Old 01-13-2011, 07:58 PM
vinnt vinnt is offline
Mein Auto: BMW 745i
If you press the trunk button 1nce quickly and hold it the second time the trunk will close automatically. U just gotto hold it until it seals otherwise it'll just open again. How do I turn the welcome home lights on on my car? Also how do I set the doors to lock automatically when pulling off/driving.
Old 01-14-2011, 05:25 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Successful changes that I have made so far and things that might be interesting (and to help summarize previous notes from some of the other guys, obviously primarily 7figurez & makaveli)... I will add to the list as I get the time to format the stuff. My hope is to have a single place to consolidate the interesting things, though if someone wants to build up a master reference thread in the DIY section, it might be helpful to others. Keep in mind that I have a 2002 E66, which appears to include more check-controls turned on than later cars.
  • CAS module
    • Comfort close windows using remote (push-hold lock button)
      • KOMFORTSCHLIESSUNG_FB (comfort closing with remote (power windows, sunroof or convertible top))
        • aktiv (set to this)
        • nicht_aktiv (original value)
  • HKL module
    • Comfort close trunk (push-hold lock button)
      • KOMFORT_SCHLIESSEN_HKL (comfort close trunk (push-hold trunk or lock button))
  • LM module - IGNITION MUST BE ON TO CODE
    • Turn daytime running lights on/off
      • DRL_V_GEDIMMT (daytime running lights / NCSDummy: dimmed front daytime running lights)
        • nicht_aktiv (lights off)
        • wert_01 (unknown / value 01)
        • wert_02 (lights on / value 02)
    • Change light-touch blinker behavior
      • MIND_ANZ_ZYKL_TIPP_BLK (one-touch turn signal function)
        • wert_01 (one blink / value 01)
        • wert_02 (three blinks / value 02)
    • Remove check-control for backup lights
      • FEHLERMELDUNG_CC_RFS_L (check control (CC) left backup light failure)
        • aktiv (original value)
        • nicht_aktiv (set to this)
      • FEHLERMELDUNG_CC_RFS_R (check control (CC) right backup light failure)
    • Set to allow front fog lights with high beams on
      • FL_UND_NSW_NICHT_GLEICHZ (front fog lights not simultaneously with high beams)
  • MMI module
    • Remove legal disclaimer accept
      • FAHRZEUGTYP_MMI
        • ece_ll / europe (left-hand drive) (set to this)
        • ece_rl / europe (right-hand drive)
        • us_ll (original value)
      • LAENDERVARIANTE_BNDB_MMI
        • aegypten / egypt
        • australien / australia
        • deutschland / germany
        • ece / ece (europe) (set to this)
        • gb / great britain
        • golf / persian gulf states
        • japan / japan
        • kanada / canada
        • korea / korea
        • suedafrika / south africa
        • taiwan / taiwan
        • us / us (united states of america) (original value)
  • SHD module
    • Close sunroof with wiper operation
      • REGENSCHLIESSEN (close sunroof with automatic (RL) wiper operation)
      • REGENSCHLIESSENTILT (close tilted sunroof with automatic (RL) wiper operation)
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 01-14-2011, 06:14 AM
joej85 joej85 is offline
Mein Auto: 2004 745Li, 1989 735i
Keif,
I love the list format you started. We definitely need a list of the popular items to code!
Heres another thing I would like to code away...
Does anyone know how to get rid of the "location" screen that pops up on idrive? When the dealer turned off BMW Assist on my car, this screen started coming up every time i start the car. (Along with the legal one). At least the location screen will go away on its own after 30 sec or so...
Old 01-14-2011, 07:06 AM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
Originally Posted by joej85 View Post
which module are these in?
I had to code them in the main cas file that was generated before I picked a module.
then I had to hit process whole car instead of picking a single module. And then code car.
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 01-14-2011, 09:39 AM
bmw74me bmw74me is offline
Mein Auto: 750i
To add to kief's list
In the iDrive can be selected after changing all 3 values below the additional option M-HUD under the HUD settings.
Control unit: Cappl
MDrive
nicht_aktiv -> active
HUD_M
Control unit: HUD
M_SPORT_HUD
nicht_aktiv -> aktiv_handschalter
[Turn indicator in the HUD]*
Control unit: HUD
BLINKER_AUSSTATTUNG
[Reel speed or tachometer option in the onboard computer]*
Digital speedometer in the vehicle computer.
