Old 01-04-2011, 10:28 PM
Johnny Montana Johnny Montana is offline
Mein Auto: Lotsa 7 series! E38 Fan!
After engine swap = Turn Key but no crank
1998 Bmw 740 IL
I pulled my ruined 4.4 out and installed a good 4.4 that I had in another car of mine.
Wiring harness = original
computers= original
Battery is new = Voltage is good to fuse box.
No blown fuses
Starter will crank engine when solenoid is crossed....
Am I battling something with the onboard anti-theft device????
Not sure but I know everything is hooked up properly....not my first engine swap.
Any ideas / similar experiences??
Thank you in advance
JH
Old 01-05-2011, 07:05 AM
wilk187's Avatar
wilk187 wilk187 is offline
2001 740il Sport, RIP
Mein Auto: 2006 750i Sport, '14 GTR
if you don't get a reply quick enough, try bimmerforums...theres a few guys over there that have done the 4.4L swap
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes,
LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
Old 01-05-2011, 11:33 AM
I found the problem
I found the problem
The computer components are not fool proof when you connect the wiring harness.....
There are connectors that will easily plug into spots where they are not meant to be.
I had two harnesses connections swapped. Once corrected the car was fine.
The very important item I overlooked was color coding. ya gotta have the blue connections in the blue box.....gotta have the black connections in the black box...
I guess I should have known but I assumed there was only ONE way any of the connections would successfully latch....not so
JH
HTML code is Off
