Old 01-08-2011, 06:23 PM
shrivti shrivti is offline
Mein Auto: X5, 525i
Error Code P0014
I replaced the camshaft position sensor, but still get this error code.
Any ideas on what to look for next? As an aside, I used BMW OEM parts.
Thanks for your help.
Tim
Old 01-08-2011, 08:07 PM
agent15's Avatar
agent15 agent15 is offline
Mein Auto: 87 325is, 02 530i Sport
Did you have the code cleared?
Originally Posted by Fudman View Post
For me, the e39 is the ... best balance of luxury ... performance ... good looks and class. Sort of the Catherine Deneuve of cars, if you get my drift.
Old 01-09-2011, 09:03 AM
Mein Auto: X5, 525i
I did- cleared the code and it came back after about 2 hours...Open to any suggestions.
Thanks again.
Old 01-09-2011, 11:31 AM
agent15's Avatar
It appears there are two CPSs, one for each cam (intake and exhaust). Are you sure you replaced the right one?
Are you certain it was the same code before and after the CPS replacement? According to the Bentley, P0014 is "'B' Camshaft Position Timing Over-Advanced or System Performance (Bank 1)." There is also a code (P0011) for "'A' Camshaft Position Timing Over-Advanced or System Performance (Bank 1), as well as codes for 'A' and 'B' Camshaft Position Timing Over-Retarded." I'd assume the 'A' and 'B' designations mean 'intake' and 'exhaust' respectively, but I don't know for sure.
Old 01-09-2011, 12:50 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Did you replace the senso with the OEM BMW part or purchase one from a parts supply?
Old 01-09-2011, 05:45 PM
Mein Auto: X5, 525i
Agent15 and poolman. thanks to both of you for the replies. I replaced both, and both were BMW OEM. This is a tricky one for sure...unless I got a bad part to start with. Any way to test the part itself?
Old 01-09-2011, 05:54 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
Well, the test will be a lot of rework. Place another OEM & if code distinguishes, the answer is up.
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
Old 01-09-2011, 05:58 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
Examine the plugs the CPS connect to, and flush them out with some electrical contact cleaner. Is the code specific to intake versus exhaust? If so, swap the CPS and see if the problem moves. Otherwise I would suspect either the connector or a bad CPS. As I have learned over the years, "new" does not necessarily mean "good". I have had a bad Bosch oem pre cat O2 sensor right out of the box.
540 M-Sport package (Canadian market), factory Bluetooth phone kit, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, H&R 15mm spacers, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 01-09-2011, 07:51 PM
agent15's Avatar
Wow, head-scratcher for sure unless you can find a wiring/continuity issue somewhere. I'm definitely curious to know what happens, since I have a friend with an M52B28 throwing a CPS code as well.