Control unit: COMBINATION
BC_DIGITAL_V
BC_DIGITAL_V_KORREKTUR
active / nicht_aktiv
[Permanent instrumentation lighting]*
The speedometer light despite the lights always on first ignition
M_TAG_SKALENBELEUCHTUNG
[Blank line in the paste-board computer]*
BC_LEERZEILE
[Speed settings for climate control display]*
The current fan speed is displayed even in the automatic operation of the air conditioning.
Control unit: IHKA
GEBL_ANZEIGE_AUTO
[No automatic. Compressor] with climate control*
When you press the automatic button will no longer switch automatically sets the air conditioning.
Control unit: IHKA
ABWAHL_AC
[Spiegelanklappen on the remote key]*
Connect with the comfort = longer pressing the Connect button on the remote control.
Control unit: KGM or TMBT and TMFT
BEIKLAPPEN_B_KOMFORTSCHL
[Roof rain Close]*
with rain sensor is activated.
Control unit: SHD or HSDH
RAIN CLOSE
If with respect to the coding, an error message comes the pinch:
- Ignition on
- Ensure that the sunroof is closed
- Press the key to lifting / tilting the sunroof and hold (approx. 1 minute) until all settings have been hit once and the sunroof is closed.
[Comfort tailgate open and close]*
Komfort-Öffnen/Schließen = longer pressing the open or close button on the remote.
Control unit: HKL
KOMFORT_OEFFNEN_HKL
Tailgate by pressing only once on the key itself include:
FUNKTION_FBD_SCHLIESSEN_2
nicht_aktiv -> active*
Tailgate to close the switch in the foot:
FUNKTION_TOEHKI
[TV / Video while driving activation]*
Control unit: Cappl
VIDEO_DENY_C0B
deny_slow_key -> deny_never
[Entry aid steering wheel height adjustment de-/activate]*
Control unit: tractor
EINSTIEGSHILFE_HOEHE
active -> nicht_aktiv
[Steering wheel button function "next entertainment source" Add]*
Control unit: Cappl (from the first software release CCC_APP.C0A)
NEXT_SOURCE
AM Tuner skip:
AMBANDS
[IDrive options for acoustic locking and unlocking Add (with DWA)]*
Control unit: Cappl or MASK
ACOUSTIC
C941C_QUITT_AKUST_KLAPPE
fkt_gesperrt -> fkt_frei
K9416_QUITT_AKUST_ENTSCH
C9413_QUITT_AKUST_SCHAERF
[Change the alarm sound of the beeping of the DWA to howl]*
Control unit: DWAS
ALARM TYPE
U.S.
[Advanced maneuvering in the iDrive menu]*
for example, a rear-view camera is connected via LVDS.
Control unit: Cappl
RVC
RVC_CONNECTED_TO_VM
nicht_aktiv / active
RVC_DISPLAY_OPTIONS
main_or_fullscreen / only_fullscreen only_mainwindow /*
[Seat climate menu in the iDrive]*
Control unit: Cappl
VA_AIRVENT_SHORTCUT
VA_SEATCLIMA_SHORTCUT
VA_SEATHEAT_SLIDER
VA_SEATVENTILATION
SITZHEIZUNG_APP_9
[SMS display in the iDrive]*
Control unit: Cappl
SMS
[Notepad complement in the iDrive menu, phone]*
Control unit: Cappl
NOTEPAD
[Comfort Open (2 times to open the remote control) to the driver's window semi]*
Control unit: Cappl
K931D_SCHEIBENABSENKUNG
par_gesperrt -> par_frei
[Light sensor sensitivity settings menu in the iDrive]*
Control unit: Cappl
RAIN_LIGHT_SENSOR
C750A_SCHWELLWERT_EMPFIN
C750A_SCHWELLWERT_NORMAL
C750A_SCHWELLWERT_SEHR_E
