Old 01-16-2011, 02:31 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
Yea, there multiple coding files for each module depending on what software version is detected. It won't do c04 because we are prefacelift and have old software I believe. I will be upgrading idrive pretty soon though, so I will keep you updated. Mine stops on kombi when coding the whole car also.
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 01-16-2011, 07:56 PM
teejaylentz teejaylentz is offline
Mein Auto: 2002 745i
How did you get past the KOMBI error to be able to get the MP3 and MP3_FOND settings to show up?
EDIT - Thanks for your help so far- if you figure out how to upgrade MMI/iDrive that would be very cool! - I'm guessing you are using WinKFP for that?
Old 01-17-2011, 02:43 PM
joej85 joej85 is offline
Mein Auto: 2004 745Li, 1989 735i
And....Have you confirmed that MP3 really does work?
Regarding the software that was contained in the thread linked earlier in this thread...It is not updated to newer version of software correctly.
The NCS data files in that software appear to be version 2.37 (Files were the same from 2.36-2.38.1). However, NCS also uses files that are located in the c:\ediabas\ecu directory, and these files aren't updated to the 2.37 software version.
I used this version of software to make backups of all my modules and it choked on the LMA. My car was choking because the LM_AHL_2.prg file was missing from the c:\ediabas\ecu directory. I checked the files in that directory and LM_AHL_2.prg was not there and many of the other files are very much older than the 2.37 files in NCS. Whoever updated this software updated only the NCS files and not the ediabas\ecu files.
Be careful with this software.
Old 01-17-2011, 03:11 PM
jbhoot jbhoot is offline
Mein Auto: 2006 750Li
Has anyone tried using NCS Dummy? Here is the link
http://forums.bimmerforums.com/forum....php?t=1553779
Old 01-17-2011, 08:01 PM
Yes mp3 does work. I use it everytime I drive my 7 now. And yes I tried ncsdummy. Didn't really have much of the stuff converted but does show all possible inputs for each line.
Old 01-17-2011, 08:03 PM
Your car probably choked on lma because you have to turn on ignition when dealing with lma.
Old 01-17-2011, 08:30 PM
No, I had the ignition on.
The files in ediabas\ecu aren't up to date with the ncs files.
If you look at the dates of the files in the ediabas\ecu directory, the newest files in there are dated 2005. V2.37 software came out in 2009. The "real" V2.37 ecu files are dated 10/2009. The ncs files in the package are correct V2.37 files, dated 8/2009.
The files may not be an issue if the car software has not been updated recently, but my car needs the newer files because it was programmed with 2.37 software early in 2010.
Old 01-17-2011, 09:17 PM
I'm taking a break on this for now until there are more details on how to enable mp3 support. I still can't get past the KOMBI error - if you have more detail on how to get past that, I'd love to know. I tried a few different versions of NCS Expert and EDIABAS (including the ones in this thread) to no avail.
My vehicle hasn't been updated recently - I think it was updated once in ~2004.
Old 01-19-2011, 01:44 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Added to list of verified items: daytime running lights on/off, one-touch blinker behavior (link back to list).
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 01-21-2011, 10:38 AM
v137p12103 v137p12103 is offline
Mein Auto: 2006 750i
Anyone in the California Bay Area that can do this programming? I am willing to pay. Please PM me.
Old 02-23-2011, 08:42 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Does anyone have a link to a DIY for using NCS Expert. I have INPA up and running and I have done a few things and now Im ready to take a plunge into NCS. Any help would be appreciated. Maybe one of the guys here can do a quick step by step DIY if one is not available
Old 02-23-2011, 11:41 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Could some one that has INPA running do me a favor ?
I need a copy of your FSW_PSW.TRC file for the KOMBI .
I was looking in mine & I must have change something
by accident cause now I can not reset anything
(oil ,spark plugs , coolant , micro filter ) in the secret menu
when you hold the trip meter on the cluster . I would like to
compare my file I saved with yours .
I WOULD HIGHLY APPRECIATE IT & I THANK YOU IN ADVANCE .
Old 02-24-2011, 12:20 PM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: F02 750Li
See this thread: http://forums.bimmerforums.com/forum....php?t=1562077
Old 02-24-2011, 12:37 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Originally Posted by hd750Li View Post
Hey HD... Wanna come by and help a bruh out?
Knowing my luck... I will try this and blow up my ride.
Old 02-24-2011, 12:51 PM
hd750Li's Avatar
Sure! I can help you set up the things or just do it. I have everything on my laptop ready to go. Just PM me, will you? I think you got my email.
By the way, thanks to all other folks, I was able to program almost everything that was mentioned in this long valuable thread.
Old 02-24-2011, 01:10 PM
DFEL750I's Avatar
Mein Auto: 750I
Thank HD. I checked out the link and it seems pretty straight forward if everything works as planned. I will give it a try when I get home
Old 02-24-2011, 06:37 PM
DFEL750I's Avatar
Mein Auto: 750I
I was able to successfully code "windows up with remote" as well as "trunk close with remote" To the other ambitious guys looking to do this make sure you know what youre doing because it is easy to screw things up.
My recommendation is to make a backup of the entire car before you change anything. Then as added safety make a back up of each module that you read before you make any changes that way if things screw up you can go back and use the original to recode the module.
Old 02-24-2011, 06:40 PM
DFEL750I's Avatar
Mein Auto: 750I
I just got back inside from coding the car in the garage so Im cold as hell (My next house will have a heated garage ). If you dont get what you need by tomorrow I will pull it from my car for you.
Old 02-24-2011, 07:52 PM
PAPER's Avatar
CRISP & CLEAN
thank you much appreciated .
Old 02-24-2011, 09:07 PM
spyders 745li's Avatar
spyders 745li spyders 745li is offline
Mein Auto: bmw745li
hey thats cool how did u do that i would love to ad that option. thank
Old 02-24-2011, 09:12 PM
txag_530i's Avatar
txag_530i txag_530i is online now
Mein Auto: 2006 530i
Do you have the V2.37 ecu files? I cannot get NCS to read my car.
Old 02-24-2011, 09:38 PM
DFEL750I's Avatar
Mein Auto: 750I
Read this thread from the beginning. All the info you need is in here
Old 02-25-2011, 08:47 AM
SMOKEDSEVEN SMOKEDSEVEN is offline
Mein Auto: 2003 745 LI
Originally Posted by 7Figurez View Post
My bad, I didnt mean to say you helped me, it was another member and I who figured it out. Its not in the VO you need to change its in the MMi/CCC interface where you change it from US to ECE and US_ll to ECE_LL.
MY VO is still set to US spec and I dont have the warning screen anymore, with the above changes I completed.
hey 7... im in the dc area and wanted my car programmed for the windows and locks... i called you earlier... can you give me a ring 2024131313 thanks
Old 02-25-2011, 04:07 PM
DFEL750I's Avatar
Mein Auto: 750I
Sent you a PM with the link to download the KOMBI TRC File. Mine is unmodified
Old 02-25-2011, 07:46 PM
PAPER's Avatar
CRISP & CLEAN
thanks , I will check it when I get home . thanks again
