Old 01-03-2011, 09:50 AM
slbjr slbjr is offline
Mein Auto: 2011 328i
Please post alignment specs e90 sport pkg
Can someone please post alignment specs for a 2011 e90 328i w/ sport package (sedan)?
I have had a lot of problems with ride quality/stability and it seems the dealer has changed the SAI by 2 degrees, which helped.
Does SAI specs of 15*14' L and 14*0' R (changed from 13*25' or so each side) mean damage? I thought SAI was not particularly adjustable?
Any thoughts on standard SAI settings? I have searched the internet and found nada.
Old 01-03-2011, 11:30 AM
bwillia's Avatar
bwillia bwillia is offline
Just another Gear Head!
Mein Auto: 2008 335xi coupe
See my response on your other posts.
Old 01-03-2011, 11:42 AM
bwilla,
Thanks. The SAI readings are as correct as I think they come, a BMW regional engineer came and supervised the work that was performed because of my complaints.
So in your opinion SAI readings of 15 degrees 15 minutes (L) and 14 degrees 0 minutes (R) [changed from 13.40 L and 13.11 R] indicates some sort of damage? Any ideas on what?
What are the standard SAI and caster readings for this car?
Old 01-03-2011, 03:43 PM
Unhappy Re:
Here are alignment specs - any thoughts are appreciated!
alignment, sai, specs, stability