and vehicle application by:
FLCN + = normal threshold
+ FLCS = threshold very sensitive
[Light sensor sensitivity setting]*
Control unit: RLS
FLC_SCHWELLWERT_SATZ
wert_01]
wert_04] = sensitive
wert_02 = normal
wert_03 = very sensitive
[Daytime running lights non LCI]*
VFL headlights with LM1:
Control unit: LMA
DRL_V_GEDIMMT
nicht_aktiv -> wert_01 = Indicator -> wert_02 = beam
DRL_WERT_DIMMUNG
wert_01 = 26% -> wert_02 = 40%
Daytime running lights on the main (only LM2):*
VERHALTEN_DRL_TFL_33
drl_tfl_off -> drl_h -> drl_s -> drl_l -> tfl_s
U.S. daytime running across the beam (only halogen beam and LM2):*
drl_h
PWM_FL_FKT_DRL_33
wert_01 to wert_03 = Dimmungswert
[U.S. indicators with side turn indicators on parking lights or headlights]*
Control unit: LMA
DRL_TFL_BLK_V_GED
PWM_SIDEMARKER_BLK_V
wert_01 = off
wert_02 = light
wert_03 = dark
[Side marker lights with daytime running lights activated (only LCI)]*
Control unit: LMA
SL_V_MIT_TFL
active
[As cornering fog lamps with LM2]*
! Works! Jakober not loud! Request for feedback
Control unit: LMA
PWM_FL_NSW_FKT_ABBLIEGELI
wert_01 -> wert_02
[Cold and hot control of the lamps]*
Control unit: LMA
KALTUEBERWACHUNG_
KALTUEBERW_
WARMUEBERWACHUNG_
WARMUEBERW_
FEHLERMELDUNG_CC_
RFS_R, RFS_L = Reverse Light
FL_R, FL_L = beam
AL_R, AL_L = cornering
SL_V_R, SL_V_L = parking light
NSW_R, NSW_L = fog
BLK_V_R, BLK_V_L = flashing front
BLK_H_R, BLK_H_L = flashing back
BL_M_1 = 3 Brake light
KZL_R, KZL_L = plate light
NSL_R, NSL_L = rear fog lamp
TFL_R, TFL_L = Daylight
SML = Side marker lamps
BL_R, BL_R = brake light
RL_BL_1_R, RL_BL_1_L = tail light brake light 1
RL_BL_2_R, RL_BL_2_L = tail light brake light 2
[Welcome Light]*
Only works with light module 2 (LM2 all LCI or all VFL 09/2006 have with xenon and adaptive headlights) and the light switch in automatic position + position 1
Control unit: LMA
WELCOME_LIGHT_ACTIVE
WL_AL = low beam
nicht_aktiv / hart_einschalten
WL_BL = brake light
nicht_aktiv soft_einschalten / / hart_einschalten
WL_BLK_H = Left Rear
WL_BLK_V = front indicator
WL_FL = beam
WL_KZL = plate light
WL_NSL = rear fog lamp
WL_NSW = fog
WL_POL = position or the front parking light
WL_SL_1 = closing or parking light rear 1
WL_SL_2 = closing or parking lights, rear 2
WL_SM = Eyebrow
[Coming Home Light only VFL]*
After switching off the engine and operate the ignition, the flashing briefly.
Control unit: LMA
HEIMLEUCHTEN_
[Eyebrow / off]*
Control unit: LMA
SIDEMARKER_US
[Flash light with bi-xenon]*
Control unit: LMA
BI_XENON_BEI_LH
[Interior of brake lights during normal braking (only VFL Taillights)]*
Control unit: LMA
RL_BL_1_BREMSL_FKT
[Beam with the Xenon headlights and not also on the high beam-H7 (only VFL)]*
Light switch to automatic:
Control unit: LMA
FL_AUS_BEI_BIX_IN_S_FLC
active
Light switches in all positions:
Control unit: LMA
PWM_ANST_FL_BIXENON
wert_03
[Beam and fog lamps are not simultaneously]*
Control unit: LMA
[Flashing adaptive brake lights (Break Force Display)]*
In an emergency stop flashing the lights.
