Excessive Brake Dust 335i - Page 3 - Bimmerfest - BMW Forums
Old 02-06-2012, 09:37 AM
WaxComb WaxComb is offline
Mein Auto: 2011 535i
I really don't see the issue with brake dust. I had an 04 Infiniti G35 and the OEM pads on that put out clouds of black smoke (obviously I got the exception of the Japanese cars don't have brake dust rule.) My 08 E92 335i wasn't as bad as my old Infiniti.
Anyway, I wash my car every other week, and thus the wheels get cleaned so pitting isn't an issue. I'd take dirty wheels over worse braking.
Freude am Fahren
Old 04-05-2013, 07:12 PM
shedridc shedridc is offline
Mein Auto: 328xi Coupe
Anyone know if I get replacement pads at the dealer for my 2008 328xi, will they be the new low dust type or the old high dust pads as are currently on my car?
Old 06-03-2013, 08:58 PM
stoked335d stoked335d is offline
Mein Auto: 2014 S4
I just got my brakes changed on my 2010 335d and I think the dealer used older pads from stock. I have never seen my wheels get so dirty in less than 100 miles like this on the OEM that came on the car. I am going to complaint and have them swap them out for the new ones. Does the brake pads have any shelf life like tires? From what I read here OEM pads were changed by BMW in Sept 2009 so that is almost 4 years ago.
Old 06-04-2013, 12:09 PM
Mein Auto: 2014 S4
Does anyone have the part numbers for the new less-dusty OEM brake pads?
Old 06-04-2013, 12:23 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
There is another current thread that has some part numbers listed, or you can check realoem.com, or penskeparts.com
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 06-04-2013, 12:32 PM
Mein Auto: 2014 S4
I did a search here but it did not show up. Thanks, I'll take a look at realoem. My SA is giving me the sales pitch "Bimmer pads are high performance therefore dusty etc" Need to find the part number for him.
I have driven this car with factory 2010 pads for the past 3 years and there is very minimal dust even not washing it for weeks but now less than 100 miles after the brake job the front wheels look like gunmetal gray color.
Old 10-23-2013, 03:19 PM
OrlandoD OrlandoD is offline
Mein Auto: 2010 335D Sport
Hi Stoked,
I have a 2010 335D Sport with 22k miles on it and recently had my front brakes replaced at the dealership. They did the rotor and pads. I have never had any brake dust issues and the brakes have always been very quiet. Now they groan and I have massive amounts of dust. They tell me this is normal. WTF?! I could not wash the car for a month before and never have as much dust as a couple of days now. It's ridiculous! It's been a few months since your post. What was your fix?
Thanks,
OrlandoD
Old 10-23-2013, 04:10 PM
Banned
Mein Auto: 2007-335 HTC
Originally Posted by clspruiell View Post
Ok so this is normal and just a headache? If so thats fine. Are there any tricks?? I wish there was a wheel cleaning robot to roam around my garage at night. If I had kids i would include this on their list of chores
the trick is to tack weld a lead to the brake caliper from the negative battery post and the positive lead to the brake pad and then the brake dust will be repelled by the charge and wont stick
haha KIDDING
all post are just suggestions from ordinary people driving extra ordinary machines and advise should be taken wisely
Old 10-23-2013, 04:11 PM
Banned
BMW should make the pads silver in color and the dust will just blend in to the wheel paint
I might just have a great Idea there
Old 10-23-2013, 05:24 PM
Mein Auto: 2014 S4
Originally Posted by OrlandoD View Post
Hi Stoked,
Thanks,
OrlandoD
I got the part #s for 335i new formulation pads and went back to dealer. They looked at the #s and came back and said clip for 335d pads are different so 335is new dust free ones won't work on our cars. It sounds like they make a different formula when car is shipped from factory and same pads are not available to us here. There is no fix but it dusts less and less after few months depending on how much you drive.
