Old 01-05-2011, 10:25 PM
Ebonix's Avatar
Ebonix Ebonix is offline
Mein Auto: 2002 E39 530I M Teck
Originally Posted by edjack View Post
How many miles on the car?
In The Olden Days, new Guibos were supplied with a steel strap around them. Don't know if that's still true, but, if it is, leave the strap on until all bolts are tight. The strap serves to compress the rubber in order to get the bolts in.
When the nuts are nearly tight do not turn the bolts, but just the nuts. This will prevent twisting the steel inserts.
257,000 KM - excluding the 20,000 + that don't show up due to a non working speedo
Flex disk removed was the original - no steel straps - all bolts slid through like a knife through hot butter
Current - E39 M5
Current - E39 530IA M-Teck Steptronic
Previous - E39 540IA Modified Full Custom 3" Exhaust
Previous - E34 525IA Stock
Previous - E28 520IA Stock
Previous - Porsche 911 '77 Carrera
Old 12-22-2011, 09:49 PM
ztitans1 ztitans1 is offline
Mein Auto: 1997 528
Wow all this about how to properly name the part and nothing on how to actually fix it. I enjoyed the read, but need to move on to figuring out how to actually repair my car.
I just love this logo...
Old 08-27-2012, 07:49 PM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
I think this will be a project for me sometime down the road (pun intended) ;-)
Ebonix stated, "Suffered severe vibration under heavy acceleration a few weeks ago." Mine is more light to moderate under moderate to heavy acceleration and goes away once at speed, or if I let go of the gas. Under light acceleration--nothing. It could be a million things including drive shaft, trainy mounts etc. But is my description more indicative of the Flex disc?
Old 08-28-2012, 10:08 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Angry
This is quite helpful, thanks.
Old 08-29-2012, 11:05 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I don't know, but typing /vibration in the bestlinks nets these, which may help:
- The main causes of vibration while highway driving (0) (1) (2) (3) (4) (5); while highway braking (1) (2) (3) & why it's not rotor "warp" (1); and severe shuddering while slow speed braking on bumps (1) & TireRack vehicle vibration diagnosis chart (1) (jpg) with match mounting hints (1) & due to worn drive shaft, flex disc, center bearing, or "giunti Boschi", namely the giubo (pronounced sort of like jew'eebo), and sometimes unknowingly misspelled as "guibo" (1) (2) (3) (4) & how to repair the rear driveshaft seal by the differential (1) or the inner constant velocity (CV) half-drive shaft (1).
Old 08-30-2012, 06:11 PM
Bimmer01girl Bimmer01girl is offline
Mein Auto: 2001 330i
So if this is bad would my car vibrate like a u-joint was bad. This is my first drive shaft issues with my car. I've only owned it for six months.....
*inlove with my 330*
Old 08-30-2012, 06:16 PM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
Uhm, you do realize this is the E39 5 series forum not the E46 330 forum, right.
Generally speaking, vibration can come from a variety of sources like wheels, engine, drive shafts, braking.
Would help to be more specific your description as to when it vibrates.
Answers may be limited here unless an E39 owner happens to also have an E46.
Old 10-13-2013, 04:31 PM
rodhutch rodhutch is offline
Mein Auto: BMW E39 530i Sport
530 Flexdisk replacement
Have only seen posts on e39 V8s. Do you have to drop the exhaust on the i6 E39s to replace the flexdisk/guibo?
