Old 01-03-2011, 02:14 PM
mr.haley mr.haley is offline
Mein Auto: 525i
Unhappy 06 525i radiator Swap
So, as it appears I am just another struck by the infamous BMW radiator... I recently had a low coolant notice appear, filled it dropped the under belly plate, and waited... Sure enough I have noticed that it is leaking from the front driver side. I removed the hood latch area and opened things up to look around. I cannot see anything unusual from the top but from the underside, I see its dripping from the bottom driver side of the radiator area. It appears that the radiator is encased in a plastic molding of about 1 inch thick..? Anyways it appears this cant be removed from the bottom, and before I ordered a new radiator I figured that I would see if anyone has any ideas to pin point the leak besides pressure, and if anyone knew of a way that I can completely access the radiator itself from the bottom. Also if I do go ahead and remove/replace the old radiator, does anyone have any advice on tools/technique beforehand or know of a good video?
Old 01-03-2011, 08:26 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
If you want to DIY, get the Bentley manual. I don't know of a E60 DIY for this, but there are E46 examples (E46 fanatics has one, I think) and the job is pretty similar. Good time to do the hoses as well. Not hard.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
coolant, e60, leak, radiator
