Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 04-15-2002, 11:08 AM
low low is offline
Wishes he had an XBoX
Mein Auto:
okay im getting confused, about to klasse my car
alright, im hearing all different kinds of stories...so im about to klasse my car...http://www.properautocare.com/klasse.html
using the above, AIO and SG. now im reading over at autopia that once the SG is applied then theres a consequence that you can wont be able to get it off until it wears off?? i mean, wont my next car wash, 'wash' away the AIO and SG..(i will be using zymol's car shampoo, btw.) so i can start step 1 again? someone wanna clear this up for me?
where am i lost? or is all this just for the real detail freaks out there???
Old 04-15-2002, 11:38 AM
eugeneDC/TX eugeneDC/TX is offline
sometimes i wish for an x
Mein Auto: 2001 325i
okay, so i'm taking the klasse plunge too and had similar questions... here's what i found:
if you AIO and SG, yes a regular or even dawn wash wont strip it all the way down. you can apply AIO to remove SG or an alcohol (or alcohol/water) mix to strip. you can also use a paint cleanser (e.g. p21 paint cleanser) to strip. most people at autopia do a super prep job so once they klasse, they really dont strip and start over unless they have too.
here is the thread i asked on autopia about it
Old 04-15-2002, 11:58 AM
low low is offline
Mein Auto:
geez, my prep job is just using soap and water then dry....
Old 04-15-2002, 12:48 PM
most ppl here and most definately everyone there at autopia do more than wash and dry. WAY more. the mod here, ripsnort, has a very good detailing schedule. do an archive search at autopia or ask for ppl to post their detailing procedures. you will be able to compare... the ppl at autopia are fanatical, but their cars look good
Old 04-15-2002, 01:49 PM
Intermezzo Intermezzo is offline
Mein Auto: 330I
Here's a suggestion:
Do this twice a year. Once in the spring and once in the fall.
1. Shampoo
2. Clay
3. Remove swirls (if necessary)
4. Klasse AIO
5. Klasse SG (3 coats of this stuff will look awesome)
6. optional: Top your Klasse with your favorite carnuaba wax. Make sure the wax is a pure wax with no cleaning properties.
Claying and swirl-removal as well as AIO will all remove existing Klasse and wax. Do this twice a year and you'll be stripping your Klasse twice a year.
As Eugene said, some Klasse users do not strip twice a year (hehe). Instead, they layer indefinitely and spot-remove swirls and spot clay as needed to remove any embedded contaminants which come through normal driving.
For indefinite Klasse SG layering, just follow the same procedure as above, except once you are finished with step five you can keep layering a coat of SG or carnauba wax whenever you feel like it (but not interchangeably! Just one or the other).
Polymers like Klasse and Zaino provide a buffer against swirls. Sometimes you can get a swirl in your sealant layer and NOT your clearcoat. This can be easily fixed by adding a coat of Klasse SG. Klasse and other polymers provide a much better 'sacrificial' layer than do traditional waxes.
If you get a scratch on your car that goes through the SG, then spot remove it with an abrasive product and then Klasse right over it again once the imperfection is removed.
Old 05-08-2002, 12:08 PM
scottn2retro's Avatar
scottn2retro scottn2retro is offline
into things retro
Mein Auto: '02 M3 SMG & '08 135i
Okay to use some Meguiars products
Good Post Intermezzo -
I'm looking at doing some stuff with Klasse for the first time so I had a couple of questions:
1) for the clay and swirl removal steps, are there any certain products that have to be used or can Meguair's (or other) clay kit and ScratchX be used?
2) I'll have to check, but Meguiar's Gold Class liquid wax should be okay for the carnuba step?
Old 05-08-2002, 12:43 PM
Mein Auto: 330I
Re: Okay to use some Meguiars products
The best clay I have used is Clay Magic, which is sold at Autozone stores (check the larger stores......the smaller stores don't seem to have CM). The clay magic kit comes with the lube and only costs $10. I also hear good things about Griot's clay w/ speedshine. I haven't tried the meguiar's clay, but I hear it streaks all over your car and leaves a mess.
ScratchX is only to be used for spot-removal of surface imperfections. It's not the type of product that you use to your entire car. The type of polish you should use will also depend on how badly your car is swirled up. For light swirls, I would use 3M SMR or Meguiar's #9 with a PC machine. For heavier swirls, you should use something like 3M Finesse-It 2 Machine Polish. Your best bet would be to do a search under the keyword phrase "swirl and removal" (or several variations of it) at this link: Search
Actually, I wouldn't recommend Gold Class wax because it contains mild cleaners in it. A better choice would be Meguiar's #26. My two favorite non-cleaning waxes are One Grand Blitz and P21S Carnauba.
Old 05-08-2002, 04:55 PM
into things retro
How does the AIO work on swirls
Reading the product description on AIO, it says it removes swirl marks.
Any experience on how well that works?
Old 05-08-2002, 09:54 PM
Mein Auto: 330I
It only removes very light swirls. It's more suited towards removing any micro-swirls caused by stronger polishes.
Old 05-09-2002, 12:01 PM
unleasHell unleasHell is offline
Mein Auto: 2002 330i PP Step, Tinted
Hopefully, I will be applying Klasse for the first time this weekend.
QUESTION: Can anyone reccommend which Quick Detailing spray is good to use once I have Klassed my car?
In one of the on-line nstructions, they say to use a squirt of Eagle-One Wet Wipe & Shipe as you are applying the Klasse so I am guessing that would be "OK" to use afterwards?
Old 05-09-2002, 12:12 PM
into things retro
perhaps Mequiar's
hey unleasHell -
Good luck this weekend. I think I got a message from alee recently (to many messages to remember them exactly) and he didn't have an absolute recommendation, but he thought the Meguiar's Quick Detailer Mist might be okay.
Old 05-09-2002, 12:16 PM
thanks Scott
yeah I have a super-old sample size bottle of Meguirs Quik (Wax) Spray that I have been using at night after I do my Calif. dustering(?).
I'll let ya know how the Klasse goes (on & off).
good luck
Old 05-09-2002, 12:25 PM
Mein Auto: 330I
Yup, E1 Wet works fine with Klasse. If you are going to use a QD to aid in Klasse application, I wouldn't use anything other than E1 Wet or Meguiar's #34 because they do not contain any carnauba(does Griot's Speed Shine contain any carnuaba?).
For general maintenance, you can use any QD you wish....even if it contains carnauba. Washing your car right before applying a coat of KSG will pretty much remove whatever small amount of carnauba (if any) is still left on your car from using a carnauba-based QD earlier in the week.
Old 05-09-2002, 03:58 PM
awd330 awd330 is offline
Just Festering Around
Mein Auto: 330xi
unleasHell -
Just a clarification. Meguiar's Quik Detailer and Quik Wax are two different products. Quik Wax contains carnuba while Quik Detailer does not. I'm not a Klasse user, but I believe that you need to avoid carnuba based products if you plan to layer on additional coats of SG.
Old 05-09-2002, 04:00 PM
Your right!
I have the "Detailer" (I said it wrong)
One plainly states that it contains Carnuba, The Eagle one Wet wip n' shine does not mention carnuba either.
Similar Threads
How to Save Money Doing Euro Delivery Nat Brown Ask-A-BMW-Dealer 142 11-07-2014 08:23 PM
Some F1 History... FSelekler Motorsports, Racing & Track 7 11-22-2007 10:11 PM
Is it time to sell my car? (very long) GalBimmer General BMW Questions 26 11-22-2005 08:01 AM
BMW ConnectedDrive: ChrisTO General BMW Questions 12 11-08-2005 06:41 AM
