#51
To digress a bit, Volvo rotor is now made in China (a Chinese now owns Volvo, whatever it means!), and comes in a blue box saying "genuine Volvo part", geezzz!!!
I don't mind buying Chinese food or Chinese fireworks for July 04, but Chinese car parts, they are 2000 years behind the Western world... |
#52
>'97 528i, 175400 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'87 528e, 210000 miles, mice, mouse nests, mouse pee smell, style 31s >'65 & '74 MG Midgets BFC OT Lego Club #48 |
#53
I found that my behr wasnt the same exsact size as the first one i replaced... that was must have been OEm Bmw back in 06
#54
But, I do know the white float handles BOTH the level stick & the electrical sensor. As shown in the pic below, the black slider is on the other side of the expansion tank, behind a thin black plastic bulkhead which forms a separate chamber, from the white float, electrical sensor, and level stick attached to the white float. Details here: - BMW E39 failed radiator & failed expansion tank pictorial autopsy Ideas always welcome for what the black slider actually accomplishes! |
#55
For the record, this quote today sums up one user's feelings rather well:
- E39 (1997 - 2003) > Radiator issue Quote:
#56
i am on my second expansion tank replacement. M62. the first one i bought a Behr. started leaking somewhere near the sensor port. bought a cheap ebay one this time. i do not mind spending $30 every year for a new expansion tank, but i do mind spending $70 a year on one. if there are that many out there that are failing within a year, then i am not going to try elsewhere. i am also running NPG+ is my car. the pressure is never up in the tank. the fluid would drain out after i stopped. it was not coming out while i was driving.
G~ |
#57
By way of cross reference, see this thread from today:
- E39 (1997 - 2003) > cooling system overhaul, not always a good idea Quote:
#58
Apparently today was posted yet another defective Behr China expansion tank:
- E39 (1997 - 2003) > Genuine BMW Expansion Tank Quote:
#59
I bought a Behr expansion tank along with other cooling components about 13 months ago from EAC Tuning and just noticed that I was losing a small amount coolant each week. After inspection I located the leakage at the bottom of the tank near the fitting for the level sensor. I guess I'll just chock it up to experience and go buiy a genuine unit from Tischer (getBMWparts.com).
that is exactly what happened with me. i am sure it is not EAC Tuning's fault. the timing on yours matches pretty close to the timing on mine.
G~ |
#61
For the cross-linked record, we have new information on how better to tell if a Chinese-made Behr Hella expansion tank needs to be sent back upon arrival!
#62
For the crosslinked record, see this thread today:
> E39 (1997 - 2003) > BEHR expansion tank leaks after 5000 miles [quote=E39_Ryda;6686128]... cooling system job back in Nov 2011. I bought a BEHR expansion tank as recommended on the forums and it even has Made in Germany stamped on the bottom. This morning I was checking my oil and saw this! I've driven about 5000 miles since the replacement and I couldn't believe how quick this tank started leaking around the seams. I'll be contacting www.oembimmerparts.com and see if they'll warranty this or offer me a refund.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#63
To crosslink for the convenience of others, this somewhat related pictorial failed-expansion tank thread was opened recently:
> E39 (1997 - 2003) > 97 528i Expansion Tank questions w pics
#64
Add me to the list of a crack at the seam of "GP" (not Behr) Reservoir.
In May 2006 @ 90K miles, I overhauled the coolant system. The Reservoir (PN 17111723520) was made by "GP", not sure of the "Country of Origin" (was it "Made in Germany" or "Made in China"? I don't know). Fastforward 6 years/40K miles later, I notice that I lose approx. 1 cup of coolant every month, and the bottom of the reservoir was wet. The bottom line: very fine crack on the FRONT side of reservoir and the Seam. One thing I have always done, when I replace any parts preventively and if the part is still good, I keep it. So it is a good thing I still kept the factory reservoir (made in 1997), so it goes back in for now until I sort it out. So the questions: 1. Is everyone happy with BMW dealer reservoir (someone told me it is made by "GP")? 2. The Behr reservoir (made in China): I am staying away from this! 3. Online vendors also sell "Meyle" reservoir: is it any good? 4. My last resort is to mod the BMW using the Reservoir from a 1998 V70 (the 850 series) Reservoir. The thing is: my 1998 Volvo V70 reservoir from factory is still chucking along at 14y/120K miles. Also, people in Volvo forum rarely report reservoir issues! -------- Here is the pic of the crack at the seam on the Reservoir by "GP" after 6y/40K miles: Last edited by cn90; 07-27-2012 at 06:10 PM. |
#65
I had two behr expansion tanks fail on me. One lasted 7 months one 9 months. They were fitted by a indie which kindly fitted me a genuine BMW one 16 months after the original work.
