E46 M3 (2001-2006)
Old 12-29-2010, 06:17 AM
pcgem1 pcgem1 is offline
Mein Auto: 2004 M3 Convertible
SMG won't shift (solved)
I ran into the problem where my SMG transmission would not shift. I know there are many threads on this topic but what I found was that it took me a few hours of sifting through them to find enough info to do something about my issue other than becoming a 'favorite payer' to the dealer. The many threads I read always left out part of what I needed.
Having said all that, I'm posting everything I learned here in one post....which by the way saved me thousands of dollars so I hope this post will help you too. I'm also including pics of what I'm talking about so you can confidently find the items I discuss on your car.
As the weather got cold, I noticed my SMG transmission wasn't shifting into neutral as easily which prevented the car from starting until after several attempts. Then one day after coming out of work, I couldn't get it to shift at all and had to leave the car in the parking lot overnight. The posts I read where people took their car to the dealer to get this problem fixed said in all cases, the dealer replaced the SMG relay and the hydraulic pump/pressure accumulator (yeah, check out the really scary price here: item #1 http://realoem.com/bmw/showparts.do?...=21&fg=10&hl=1). Seriously, my family would have gone without Christmas this year if I had to pay for this.
My 2004 M3 only has 40K miles on it so I seriously doubted the hydraulics would be having issues. The faint noise you're supposed to hear (sounds like a small electric motor running from under the car) when you unlock the car or open the door is the pressure accumulator building pressure in the hydraulic system so it can operate the SMG transmission, put it into neutral so you can start the car. Sometimes I heard this, sometimes I didn't hear it at all....which is definitely a problem. I found that when relay switches start going bad, they can really be affected by cold temperatures so I decided to start by replacing the relay and to great relief found that was the problem. I picked up the relay at Carquest for $8.20 including tax and it is virtually the same part. Typically I go to great lengths to get authentic parts but in this case, it really was the same. It took me all of 4 minutes to change it in the parking lot too. If you are having SMG issues, I highly recommend changing this out just to see if it's the problem because it's only an $8 risk but could save tons of money....even if you are not good at working on cars, this is really easy and here is what you need to know.
SMG relay, part number: 12631742690
Typically between $7-$9
You can get it at most autoparts stores, online, dealer, etc.
The first attached picture to this post is a pic of the one I installed
Here is a link for closeup pic and purchase info:
http://www.bmwpartsweb.com/BMW-Parts...D-31C9277.aspx
Where this is located in the car: In the engine compartment right in front of the driver in the fuse box/wiring hub. The second attached picture is the location with the cover on.
Using a 1/4" star head screw driver (also known as Hexalobular), remove the 4 screws holding the cover, pull the cover off and you'll see what is shown in the third attached picture. (be careful not to drop the screws...this is easy to do)
The "Salmon" color Red relay is the device of interest. To remove it, you can try wiggling it from side to side while pulling up. Be sure to take note of the small tabs on the side, you may need to gently pry back the plastic pieces holding them to free the relay. I used a small flathead screwdriver to pry up on the relay because my hands were too cold to really get a grip on it. It popped right off, there are no screws holding the relay in place.
Since this was the first time I had seen this relay, I was careful to note the pin layout so I was sure to put the new one in the same way. Usually though, these only fit one way so there is no way to make a mistake when putting the new one in.
Once you've pushed the new one in place and screwed the cover back on, see if the shifting issue went away. I had two alarm lights on my dash still on. The lamp that looks like a gear was yellow and my check engine light was on (or was it service engine??....can't remember). I didn't have time to look up the procedure for resetting these lamps so I figured I would get to it the next day or two. The next day, the gear shaped lamp went out by itself and about 3 days later the check engine lamp went out. I have not had any dash alarms light up since and the car has performed/shifted with no issues what-so-ever.
ID:	260116   Click image for larger version
ID:	260117   Click image for larger version
Old 01-07-2011, 01:09 AM
DarkSide DarkSide is offline
Future BMW *****
Send a message via AIM to DarkSide Send a message via MSN to DarkSide
Mein Auto: 04 TSX
awesome post, thanks for the info
If it bleeds, we can kill it!
Old 02-19-2012, 01:59 PM
wnrobinson wnrobinson is offline
Mein Auto: 2004 M3
PCgem1 It works!!!! Thank you.
