Old 01-05-2011, 09:17 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Z3 for $800 w/ Blown engine?
Hey everyone, a buddy of mine ran across a 98 Z3 with a blown engine for 800 bucks. Car has 80K miles, and thats about all I know. I read up that these use S52 engines, so could I just plop a used one in and have a Z3 for 1500 bucks? Thanks!
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 01-05-2011, 09:54 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
More to the story....the car is worth $2K in parts even with a blown engine. but if it's a M with an s52 then it should be pretty easy to put another S52 in.
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 01-06-2011, 07:28 AM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
only the M's use the S52 engine. An M car will have a quad exhaust, M badges and a single chrome bar across the gills on the front panels.
DreamingWell.com Web Services
Old 01-06-2011, 06:51 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
Thanks for the opinions, I'm still trying to contact the original seller (heard through a friend type of thing). Say the car isnt an M, what engine pops in then? And what would it take to fit an S52 into a non-M car. I found a S52 used for a few hundred used, which is why i ask. Thanks again guys
Old 01-06-2011, 07:09 PM
Pants Pants is offline
Road Rager
Mein Auto: '06 Z4 SI
Who cares? For that price with that few miles.
Just buy it and figure out the right motor later.
Old 01-07-2011, 08:00 AM
wildag's Avatar
///M 'n it up!
The S52 engine should "fit" in a non-M, but that doesn't mean all the mount tabs and wiring harness points are available. You'll also need the M's ECU.
The M's had a different suspension setup and rear diff. The transmission was different from most models of the non-M; I believe it was the same as the 2.8 and 3.0i.
Your biggest problem is going to be the rear subframe and exhaust. The M's had a two pipe exhaust, and the non-M's have a spare tire mount in the way. The M's also had a different rear subframe shape and bumper.
Old 01-08-2011, 12:02 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
Okay... Thanks wildag. Unfortunatly it looks like the cars been sold, so I dont think the Z3 for 1500 bucks idea is gonna happen. Although its nice to know that, now I can sound smart about Z3's too. lol
Old 01-08-2011, 06:05 PM
Road Rager
Don't worry yourself too much.
The Z3 uses the same rear suspension as the wagons used on the Oregon Trail.
Old 01-09-2011, 01:22 PM
Dirkjr Dirkjr is offline
Mein Auto: 2001 Z3 2.5i
i would love to make a find like that. Would be great as a parts car. Hey the glove box and rear window alone would make it worth while.
