Old 12-31-2010, 01:50 PM
flyboy50dabo55 flyboy50dabo55 is offline
Send a message via AIM to flyboy50dabo55
Mein Auto: 2004 BMW 745 LI
Oil Pressure too low, stop engine warning
First it said oil was low i added oil.The next day the car begins to idle funny shakes/vibrates.Now its telling me oil pressure is low stop engine possible damage to engine.I noticed something leaking from the bottom of car near the front driver side wheel.Due to the weather here in nyc ive been unable to get it to a mechanic i just wanna know if anyone know whats going on.It also makes a tapping sound while idling..Please help..
Old 12-31-2010, 01:54 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- met in Rome, named Mo
Mein Auto: 2008 535i
If something is leaking, stick your hand under there and see what it is. If it is oil, considering the messages you have had, I would not start the engine or drive it until it can be flat-bedded to a good mechanic.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 12-31-2010, 01:57 PM
O ok but do you have a idea of what could it be?I believe its oil leaking though...
Old 12-31-2010, 04:39 PM
ikob ikob is offline
Mein Auto: bmw 745LI
oil presser switch.. I hope thats all. its not to expensive part
http://realoem.com/bmw/showparts.do?...39&hg=12&fg=05
good luck bro
Old 12-31-2010, 05:18 PM
07841-tb's Avatar
07841-tb 07841-tb is offline
Mein Auto: 02' BMW 745li & 04 Rover
I once got the same low oil pressure message. I had a bad oil pressure switch but make sure you look for an oil leak.
2002 BMW 745Li
2004 LAND ROVER RANGE ROVER HSE
Old 12-31-2010, 05:21 PM
so wait the switch can make the engine sound like that?
Old 01-01-2011, 03:38 AM
RTGrove RTGrove is offline
Mein Auto: 2006 750 Li
Yup - once it lets all the oil out. Ive had them let go on other cars and its amazing how fast the oil can come out of there under pressure. Hope you didnt do any permanent damage but it sounds like you might have... Sorry
2006 750 Li - His
2006 Volvo V70R - Hers
2002 Porsche 911 Cab - Her idea
1956 Ford Sunliner Convt - His idea
Old 01-01-2011, 08:53 AM
I hope I didn't
Sent from my PC36100 using BimmerApp
Old 01-01-2011, 08:59 AM
Ok I just ordered the pin do I need more than one?
Old 01-01-2011, 01:34 PM
irokdastar383 irokdastar383 is offline
Account Under Review
Mein Auto: 745li
i had this a week ago when i did my oil chnage . check your filter.
Old 02-28-2011, 09:58 AM
Wojtek-s Wojtek-s is offline
Mein Auto: 745il
Oil pressure warning
I got same oil pressure warning. I checked the oil level - looks good. The Oil and oil filter was replaced at the dealer recently so I don't think I have the Oil filter issue. I think that I should replace the sensor (as suggested earlier). Please advice how the change the sensor - I can't find it in my car (2004- 745 il).
Wojtek
Old 02-10-2013, 02:07 PM
Swasey745Li Swasey745Li is offline
Mein Auto: 03 745Li
Talking low oil pressure
I recently purchased an 03 745Li and after a few days I kept getting the "oil pressure too low, stop immediately & contact BMW roadside" message on the screen and the "low oil pressure" warning under the speed-o. It would only happen once the engine was warm and mostly at low RPMs. Then if you would step on the throttle a bit, the message would go away. sometimes it would go on and off more frequently than others. Some days not at all. I took it to BMW and of course they claim to be unable to duplicate the message after driving it 10 miles and letting it idle for 15 minutes. They charged me the $130 diagnostic fee and told me i'd have to pay another $130 to wash down the engine and find a leak. After they changed the oil, the message didn't come back for a couple of days. Then the moment i dreaded, ding, oil pressure too low.