Old 03-30-2012, 10:26 AM
Knightmare007 Knightmare007 is offline
Mein Auto: 2005 BMW M3 Convert
Worked for me today, 2005 M3...life saver! TY SIR!
Old 08-11-2012, 09:41 AM
manuelfdo manuelfdo is offline
Mein Auto: M3 AND X5
Worked for me today, after three days waiting on the dealer to give me a better deal on a new SMG pump. I went there open the hood, pop the new relay bought at Pepboys p/n R6284 and its running like champ again! Thank you for the post . 2004 M3 Conv 80K miles on.
Old 08-22-2012, 08:49 AM
silverbimmer3's Avatar
silverbimmer3 silverbimmer3 is offline
Mein Auto: '05 M3 ZCP; '06 530 XIT
Really great info. I will keep an eye this coming winter.
Appreciated.
Old 03-19-2014, 11:49 PM
Buloy07 Buloy07 is offline
Mein Auto: Z4
I got 2004 Z4 SMG and I had the same problem....I changed my RELAY SWITCH with the same part # and I replaced the old one then start the car....won't shift any gear and in neutral gear. I installed the old RELAY and the car is still in neutral and won't shift to any gear.....I need help! Please somebody help me on how to solve this issue...
Old 03-20-2014, 02:23 PM
BMC-M3 BMC-M3 is offline
Mein Auto: E46 M3
I found this thread from a sister site it has a multiple issues regarding SMG. The thread stated back in Oct. of 2008.
Good luck
http://www.m3forum.net/m3forum/showthread.php?t=231113
Old 03-27-2014, 04:56 PM
lweekley lweekley is offline
Mein Auto: M3
Thank you thank you thank you
Thanks so much for this post. Had the same problem that came up at a bad time financially. Issue is going. Thanks again!!
Old 04-16-2014, 09:13 AM
baabish baabish is offline
Mein Auto: 2006 bmw m3 smg cov
Hi, i have a 2006 m3 smg cov will the above part numbers for the replay gonna be same or different. if it is different where can i get the part number so i can go down to any part shop and buy one of these.
Old 04-16-2014, 10:18 AM
Mein Auto: E46 M3
I am not sure but all should be the same. Look at the relay in your car it should have the number on it. I have not check mine yet. My car is 2005 vert.
Old 04-16-2014, 11:45 AM
thank you!
Old 10-21-2014, 05:07 PM
tony745li tony745li is offline
Account Under Review
Mein Auto: 2003 bmw 745li
If anyone is looking for this relay on a E65/E66 its located in the glove box , behinde the fuses. So you would have to remove the fuse box and the glove box . Took me sooo long to find it on the E65 .
Old 11-01-2014, 08:39 PM
tomloans tomloans is offline
Mein Auto: 2001 740i Sport
This is good deal if u r ever forced to change out the smg pump...
http://www.getbmwparts.com/parts/ind...&siteid=214672
Smg pump
Old 11-19-2014, 04:38 PM
AWMrocks AWMrocks is online now
Mein Auto: 2006 M3 Convertible
Thank you! 2006 M3 w/ 55K miles and had exact same issue as OP. This solved the problem and saved me a tow and potential expensive repair from the stealership. Thanks again!!
Old 12-30-2014, 12:55 PM
robot99 robot99 is offline
Mein Auto: 2004 M3
Adding my thanks for the post, I had the same exact problem.
2004 M3 with 98,500 miles. Running fine except on a couple hot days in the summer earlier in the year it had issues shifting. Then on a cold evening wouldn't start at all. Replaced salmon relay and thankfully not a bigger issue!
Old 02-27-2015, 06:21 AM
Hayk Hayk is offline
Mein Auto: Mercedes
Great post! I wonder is many issues with SMG pump replacements could be avoided by simply replacing switch.
Old 04-24-2015, 04:09 PM
hanksm3 hanksm3 is offline
Mein Auto: 2005 M3
Thanks PCGem1 for this fix. At 80K km, I had visions of multi-thousand dollar bill from the dealer. the salmon relay is now $25cdn and I/10 of the price of a flat deck tow to the shop!