Control unit: LMA
BFD_1_RL_BL_ERSCH_BILD = brake light
wert_03 = flashing
BFD_1_BL_M_ERSCH_BILD = 3 Brake light
wert_03 = flashing
BFD_1_RL_BL_1_ERSCH_BILD = brake light 1
wert_03 = flashing
BFD_1_RL_BL_2_ERSCH_BILD = brake light 2
wert_03 = flashing
BFD_1_NSL_ERSCH_BILD = rear fog lamp
wert_03 = flashing
[Warning light on de-/ activate]*
Control unit: LMA
LICHT_AN_WARNUNG
[Zündschlüsselwarnung de / activate]*
CC_ZUENDSCHLUESSEL
[Acoustic seat belt warning disable]*
Note: The effect on the release behavior of the air bag is unknown.*
Control unit: ABG
SBR_BEIFAHRER_ACSM
SBR_FAHRER_ACSM
or a vehicle, contracting with the value:
+ OI11 for the driver
+ OI12 for the passenger
and
to 03/2004:
SBR_BEIFAHRER
nicht_aktiv
SBR_FAHRER
nicht_aktiv
from 03/2004:
Control unit: SGM
SBR_BEIFAHRER_SGM
nicht_aktiv
SBR_FAHRER_SGM
nicht_aktiv
Control unit: ACSM
SBR_BEIFAHRER_ACSM
nicht_aktiv
SBR_FAHRER_ACSM
nicht_aktiv
[Passenger seat occupancy sensor mat disable]*
Control unit: SBSR
SBE1_SBSR
nicht_aktiv
or
Control unit: ABG
SBE1_ACSM
nicht_aktiv
[Home Comfort]*
The ignition key must be touched only briefly to the ignition to start the car.
Control unit: CAS
HOME COMFORT
[PDC volume change]*
Control unit: PDC
LAUTSTAERKE_HINTEN
e65, e60, RR1, e70, wert_02 to wert_07
LAUTSTAERKE_VORN
e65, e60, RR1, e70
[Engine start only when the brake pedal depressed, de-/ activate]*
Control unit: CAS
ANLASSSPERRE_BLS
[MP3 functionality upgrade]*
KMP3 in the FA-supplemented
Control unit: Cappl
MP3_CCC
full
[IPod interface retrofit]*
IPOD in the FA supplement
Control unit: Cappl
MP3_CCC
external or full
CDC
active
[AUX-IN interface upgrade]*
NAUX in the FA-supplemented
Control unit: Cappl
AUX_CONFIG
mounted
INPUT_SCALING_SUB2
wert_02
Old 01-14-2011, 09:46 AM
I know what list you are going off of and those are. Not for 7series. Few will work for 7 but majority won't
Plus we don't have a cappl. Kmp3 is invalid for e65 and those mp3 lines don't exist as well. Those are for 3 and 5 series. Nobody on the net has a e65/e66 list, which is why we are compiling one here.
Old 01-14-2011, 10:48 AM
irokdastar383 irokdastar383 is offline
Account Under Review
Mein Auto: 745li
what code do i need to make it stop ringing that the fog lights , license plate and reverse light is out?
Old 01-14-2011, 11:04 AM
Looks like keif has it in his post up top for reverse lamps. Foglamps line should look the same but with nsw_l and nsw_r at the end.
Old 01-14-2011, 11:11 AM
Master Tinkerer
Good call, I'll add those in when I get home later.
Old 01-14-2011, 11:24 AM
Mein Auto: 745li
thank you guys . btw MakaveliFaison great find.
Old 01-14-2011, 12:21 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Anyone using this on an 06+ E65/65. I read earlier if the NCS files are not up to date that you can end screwing things up and just need to make sure before I go ahead. I will be using the version of NCS expert that is included with INPA that was posted earlier in this thread.
So far I am unable to get INPA to work on my car using a USB to serial adapter. If anyone has this working can you let me know which type of adapter you are using? I can see batery and ignition but cant seem to access any of the modules without running into errors. Any help is appreciated.
Old 01-14-2011, 12:31 PM
Master Tinkerer
Are you using a cable/interface compatible with D-CAN?
Sent from my SPH-D700 using Bimmer App
Old 01-14-2011, 12:45 PM
Mein Auto: 750i
Cool
Old 01-14-2011, 01:37 PM
DFEL750I's Avatar
Mein Auto: 750I
Keif, I bought the cable listed here
http://www.bimmerfest.com/forums/sho...d.php?t=505694
I also downloaded the software used on the first page of that thread at well.
Old 01-15-2011, 01:55 AM
7Figurez's Avatar
7Figurez 7Figurez is offline
Mein Auto: 2005 745I
The above list by BMW74me should be edited or removed as makavli said since most of the coding does not relate to the e65 and you are going to confuse alot of folks with this copy/paste you have put here. You are going to have alot of people saying they cant get to the CAPPL module or they cant find the HUD settings, so I think it should be removed or just put the link to the other forum where u copied it from, so people know where and what the coding came from.