After reading many suggestions, I went to an auto parts store and bought an oil pressure switch, swapped em and haven't gotten the light back since. I noticed that not many threads weren't detailed enough on how to change the switch or share it's location. By all means, this is NOT a DIY, but simply what I did to change the part. I took the engine cover and passenger side valve cover, cover off. remove the airbox. 2 phillips screws towards the front of the car on the airbox are all you have to take out to get the box out. It is a VERY tight fit but with some wiggling and elbow grease, she'll come out. The switch is located under the valve cover and towards the front of the engine. It looks very similar, if not identical to the coolant temp sensor located at the front of the motor, towards the middle. remove the silver clip holding the plug onto the switch (be careful, you need this clip, otherwise, the plug will not stay on). I used a 15/16in deep socket to get the old sensor out. you may need to remove a hose that is in your way, you'll know once you get to the sensor. it clips on and off very easily. take the sensor out, replace with a new one and put everything back together. keep your fingers crossed that this will solve your specific low oil pressure issue. i hope this helps anyone having the same issue. Sorry for not taking pix, when I replace my halo ring bulbs and have to remove the airbox, I will try and take pictures
Old 03-15-2014, 08:36 PM
sastorguang sastorguang is offline
Mein Auto: bmw 7 sieris
i have exactley the same experience with my car. if you know the reason,
let me know. i think it is a common problme, and most of user
did not know why even mechanicas
Old 03-16-2014, 07:51 PM
nr123 nr123 is offline
Mein Auto: 760li
You are in NY, contact BMWOEM1, he does great work.
Old 08-22-2014, 08:27 PM
Frankito Frankito is offline
Mein Auto: 2005 BMW X5 4.4 Sport
How do I contact BMWOEM1 ? Just got the same light only problem is I am 40 miles from home smh
Old 08-24-2014, 09:52 PM
gammodm gammodm is offline
Mein Auto: 2004 745i
It's either the sensor or the nonreturn check valves, both are easy DIY
Old 08-26-2014, 01:53 PM
javito javito is offline
Mein Auto: 2004 bmw 745li
It happened to me before,turned out to be the oil pressure sensor.....
Old 12-08-2014, 09:48 AM
kuchib kuchib is offline
Mein Auto: 2006 750Li
2006 BMW 750Li
Hi Folks:
Just registered and wanted to introduce myself. I have this 2006 750Li for a few years (bought used in 2009) and its been a fantastic car ! Love driving to all my meetings as far away as Philly (I live in NC). Its a dream to drive this car!
I take my car to a local BMW specialist who came highly recommended and so far he has been impressive in maintaining my car.
I am getting all kinds of fault codes now including oil pressure low that some have reported here and attributed it to a faulty oil pressure switch. I will mention this to my mechanic.
Also, my mechanic told me that several of these fault codes may be related to my software being out of date and that I should go to the dealership and have the software updated. The dealer here in the RTP area (Performance) says that I have to bring it in for them to update the software. The cost is included if the car also has recall notice which my car has (and I didn't know this) regarding seats. SO I have an appointment tomorrow. I will post whether that software update does take care of my fault codes.
Great to be here and thanks for all the helpful posts. Cheers!
RK
Old 12-08-2014, 10:55 AM
Squiddie's Avatar
Squiddie Squiddie is offline
BMW Snow Plow User
Mein Auto: e89 Z4, e46 330Ci vert
Gotta be honest. If my 8 year old 7-series was suddenly complaining about low oil pressure, without me having changed anything about the software, I would not drive it to the dealership to have the software updated.
Old 04-07-2015, 05:23 PM
Drillsgt Drillsgt is offline
Mein Auto: '03 745i
So is there more than one item that could be the cause or may need to be replaced? I keep seeing the words "oil pressure sensor" and " oil pressure switch" are they the same thing? I've had the sensor replaced but the problem still presists. I've had the oil pressure tested and the car has pressure so I just chalked it up to the cars age and that it might have a short somewhere thats causing the message. Does anyone know what the pressure is supposed to read? I just got the idea that although there is pressure, it might not be high enough to satisfy the sensor. My guy checked and said the car is at 60 for a presure reading. If it is too low, what could be causing it to lose presure?
Just slightly better than my Aztek.
Old 04-07-2015, 06:21 PM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
Try this???
The early bird may get the worm, but the second mouse gets the cheese.
Old 04-08-2015, 09:28 AM
First thing I would do it replace oil pressure sensor. It's under air box on passenger side of engine. You can get it for like $20 anywhere. See if that solves the problem.
If that doesn't work then you have 6 sending unit/ check valves on top of the engine above the water pump and below the air intake. You can find them on the Internet, go ahead and replace them all.
Both items are probably 30 minute fixes each.
