Old 01-23-2013, 05:48 PM
waehrik waehrik is offline
Mein Auto: e39 530i/5, e28 535i
Thanks Jason5 for posting the link to the one that people should be buying! Not only is it in stock for one more lucky person right now, but it's a pack of 25 vs the 10 I got for about the same price.
[QUOTE=bluebee;7332919]This is EXCELLENT information for those of us who have not had the need just yet.
Now you tell me!
Oh I'm certainly not arguing that you can't use an RTV solution in place of the factory gasket or o-ring and that it wouldn't work in the beginning. I'm just concerned that anyone who goes that route as a quick and easy fix may encounter problems in the future in the form of a small vacuum leak. If a smoke test is not done as in most DIY jobs most of us would dismiss the DISA as a candidate as it had recently been repaired. Particularly if someone rebuilds the DISA using Gary's kit at German Auto Solutions (highly recommended, no affiliation, blah blah) it should never need to be touched again.
Old 03-08-2013, 06:17 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For reference, this is a pretty picture of the DISA o-ring from this thread:
- Where to get a proper DISA valve repair kit (1)
Old 03-11-2013, 09:34 PM
dznuts007 dznuts007 is offline
Mein Auto: 2001 E46
I used a #139 Viton and oh man, it was a really really tight fit. I thought I wasn't going to be able to get the DISA back onto the engine. Eventually got it back in after adding a little Slick Honey onto the oring.
I'm thinking a #138 might be a little better fit seeing that it's 1/16" smaller. Anyone else have trouble getting the DISA back in with a #139?
EDIT: Scratch that...I just realized this was an E39 thread and not an E46 thread. Got this link from an E46 forum...
Old 03-22-2013, 03:27 PM
jetamt jetamt is offline
Mein Auto: 1997 528i
just a note. I just replace the disa valve an ccv on my 01 525i. A little bit of a pain. I also cleaned the icv. after a lot of research and the recommendation of a longtime bmw owner friend I joined bmw club of america for 48.00. I received a huge discount from my local bmw dealer on parts (roadshow bmw of memphis. The total for the disa,ccv an all hoses including dipstick oring an oil filter was 731.00. after discount was 484.00 including tax.. My disa looked fine but when i checked the vacuum pot it was bad. I had to replace the disa. I suggest to anyone to check with your local dealer to see what kind of discount they give for club membership. I could have bought a little cheaper on line but wasnt sure of quality of aftermarket parts. I figure I spent maybe a hundred or so dollars more but I got genuine bmw parts. the originals lasted 120000 miles. There is a disa valve check on youtube to check vacuum pot. It appears when the ccv goes bad oil is sucked into intake an damages vacuum pot diaphram in the disa or they just dry out from heat overt time. before modifying or trying to repair disa be sure to check vacuum pot. if bad there is no fix to my knowledge. With over 25 years as an aviation mechanic I can tell you its best to do it right the first time. May cost a little more on front end but will save you in the long run run. With fuel cost of today poor gas mileage can run up cost quickly. fyi I am not an employee of bmw dealership nor associated with bmw club of america other than a new member.
Old 04-07-2013, 07:15 AM
04Vrod 04Vrod is offline
Beemer fan
Mein Auto: 2004 X3 3.0i
Back in Feb, I noticed that the gas mileage was down on the X3 3.0i. The performance was also lacking and then, I got a CEL. When I read the codes for the CEL, there were 2 that called out Lean bank 1 and Lean bank 2. I had been reading about the DISA valve and it's failure and ordered a metal replacement kit for the DISA valve. Sure enough, I received the kit, pulled my valve out and was astounded at what I found. The yellow plastic arm was completely worn out and disconnected from the valve butterfly. The stainless pin was still in the bottom (intake side) of teh butterfly holding it from falling into the intake manifold and giving me a very bad day. It took about 1.5 hrs to follow the directions and rebuild the DISA valve, along with checking the vacuum pot for function. I re-installed the valve and took it for a ride. The gas mileage is back to about 20.5 MPG combined, and 24 Hwy. I would recommend that everyone rebuild their DISA valve before the BS BMW plastic stuff causes major failure.
