E36 (1991 - 1999)
Old 04-16-2011, 03:41 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
Originally Posted by bluebee View Post
Update?
i haven't had the time to do any sort of informative diy on regrds to emissions...oh, wait, that's not the update that you were loooking for...nwvwemind, i'll just go to the back of the line and wait my turn again...
df
Old 03-03-2012, 04:15 AM
rderow rderow is offline
Mein Auto: m3 convert smg e46 2002
2002 m3 failed smog..help! only 50k miles
Trying to figure out what to do with my 2002 m3 that failed smog. It barely missed NO and HC..
HC
15 mph max 49 - my number 71
25mph max 33 - my number 65
NO
15 mph max 409 my number 772
25 mh max 696 my number 728
It has an afe air filter (which i will replace with stock this weekend). It has an after market pipe and section 2 (stock cats) as well but that shouldnt matter. The guys at the shop ran the codes and it said it needed a new thermostat so that was replaced and still failed. My next step is clean mas sensor, change oil, and change air filter.
What else should I try? I was told valve job but dont have the cash right now
Old 03-03-2012, 07:26 AM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
HC
NO
All the stuff you and the guy at the shop told you to change is pointless. Thermostats, air filters, oil changes, etc. don't affect smog results.
Try looking for exhaust leaks (which cause the cats to run inefficient resulting in high NO). Also is your car misfiring? A misfiring car, which is usually because of old spark plug, can mess up emissions readings...
I'm literally having the same problem you are... =/
Instagram | @randytheus
Old 03-03-2012, 07:33 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Sorry to contradict you Randy, but yes, each of those things can have effect on emissions tests. Also OP, I'd try running a can of seafoam through your car. then next attempt, make certain that your exhaust is nice and hot. Go for a good rip first, then don't let them make you wait until your car cools off. (Keep it idling fairly high if they tell you there's a wait).
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-03-2012, 07:36 AM
Gooby's Avatar
Mein Auto: 1995 M3
Uhmmm how does an oil change affect emissions? =/
Old 03-03-2012, 08:02 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
Originally Posted by drivinfaster View Post
first, 'NO' is 'NOx', the 'x' designates any number of O2 atoms in the molecule.
close. the "x" refers to the number of oxygen atoms (not O2 molecules as stated above).
nerd needs completed.
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 03-03-2012, 08:08 AM
Gooby's Avatar
Mein Auto: 1995 M3
O2 is oxygen though...
You just said the same thing twice...
Old 03-03-2012, 08:14 AM
veteran011's Avatar
Mein Auto: 97 328is
O2 is the oxygen molecule: two oxygen atoms bonded together to form the molecule. so NOx could be NO or NO2.
its nitpicking but that's what i get for taking a lot of chemistry courses.
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 03-03-2012, 08:16 AM
Gooby's Avatar
Mein Auto: 1995 M3
Interesting...
I learned something new today...
Btw: I respect you for taking a lot of Chem classes. I hate Chem. I can't see myself taking it more than once.
Old 03-03-2012, 11:10 AM
Waiting now. Seafoam sounded complicated an risky. Fingers crossed! It has new plugs in it and the co
Outer recall was done. Hasn't had te valves adjusted yet though.
Old 03-03-2012, 12:31 PM
update:
Got all numbers to half nearly of what they were and all to pass accept 25mph HC. I put in clean high end gas Shell and crc smog and ran the heck out of it. Putting ina stock air filter now and going to get the oil change i guess for good luck. Retest at 3.
Old 03-03-2012, 04:33 PM
it does, simply because of residual hc from the oil that stays on the cylinder walls past the rings. the fresher oil is a little thicker and less likely to be burned.
touche!!
(see below...)
again, you are correct.
however, the term i used is a common emissions expression used for working on cars. i mean, how would it look to a customer if i went up to hank (a big, hairy neandertal looking wrench) and asked about his 'O' results??
just sayin...
df
Old 03-03-2012, 05:02 PM
after oil change was worse no idea why! Back to the drawing board. My mechanic said start with a valve adjustment since I dont think the car has had one in quite some time.
Old 03-03-2012, 05:18 PM
hornhospital's Avatar
D'oh, You Kids!
If it's the 2002 you list in your info, it gets a valve adjustment every time you fire it up. The lifters are hydraulic. There is no manual adjustment. I'm not too impressed with your mechanic.
Quotes to live by:
Old 03-03-2012, 05:57 PM
Hmmm
What is the whole deal with shimming then? I might be saying it wrong but thought an adjustment was part of inspection 2. I am open to suggestions as to what to throw money at next. Def high hc.. Any ideas..
Old 03-03-2012, 05:59 PM
granlund granlund is offline
Mein Auto: -02 530 & -92 325is
If it's a 2002 e46 M3 with an S54 engine, it does in fact not have hydraulic lash adjusters and will need periodic valve adjustments.
Old 03-03-2012, 06:01 PM
Side note autozone guy said no adjustment needed as well.. Mechanic worked at BMW... The world is upside down when autzonion outsmarts BMW trained mechanic.. Too funny
Old 03-03-2012, 06:04 PM
Check all six spark plugs for what color they are. The insulator near the tip should be a very light beige/grey dusting. Uneven color between the plugs and yellow glaze and/or medium grey to black is bad.
Old 03-03-2012, 07:10 PM
apparently m3's do have an adjustment procedure that is due @ 60k. if it hasn't been done that i would do that.
as for failing after an oil change, what were the readings??
depending upon the new readings, there may be a few different things to do.
does the test also show co2 and o2?? if so, please list them as well.
df
Old 03-03-2012, 08:09 PM
Gooby's Avatar
Mein Auto: 1995 M3
lol I'm getting schooled in this thread...
I should stop acting smart... lolol
Old 03-03-2012, 08:19 PM
After oil numbers were back to where they were from the first smogging.... I am going to try find a reasonable and experienced mechanic to do the valve adjustment. I replaced the plugs about 8k miles ago and no codes or anything have been thrown but will get them to check when they do the adjustment.
Old 03-03-2012, 08:20 PM
I will share o2 when I can grab the sheet but it has passed every time.
Old 03-03-2012, 08:31 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 03-04-2012, 09:27 AM
it's not a pass of fail gas, neither is co2. they are, however, very good indicators of what else is going on with the combustion.
for instance, if the o2 coming out of the exhaust is too high, that could indicate the cat is not working properly, even though no cade has been thrown.
the lower the co2 the less efficient the engine is running, which could point to other indicators, or, conversely, indicate the engine is operating at peak efficiency and (as a result) able to properly control NOx.
it's stuff you learn in emissions classes. lots and lots of classes.
df
Old 03-04-2012, 09:45 AM
If there is lash on the intake lifters, it could adversely affect the valve overlap and therefore internal EGR, right. This could account for the elevated NOx since EGR is done to lower the combustion temperature.
:3
