E90/E91/E92/E93 (2006 - 2013)
Replace battery in key fob?
I have a 2008 335i. Is there a battery in my key fob? If so, how do you replace it?
p.s. I don't think I have Comfort Access, although I'm not really sure what that is. |
There is a battery in your FOB but it recharges inductively when it is in the "ignition" slot in your car. Your owners manual talks about it. Make sure and use both of your keys periodically to recharge them.
You can watch this or similar Video on YouTube save some money but ended up cut yourself in the hand and have to drive to UMC
Or Drive to Desert BMW and call it a day I think you might need dealer help for that.Ahhh Nevermind...You are MrVegas but live in MD
Ohhhhh.... The ultimate attraction "Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves." Albert Einstein |
It's easy to know if you have CA on an '08 3 series. Your door (or all doors depending on setting) will unlock when you grab the outside handle to get in the car assuming the key is in your pocket or nearby. Also you can start the car without putting the key in the dashboard slot.
BMW-CCA Bimmerfest Supporting Member 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm Last edited by markl53; 01-01-2011 at 11:36 AM. |
OP: If you have comfort access (you really need to find this out - it will be on the original window sticker), then the instructions for replacing the battery are in the owner's manual - it takes a CR2032. If not, I'd have a dealer do it if the battery won't recharge when you drive the car. Tom |
My FOB is also broken although it does work off and on. It's the non-CA FOB. I'm going to make an appt. next week. While it's the only thing that has gone wrong with my 38-mth.-old car, my gut tells me the key FOB is a high-failure rate part (you think they put the back up key in the FOB out of the kindness of their hearts or as a sign of no confidence?).
UPDATE: I misread your comment.. But on a slightly different note, how is your FOB failing?
2007 328i, Montego Blue, R.I.P. E.D. Planned for Fall of 2011.... Last edited by Vulpes; 01-01-2011 at 06:23 PM. Reason: misread the post |
UPD
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
