Old 01-03-2011, 02:13 AM
mgooding mgooding is offline
Mein Auto: 2004 Z4 2.2i
Z4 windscreen spray not firing
After a very cold winter in the UK my washer jets on my 2004 (04) Z4 2.2i aren't performing as they should.
here's what i know:
- the pump is firing (or at least there's a whirring sound)
- the jets dribble a bit and with constant pumping can sometimes just about hit the windscreen
- the fluid may have ran out - it certainly got low. it's full again now
- this affects both jets so assume it's not localised to a single blocked jet
any help appreciated.
Old 01-03-2011, 02:14 AM
additional - the washer mix is at 50% and went in a few days ago. also it's not cold here anymore and there's no signs of leakage.
Old 01-03-2011, 06:45 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Check for holes/tears in the lines going to the nozzles. Also, check the reservoir and make sure there is nothing blocking the pick-up. Finally, just because a pump is making noise doesn't mean that it is pumping: the impeller blades may have broken.
fluid, washer, windscreen, z4
