'04 X3 2.5 Cooling fan not turning on - Bimmerfest - BMW Forums
Old 01-03-2011, 07:20 PM
Mike E Mike E is offline
Mein Auto: X3
2004 X3 2.5 110,000 miles. Noticed today that the radiator electric cooling fan is not turning on. Is this a typical problem for this vehicle? is there a quick-check to perform that would indicate what the problem could be? Thanks!
Old 01-03-2011, 07:37 PM
timfitz63's Avatar
timfitz63 timfitz63 is offline
MT = Doppler Shifting
Mein Auto: 2007 X3 (MT)
Electric radiator fans are often thermostatically controlled; if there's enough cool/cold airflow passing through the radiator to keep the coolant at the proper temperature (especially this time of year, when outside daytime temperatures hang around the freezing mark in these parts), the fan may not turn on very frequently...
As long as your coolant temperature is staying in the operating range (as indicated by the instrument cluster gauge), you're probably fine.
X3 w/6-speed & Sport Package:
A sports sedan disguised as an SUV...
Old 01-04-2011, 07:28 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
+1, but the sensors that turn these fans on do fail so keep your eye on it as the weather gets warmer.
Old 01-04-2011, 07:56 AM
Mein Auto: 2004 X3 2.5i
If you normally park the X3 in a garage, I'd say the fan should come on if you just leave it idling for a few seconds before shutting it down.
Even in freezing weather.
It does not seem to be common, but there have been a few X3 owners needed fans replaced.
Note that this one did not always show the temp. gauge reading high:
http://www.bimmerfest.com/forums/sho...d.php?t=476124
Best to check this out carefully, and not rely on the temp. gauge to indicate overheating!
Old 12-07-2012, 08:48 AM
allwr allwr is offline
Mein Auto: 2004 x3
I have a 2004 x3 2.5l and coolant keeps spraying out expansion tank/cap when driving. 1)can this short anything with coolant fan operation? 2)will this also cause head gasket to blow?
Old 12-07-2012, 10:41 AM
timfitz63's Avatar
Originally Posted by allwr View Post
I have a 2004 x3 2.5l and coolant keeps spraying out expansion tank/cap when driving...
You need to repair the problem or replace the broken part. Most likely it's the expansion tank itself; it is a well-documented 'weak' spot in the cooling system, and they are known to develop cracks. And yours, if the original tank, is certainly old enough for this to be the likely source.
... 1)can this short anything with coolant fan operation...?
It could potentially short any exposed wiring. That said, the wiring in the engine compartment is generally well-shielded from moisture.
... 2)will this also cause head gasket to blow?
Probably not unless you run out of coolant and the engine overheats and warps... Keep a close eye on your coolant level until you correct the problem; carry a sufficiently-sized bottle of BMW (the dark blue-green) coolant with you in the meanwhile.
I don't think you should mix other coolants (e.g., the old, generic greenish-yellow ethylene glycol-based coolant; or the newer pinkish-orange GM DexCool) with the BMW coolant. Just consult your Owner's Manual and replenish your reservoir with the correct fluid as necessary.
Old 12-07-2012, 05:59 PM
Mein Auto: 2004 x3
I replaced the expansion tank/cap, it still loses coolant. Can you tell me at what temp should the fan come on?
Old 12-07-2012, 08:29 PM
Doesn't really matter what temp. it is meant to come on at - if it is not coming on with A/C or after less than 1 minute of idling in any weather, something is wrong.
If it does come on under those conditions then there is something else wrong in the cooling system. Such as air needs to be bled out. Or top hose needs replacing.
Old 12-10-2012, 05:10 PM
timfitz63's Avatar
I replaced the expansion tank/cap, it still loses coolant...
Well, all that coolant has to go someplace... Are you seeing any puddles underneath the car...? Either it's leaking out, or it's getting consumed by the engine (meaning your head gasket may already be blown... ). Any white smoke from the exhaust pipe? Any mayonnaise-like substance around the oil filler cap? Anything look like it's mixed in with the oil (aside from dirt) when you pull the dipstick?
Old 04-01-2015, 11:44 PM
unique18auto unique18auto is offline
Send a message via ICQ to unique18auto
Mein Auto: bmw x3
bmw x3 radiator fan not working at all
my bmw x3 radiator fan does not turn on at all
Old 10-28-2015, 05:41 AM
croat croat is offline
Mein Auto: 02 M3
Does anyone have proper procedure to test Fan functionality on E83 X3s?
Old 10-28-2015, 06:23 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
good FEST fan info link
http://www.bimmerfest.com/forums/sho...d.php?t=853867
if you can load DIS 57 or similar on a computer with older windows XP or a virtual set up on a newer windows computer you can easily exercise the fan
get the cable etc on eBay .....bmw diagnostics is one source several folks have used......there are several others
http://stores.ebay.co.uk/bmw-diagnostics
Old 10-28-2015, 06:35 AM
Mein Auto: 02 M3
Thanks for those links.
I have BMW Programmer and I see code 279D [10141] Engine Fan: Activation
I also tested power to main cable going to fan and I see close to 14V
So it does look like it's the fan assembly