Leak was from the bottom both times, so presuming these were both China made tanks. Pretty shocked at behr quality control! They are doing there brand much good.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it. |
#66
When I was replacing the cooling parts last month, The OEM one still looks ok, so I rather use it than the new BEHR I got, I am keeping it as a spare in the trunk in case the old one **** out on me.
96 528i AT w/steptronic. => 97 540i w/ steptronic. |
#67
Cn,
Buy an OEM expansion tank from: 1. www.TheBMWpartstore.com or, 2. www.EbmwParts.com Both are dealers, and their cost is around $70 for the tank... http://www.thebmwpartstore.com/oempa...111723520.html
#68
Thanks Jason,
As you can see my reservoir from 1997 is still good (I had it in the trunk!). I don't know who made the reservoir for BMW in 1996/1997, maybe Behr but made in Germany like the good old days. Somewhere in the forum I see that the dealer BMW tank has the "GP" marking on it. I have to search. My guess is "GP" lasts about 5 years, what a shame. ------------ This post seems to indicate that current BMW tank is made by "GP": http://www.bimmerfest.com/forums/sho...d.php?t=607167 Quote:
#69
So as mine - 8/1997. 155k miles, still in the car and working fine.
#70
http://www.alibaba.com/trade/search?...oduct_en&fsb=y
Maybe I should leave the 1997 factory reservoir in for now! Why mess with success LOL! |
#72
For the cross-linked record, another early failure was reported today:
> E39 (1997 - 2003) > 8 month lifespan of coolant reservoir?! Quote:
#73
As Fudman recently stated, I'm beginning to lean toward the new adage to buy only Behr expansion tanks - and - even then - only from the dealer.
But I'm not sure of that yet. Here's my story: a) My 2002 OEM expansion tank lasted until 2010 (which is good service) as I've had the car since it was still under the original factory warranty and I've checked the date codes b) Even then, the OEM expansion tank didn't leak, per se (the radiator went, so I replaced the expansion tank - and in doing so, broke off the rotted nipple, yet I must say the bobber separated about a year or two prior to the replacement) c) I replaced with a tank from Max, whom we all know and respect. d) Now, only two years later, that tank is (apparently) leaking! Sigh. If this turns out to be the expansion tank, I'd be disappointed I got only two years of pretty tame use out of it. Now, here's the real reason I'm posting. Notice the color of the old and new bobber: I wonder. My initial (wholly unsubstantiated) hypothesis is that the factory Behr bobber is white while the aftermarket bobber is red. Is this the case? If so, then we can advise anyone with a red bobber (like mine) to be cautious. QUESTION: But first, I'd like to ask what COLOR the bobber is for the various Behr tanks (China, South Africa, and BMW dealer)?
#74
I think my original expansion tank float is white...
I would try to possibly return your bad expansion tank, and just get a new OEM tank from the dealer...! Talk to Mike at www.TheBMWpartStore.com . http://www.thebmwpartstore.com/?i=2&...n=8&type=parts Cooling system, Reservoir 525i, 528i, 530i - 2.5l, 2.8l, 3.0l List Price : $98.22 Your Price : $74.26 Thanks! Jason
i just bought a new BMW expansion tank for my 540. it has the BMW emblem and came in the BMW box. it has a red float. i am not sure if the float was ever white in a 540 expansion tank.
G~ |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