Old 01-15-2011, 01:58 AM
7Figurez's Avatar
Originally Posted by DFEL750I View Post
For those of you in areas where there is no one to assist with coding your car.......if you have internet access where your car is...possibly wireless from your garage....there is nothing that stops one of these guys from remotely assisting you
I would be willing to send out my cable to someone that wants there car coded and I can do it remotely, just as long as you have a laptop and can get internet access out to the car with the laptop.
Old 01-15-2011, 03:34 AM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
I might take you up on that since I can't find the
things you have mentioned ( close trunk from inside button , digital speedo , &
I think there was 1 more I wanted ) I have done everything else I wanted .
Oh ya close trunk with trunk button instead of lock button .
PS: I have my own cord so you wouldn't have to send your's .
Old 01-15-2011, 08:33 AM
Mein Auto: 750i
Agree I was just trying to show what can be done ...no need to point fingers
Old 01-15-2011, 02:47 PM
spera23 spera23 is offline
Mein Auto: 2007 335i Coupe
Hey,
Does anyone know if its possible to code any of the setting on the Navigation?
I find its very annoying that I have to input the country and city everytime I enter a destination where as most navigations just auto default back to the last country/city used.
Any ideas?
Old 01-15-2011, 10:12 PM
teejaylentz teejaylentz is offline
Mein Auto: 2002 745i
For MP3, haven't tried anything yet, but just going through the files looks like MMI and MMIF modules with MP3 and MP3_FOND aktiv.
Old 01-16-2011, 12:32 AM
Had a chance just now to play with this hands on. I was able to see the MMIGT module (MMI) showing up. When I read that module, there is no MP3 or MP3_FOND node in the resulting TRC file.
IF, however, I read the entire car ("Process Car" option), the TRC file does contain those MP3 options.
I'm a bit apprehensive about coding the entire car after updating the resulting TRC from processing the car.
@MakaveliFaison - how are you going about this? will this work on a 2002?
Thanks in advance!
As a side note, was able to successfully use the items listed by Keif - thanks!!
Old 01-16-2011, 06:12 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Originally Posted by bmw74me View Post
Actualy I pm'ed him and his server price seems very reasonable and fair ... But a little more detail about this subject would be great.
He's got allot of good stuff
but as with anything, do any of this at your own risk!
Old 01-16-2011, 07:32 AM
As I stated before my car is a 02 and yes you have to code whole car for mp3. As of right now that's the only way.
Old 01-16-2011, 09:14 AM
DFEL750I's Avatar
Mein Auto: 750I
I have internet access to my car so I can be a good candidate for this.
I took some pictures of the issues I am having with INPA so hopefully some of the experts can help
I am able to get to this screen after I choose E65... as you can see from the pic I can see both battery and ignition
Then I select "body" then "power module" and I get this error
After I click ok on this error I am taken to this screen which seems to be some generic screen for all the modules. I am unable to see the options I need to register my battery
Old 01-16-2011, 12:37 PM
Thanks for the confirmation!
I've tried recoding the entire car (no damage done, it appears it just goes through each module at a time), but when it hits KMBI_E65.C06, this error occurs. Is there a way to skip over this module?
ERROR! Modul: CBD_PROC.C, ProcNr: 02, LineNr: 10, ErrorNr: 40.
003004'01,CC_15_EIN (2587d, A1Bh)
ERROR! Modul: CDH.C, Proc: CDHGetNettoDataFromCbd, LineNr: 01, ErrorNr: 1043
COAPI-1043: error during processing CBD-file
KMBI_E65.C06
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 1043
SG_CODIEREN
Digging around in the files a bit more, it appears the reason we have to code the whole car is that when you read/write the MMI module individually, it is using the file MMI_E65.C02 which doesn't have the MP3 options in it. However, MMI_E65.C04 does have the option "MP3" in it. MP3_FOND, however, appears to be in another separate file MMIF_E65.C04. There doesn't appear to be any way to individually force the use of these files on the MMI module. For kicks I tried copying over MMI_E65.C02 with MMI_E65.C04 and reading the module again, but that fails.
