E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
#76
OK, I've learned a few things since my last post. Most recently, the frame-less windows on the coupe suck when the car has been coated in ice. The windows couldn't move down enough to open and close the doors properly. Getting the door open wasn't too hard, but I couldn't close it all the way from inside the car. I drove to the gas station this morning with a door ajar indicated until I was able to use their antifreeze and wiper to soak the rail until the window moved.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
#78
In any normal car, when the doors are locked and you use the door handle the door open, in my e46 they don't, It was annoying me because I would start to exit the car and realize I had to hit the unlock button.. till I saw my son open the door without unlocking it.. My 11yr old told me I had to open the door handle twice and that would open the door without having to hit the unlock button.
i discovered what that blue/white/red knob did between the two vents on the dash.. and the butterfly valve in the exhaust, which is now stuck open :-)
#80
that it is both enjoyable and maddening at the same time.
#81
Every nut and bolt is pretty much rusted together.
F*ck cars from the North.
I noticed that my auto trans has a sport feature - now I use it most of the time - so much better. Obviously, I also realized I should have purchased a manual.
Bought the car in the summer and by winter went to use the windshield washers and the motor was broken- just fixed for 20 bucks. |
#83
My car has a full Bilstein suspension setup lowered 1.5 inches along with all of the rubber bushings replaced with solid polyurethane. The PO even took the time to put in a set of performance camshafts.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03 Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02 |
#84
Uh. I learned my car had been in a small front end collision, I learned it gets no grip in rain, I learned I payed too much and it wasn't an m. I got too excited when I found a z3 coupe and just bought it without really checking it out. I didn't know they made a non m. What the hell was the point of that?
#85
i discovered my ZHP came with Shark Injector installed
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
#86
there is a flashlight in the glove compartment, it plugs in to a charging outlet so its always ready to go! its my first bmw...
Sent from my DROID X2 using Bimmer App |
#87
http://www.facebook.com/home.php?sk=...?id=1338939628 "I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride" |
#88
Calling that thing a flashlight is a bit generous.
#89
Moving the turn signal stalk UP or DOWN with the ignition key off illuminates the parking lights on that side.
Pushing the odo reset button with the ignition key off will tell you the mileage in the cluster.
It's not as hard to do maintenance as I thought.
A stuck thermostat robbed me of at least 5 MPG for who knows how long. Buy OEM whenever possible because aftermarket may not fit as intended. The Stealership may or may not have your best interest at heart. The human head weighs about eight pounds.
The owner's manual says five window sprays will trigger the headlight washer but how long (0.1 second to 5 second?) is considered a spray? If the headlight is not on, five window sprays will not trigger the headlight washer. |
#94
Good looking woman
I learned that my car is like a good looking woman -a lot of maintenance to keep up, friends are jealous, expensive to keep, I like her better with her top off, exterior does not like rain, and moody as sh*t. But in the end I like her in my garage and not in someone else's.
#95
While installing an aux plug into the HK / DCS plate I found a belly button ring. I took it out and placed it in the cup holder. The next time my gf was in the car she saw it and I got in trouble. That was hard to explain.
Sent from my PantechP9060 using Bimmer App
If you have the auto-dimming mirror, the nose doesn't turn (there's no need for it to turn).
#98
The gas intake door is locked/unlocked based on the driver side door lock status.
If the driver side door is locked and gas intake door is open, you cannot close it. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