I went to dealer for some other issue last week and asked them to check my rear brakes. They ended up checking both front and rear and replaced fronts only once again
Just checked the parts #s and they are same as from May 2013. 34-11-6-794-917
(this is the 3rd set of front rotors, 2nd pads replacement 25K miles ) Too early to tell these will dust as I just parked the car 2 days ago after only 10 miles of drive back from dealer(I don't commute w/car)
I will write an update in few weeks if new pads dust or not. It sucks that factory installed dust-free pads are not available as replacements.
Old 11-14-2013, 12:18 PM
arizona-dave arizona-dave is offline
Its a "Dry" Heat
Mein Auto: 2009 528i
Im having similar problems...New Brake Pads and Rotors front and Rear, relentless squeaking, mega-dust.
About braking ability...I drive my sedans rather hard...my 98 Lexus with 268K miles on it is still on ORIGINAL factory Rotors, only had them machines once...no vibration at all. Its on its 3rd set of pads...went to check them recently and still have 50% left. Ive never once had an issue stopping that car on a dime, and shes seem 120mph several times on steep up and down roads between here and Vegas.
Dust on the L-Ride...virtually none.
Id just like a low-dust NO NOISE solution to the BMW...love driving it, but its embarrassing driving up to a nice restaurant valet and having every person look when the squealing starts ever inch the car is moved.
2008 528i Black on Black - Pretty well loaded only 44K miles - BiXenon Adaptive Headlights - What a nice car to Drive, first car to Rival my 1998 Lexus GS300!
Old 10-14-2014, 01:05 PM
BROWNBEAR58 BROWNBEAR58 is offline
Mein Auto: BMW Z4 SDRIVE35IS
Get some metrallic brake pads like they use on race cars. That should stop it
Old 10-14-2014, 01:40 PM
energetik9's Avatar
energetik9 energetik9 is offline
energetik9
Mein Auto: 911 Carrera 4S
You realize the guy before you posted almost a year ago? This thread started in 2011. I bet most of these guys have moved on.
Current - 2009 Carrera 4S
Current - 2010 128i convertible (wife's car)
Previous - 2009 M-sport 335i coupe
Previous - X5 3.0i with prem/sport
Previous - 2000 ///M roadster
Someone should invent a sarcasm font...
"In car rock, paper, scissors 911 beats Prius everytime."
Old 10-14-2014, 03:32 PM
jigray3 jigray3 is offline
Mein Auto: e39, e93
It was so bad in the old days particularly with the basket weave BBS style wheels , BMW owners generally used Kleenwheels dust shields. Nowawdays, many like to show off their calipers, and they won't hide behind 5 spoke wheels as well well.
https://www.kleenwheels.com/
Old 10-14-2014, 04:57 PM
I had my dealer install Akebono Euro pads that I bought for him. After several thousand miles, the dust is almost non existent, certaintly unnoticeable. I have not had any concerns with lack of initial bite and overall stopping power is same as stock pads. I think the stock pads were a little too grabby. I just wish I made this change when I bought the car new in 2007. All the hassles of fighting brake dust is a distant memory. By the way, the ArmorAll Wheel Proctant really works great, I just hose off every month or so.
Old 03-11-2017, 12:10 PM
X5Monster09 X5Monster09 is offline
Mein Auto: 2009 BMW X5
Heavy brake dust X5
Hey guys wanted to share with you. The X5 offers little shielding from the brake dust issue despite the open cooling design of the rims. After several hours of scrubbing and wheel polishing I decided to think out of the box. Where I was having to clean out my wheels once a week I now only have to rinse them off once a month and the amount of build up is very minimal. There's a seller on eBay called brake overstock that sells the 8 ceramic pads and all 4 cross-drilled slotted rotors for, I paid, $215 shipped. It cost me another $200 to have them put on. I did this a couple of months ago and the brake dust issue is resolved. Most cross-drilled slotted rotors only have a 6 month warranty, these guys put a year on them. It probably sounds like I work for them but I don't, it's just a solid, inexpensive solution to a painful problem.
