The X5 SAV Forum
Old 10-17-2010, 04:57 PM
BigStevie BigStevie is offline
Mein Auto: 2003 X5
2003 X5 Radio keeps shutting of on it's own
I recently purchased a used 2003 X5 3.0. I have encountered several problems. The most annoying one is the radio turning off by itself. It seems to act very erratically. It also appears to be affected sometimes by lifting the arm rest and turning down the interior dimmer. But that is only the case at night.
Also, the BC function occasionally stops working.
Should I look at replacing the radio or is the problem more computer based. I also have an issue with missing pixels on the main display below the speedometer/Tach. Are they related?
Thanks for any help.
Old 11-02-2010, 09:49 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
Oddly, sounds like you might have a battery issue...you'd be surprised. Try getting a replacement battery @ Autozone for around $80, keep the receipt and see if that fixes it. Burnt pixels are typical for BMW OBC and MID clusters, the ribbon cable can be replaced for about $50 on eBay OR the wild change that you can get in touch with BMWNA and ask about their replacement, but sometimes their labor and parts costs can outweigh the saving of just getting the ribbon replaced.
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
Old 11-09-2010, 05:44 AM
swipe swipe is offline
Mein Auto: E30 325i Black Touring
Got the same problem with the radio on my 4.4 getting annoying now did the new battery solve the problem?
Old 11-16-2010, 09:50 AM
bump
Old 11-17-2010, 03:40 AM
m5james's Avatar
Try wigglng the ignition switch and see if anything happens. There have been instances where heavy and bulky keyrings cause the contacts inside the lock tumbler to get screwed up and cause erratic issues as well.
INTERIOR:
Old 11-17-2010, 11:59 AM
Jap Scrap Jap Scrap is offline
Mein Auto: X5
its your bm 54 unit radio module is dodgy
Old 12-03-2010, 11:05 AM
Gronwenwills Gronwenwills is offline
Mein Auto: X5 3.0 diesel
X5 radio problem
Hi Guys
Buying a 2002 X5 3.0ltr diesel, the radio is jammed on the MW wavelength can it be fixed or will I need to replace ?:::
Old 12-15-2010, 08:07 PM
skeetjunkie skeetjunkie is offline
Mein Auto: '85 325e/'06 330i/'04 X5
Check out this thread from Xoutpost:
http://www.xoutpost.com/bmw-sav-foru...dio-issue.html
Old 12-16-2010, 05:25 AM
Thanks for link, unfortunately it's a separate issue. Additional info is that radio will turn off or on but only when the vehicle has been turned off, key removed and vehicle locked ! Then when you re enter the radio can be turned on or off ( depending on the last mode) but only once , you then have to go through previous process, in any case it will only function on MW band ( as I gather that it remembers which mode was last used and you cannot select Cd mode either. Other info is that the time display is blank , the year is set to 2007 and can't accept input. The mileage and avg speed function is working ok
Old 12-16-2010, 02:45 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Try a battery disconnect/reconnect with a few minutes in between.
Old 12-17-2010, 05:04 PM
Hi
Thanks for suggestion, but already tried this method no better
Any other suggestions welcome
Best regards
Alwyn
Old 01-04-2011, 12:20 PM
jolie Court jolie Court is offline
Mein Auto: x5
dont know if anyone can help me, my radio will not turn on, i did have a new battery fitted a couple of weeks ago
