Old 01-03-2011, 01:25 PM
Eighthnote Eighthnote is offline
Mein Auto: 2001 3.0i Roadster
Z3 Trouble signs?
Hello all, I noticed some "steam" rising up from under the hood today. No gauge indication of running hot. Open up the hood and could smell coolant but no leaks. Then I saw it. My fan is not parallel to my radiator. Looking at the fan from the front of the car the left side of the fan is much closer to the radiator than the right side. Also when I pull slightly left to right I see the fan pulley moving. Could the bolts just be loose or do I have bigger issues? Thank you all in advance.
Update: I don't think it's as simple as the bolts being loose.
I just stopped in to see what condition my condition was in.
Andrew
Old 01-03-2011, 03:16 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Your water pump has gone.. do not start or drive the car....
You will damage way more than the waterpump
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 01-03-2011, 03:35 PM
reidconti reidconti is offline
Officially Weird
Mein Auto: Clownshoe,Miata,WeeStrom
Your pulley bolts COULD be loose. Are they? Should take all of 10 seconds to check. If they're not, your WP is blown. SUNZOUT is right, don't drive it.
Old 01-03-2011, 04:34 PM
Thanks folks. It's tucked away in the garage. Time to get my Bentley Service Manual out and see what's involved.
Andrew
