07 Z4 coupe Trunk panel removal. Please! - Bimmerfest - BMW Forums
Old 12-22-2010, 08:10 AM
AviTech AviTech is offline
Mein Auto: 07 Z4 Coupe 3.0si
Need the bluetooth passkey off the part in the trunk in order to sync my cell phone. Any tips or pics on removeing the rear panel to access the parts behind it would be greatly appreciated. Looked at 231 Z4 DIY articles, #60 link no longer working, #92 pretty vague. Did a search on the Z3 Z4 forums for Z4 looked through 995 posts, no joy. I do not have an "M" just plain old 2007 Z4 3.0si coupe. Post by Ron Styger has good pictures of whats behind the panel on his M but no details on how to remove the panel. Actually the thread was started by kav "Z4M phone integration".
Old 12-22-2010, 09:07 PM
papitosabe's Avatar
papitosabe papitosabe is offline
WalkTheWalk
Mein Auto: 06 Z4 Coupe
code
just tell ur dealership that you spoke to a rep that stated you would be given the code and you never got it... May have to try a few times.
Old 12-23-2010, 03:24 AM
Pants Pants is offline
Road Rager
Mein Auto: '06 Z4 SI
After you're done please post a follow up.
I'd like to know if this will be a worth while endeavor.
Old 12-23-2010, 06:50 AM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
A dealer can pull the code using a computer pretty quickly. Should be free.
Otherwise, just buy a $4 "panel popper" from any auto parts store; looks like a two large flat pronged fork with a screw driver handle and a kink in the stem. Then start pulling the plastic rivets that are all over the trunk carpet. They're 25 cents a piece if you break one.
DreamingWell.com Web Services
Old 12-23-2010, 11:15 AM
barryb97 barryb97 is offline
Mein Auto: 06 M Coupe, 01 X5 4.4i
I just dove in with some trim tools and Ron's instructions. It's a PITA but mostly it is just knowing what direction to pull or pry.
http://www.bimmerfest.com/forums/sho...d.php?t=240959
CDV delete, clutch stop, BMW pedals, Strongstrut bar, SS brake lines, radiator hole cover, brake duct stop removal, Gunmetal M3 reps, roundel under hood, Intravee II ipod adapter, Homelink, air bag sticker delete, first aid storage under seats, Bumper plugs keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings front, TC Kline DA coilovers…
Old 12-23-2010, 03:47 PM
Removing trunk panels
As long as it was apart I took some photos as I put it back together. The photos are in order of assembly from passkey on TCU to the plug in the mat on the floor. Maybe the pics will stay in order on the thread. I was hoping to put comments after each photo but I couldnt figure it out. Only tools i used were a phillips for the 4 screws on the plastic panel at the rear of the trunk, A torx driver for that one screw on the plastic panel under the window, 8mm socket for the 3 nuts on the TCU mount, and a cats paw on the plugs. Took about 2 hours but I wasnt rushing. That last photo of a clip, I believe goes on the tabs along the forword edge of the side panel after you put the tab through the rectangular hole in the back panel, think thats what broke the upper tab on mine when I took it apart. Good luck if you try to put it back on I didnt bother with it.
Name:	# 1 blutooth passkey.jpg
ID:	259473   Click image for larger version
Name:	# 2 TCU.jpg
ID:	259474   Click image for larger version
Name:	# 3 where its at.jpg
ID:	259475   Click image for larger version
ID:	259476   Click image for larger version
ID:	259478   Click image for larger version
ID:	259479   Click image for larger version
ID:	259480   Click image for larger version
ID:	259481   Click image for larger version
ID:	259483   Click image for larger version
Name:	# 12 put plug on panel.jpg
ID:	259484   Click image for larger version
Name:	# 13 like dat.jpg
ID:	259485   Click image for larger version
ID:	259486   Click image for larger version
Name:	# 15 torx.jpg
ID:	259488   Click image for larger version
ID:	259489   Click image for larger version
ID:	259490   Click image for larger version
ID:	259491   Click image for larger version
ID:	259493   Click image for larger version
ID:	259494   Click image for larger version
ID:	259495   Click image for larger version
Name:	# 24 phillips.jpg
ID:	259496   Click image for larger version
ID:	259498   Click image for larger version
ID:	259499   Click image for larger version
Old 01-06-2011, 01:32 AM
santov santov is offline
Mein Auto: 2007 BMW Z4 3.0si Roadste
Whoa!
Thanks for this!