Old 08-17-2015, 09:40 AM
JdblA JdblA is offline
Mein Auto: 04 BMW M3
Still having a problem
Hi, thanks for your post. My 04 M3 would not start or shift( stick would not move) so I followed your instructions and replaced the salmon colored relay and also discovered the orange 40amp fuse was no good that sits next to a blue relay in another section. I replaced the salmon relay first and it shifted out of gear then put in a new 40amp and it started. Shortly after that it would not go into gear, I can move the stick but it stays in neutral, will not start and the orange 40 amp is blown again.
Any ideas would be greatly appreciated. Thanks
Old 01-07-2016, 06:14 AM
bmwM3smg bmwM3smg is offline
Mein Auto: BMW m3 SMG 1999
HI Guys,
Hope you can help me with the following:
A couple of weeks my SMG module is losing oil, i have a BMW M3 SMG 1999.
What happens is the following:
1. When i open the door the pump is running
2. After that, i'm checking the oil reservoir and the oil is below the line on the indicator(dipstick)
3. I'm now filling this up until it reaches the line.
4. From that point on, i can drive the car perfectly.
5. What now happens is funny, when i park the car and leave it for a couple of hours, the top of the reservoir is wet from the oil. I believe this comes from the air hole which is on top of the SMG reservoir. (where the dipstick is in)
6. When i now open the door again and i let the pump do its work, the oil indicator(dipstick) in the SMG module show again that the oil is below the indicated line.
7. Also after each parking session there's oil below the car on the ground. I'm not quit sure if this is is related to the leakage from the reservoir or if the oil is leaking from somewhere else.
If you have suggestions let me know.
Thanks for the reply
Old 01-31-2016, 05:16 PM
Shaunsmg Shaunsmg is offline
Mein Auto: 2004 325i
Relay replaced but still problems
My car has done this three times. Exiting freeway, I heard a beep, then it shifted itself into neutral and could not get it out of neutral. I turned off the ignition several times and finally it "rebooted" and I was able to shift normally and use in automatic drive and get home with no indication of any issue. One other time, I shifted into first from a stoplight, got the beep and the transmission indicator dash light. Could not get the car out of first gear. Pulled over, let the car sit for 30 minutes. Restarted and drove with no other issues. Mechanic replaced the relay, ran great for a week, then shifted itself into neutral by itself again, unexpectedly. Anyone else had repeat problems after a really replacement??
Old 02-25-2016, 07:10 AM
mynestry mynestry is offline
Mein Auto:
bmwM3smg
Are you topping up the oil whilst car is running?
Old 02-29-2016, 02:17 AM
Reply to mynestry concerning SMG problems
HI Mynestry,
thanks for the reply to my problem.
I've learned that i need to check the oil, when the pump has done it's work, so the engine is cold but the pump has done his work after opening the door.
After that i fill the oil up to the measured line in the oil reservoir. Driving goes well but when i stop again the oil slowly goes back in the reservoir and spills out on top.
The strange thing now is that when i start the pump again the oil drops below the line again.
If what you say is through the reservoir will only let the oil come out of the reservoir which is to much but it seems that the reservoir spills out more oil then i putt in.
When i think of a logical solution its seems that there is no stop on the oil coming from the pump to the reservoir back again so its keeps pumping oil back.
So, what to do??
Last month i made a decision to convert the SMG1 module in to a manual tranny. I found a garage in Holland which can do this. Reason is that i've put a lot of time, energy and money in the current SMG system (with no real improvements. changing the pump again will set me back around 1500 euro. (which will be the second time, i've done this 2 years ago) the problem is that you won't find new SMG1 modules, all of them are refurbished, and no guaranty what so ever.
The main reason is that i want to enjoy my car without having to worry about a not working SMG module.
Thanks again for the reply, and if you have any questions let me know.
Grt.
Old 03-18-2016, 11:50 AM
kryfo kryfo is offline
Mein Auto: VW
Originally Posted by bmwM3smg View Post
HI Mynestry,
So, what to do??
Grt.
Hi bmwM3smg,
And if i may enquire, how difficult (and expensive?)) is it to convert the SMG to manual tranny?
I am currently looking at purchasing a z4 (2004-2006), I found 3 that matches my price range and needs, but the one that i like most has an SMG tranny. I took it for a spin today and i liked it. My only worry is that if the tranny needs repairing it will cost me a fifth of the car's price...adding to the worry is that it already needed repairing when it was only a few years old, now the car is 12.
thanks,
kryfo
