your key to the last positon (the position before you start your car) & leave it there for 30 seconds & that will reset the error warning (after you've replaced the dead brake sensor).
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
HTML code is Off
