Old 01-17-2013, 06:21 PM
rb25det rb25det is offline
Mein Auto: bmw 323ci
Electrical malfunction has this ever happen to anyone
I have a video to show what's going on. Its on YouTube under "vid_20130117_183344" 1st I have the key in between off and accessories, then I turned it to the off position, the I turn it back to accessories where it should be, then prime, then start, but as you can see I turn it back to prime and the car is still running I can even take the key out and the car will stay on. "BTW the bleep was a text". Does anyone have any idea what's going on?
Old 01-17-2013, 06:22 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
How old is your battery?
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 01-17-2013, 06:26 PM
Not old at all
Old 01-17-2013, 06:29 PM
Well, if the battery is ok it might be worth checking the ground and positive connections are clean and tight.
Or it may be something within the key cylinder/actuator. Hard to say.
I honestly dont recall seeing many issues like this.
- J.C. Watts Jr.
Old 01-17-2013, 06:36 PM
Actuator? Well to have the car completely off I have to either disconnect the battery or leave the key in the half way position but then I can't take the key out. If I take the key out eventually everything turns on as if I'm about to start the car, even the a/c turns on too. I've had to jump start the car 3 times since this issues because I forgot to disconnect the battery.
Old 01-17-2013, 07:56 PM
scottjoh scottjoh is offline
Mein Auto: 1999 323i
Ignition switch assembly is bad.