Old 06-09-2013, 09:21 PM
Crutzy Crutzy is offline
Mein Auto: BMW 5-series E39
I don't know if anyone has suggested this yet, but for the DISA, you can get square-cross-section o-rings of almost any material you like.
For example
https://www.mfpseals.com/catalog/cat...trong-nitrile-
Old 11-06-2013, 09:30 AM
bluedevils bluedevils is offline
Mein Auto: 2001 525i Touring
which o-ring material is easier to install?
Thread revival...
Which would be easier to install on a 2001 525i (M54 motor), the Viton or silicone version of the 139 o-ring?
Just now ordered a pack of 100 from Amazon of the 139 silicone version, thinking it may be easier to fit on/in the groove than the Viton version. Was going to order a 10-pack but the incremental cost of the 25-pack and 100-pack was so small, I went with a pack of 100. Figured I can help others in the future who may need an o-ring by shipping one to them for a buck or two.
Old 11-06-2013, 10:08 AM
bluebee's Avatar
I don't know the answer, but I would guess that it wouldn't matter from an ease-of-installation perspective.
Wow. 99 extras!
You could probably do a paypal-style ordering mechanism for those others who wish to stock an o-ring or two. The easier you make it for folks to order them from you, the better.
Old 11-07-2013, 01:17 AM
grimma grimma is offline
Mein Auto: BMW E60 525i
Hello.
I have E60 525i. I have recentlly checked (tested with closing hole while flap in closed position) my disa vacuum membrane and it did not hold vacuum. I bought new disa valve ($tealers) and it was the same as old one. I have E60 525i M54 engine? Should it be same on E39/E60 M54 engines?
Old 11-07-2013, 07:04 AM
dnbigdog dnbigdog is offline
Mein Auto: 5281
When I had to replace the DISA o-ring in my 2003 m54 powered 325ci we found that the oil filter housing o-ring from a mid 1990's Ford Probe works perfectly. It's the same inside and outside diameters, same thickness and even made from the green oil resistant rubber. Cost about $2 at Advance Auto Parts. Ask for the 0-ring that goes between the oil filter housing and the engine block.
Old 11-12-2013, 06:48 PM
My order of 100 silicon size 139 O-rings arrived. Unfortunately, I wasn't yet able to verify that they are the right size for the DISA on my vehicle, but I'm pretty sure I ordered the right ones after learning about the topic on this site.
Anyone who is interested in paying me a buck or two via PayPal in exchange for me mailing you one of the O-rings, send me a private message.
Old 08-10-2014, 09:29 AM
bluebee's Avatar
An pinched DISA o-ring apparently caused this vacuum leak:
> E39 (1997 - 2003) > Cold Idle Issue Solved (Hopefully!)
Originally Posted by kenr88 View Post
I've been chasing a cold idle issue since the winter. I had been over the entire vacuum system along with a myriad of other things with no luck. I finally had a smoke test done a few weeks ago and found that I had a leak at the DISA valve. I had already replaced the o-ring so I was concerned that the body of the valve was some how leaking and I would have to spring for a new one. When I removed it, here's what I found.
Attachment 456787
Attachment 456788
Unfortunately, I had pinched this o-ring somehow upon installation and took a chunk out of it. I never would have found this without the smoke test as I had already replaced it and wasn't going to re-visit such a simple fix. The moral is just be careful when re-installing the unit.
Now I have to wait for the winter for a good test because the average summer temp out here is about 95!
Old 08-13-2014, 11:15 AM
bluebee's Avatar
By way of cross reference, see also:
DISA Valve O-Ring, by Mudbone
Old 12-18-2014, 09:39 AM
bluebee's Avatar
Yet another DISA valve o-ring thread was opened today, over here ...
> E46 (1999 - 2006) > DISA O Ring help
Originally Posted by jmoney6 View Post
I tracked down one of the more severe leaks to the Disa o ring. Disa itself tests fine.
I searched and found a Fel-Pro PN 35489 should be an exact fit.
I removed the old gasket and attempted to install the O ring, but it seems too big and won't all go into the groove. Its almost like 80% of if fits nice and snug but the rest (too much material or it seems stretched) to go flush all the way around.
Any trick to installing the gasket?
Originally Posted by ahull View Post
I'm thinking the fel-pro may only work on the 330, which has a larger DISA. You *might* be able to cut out the extra 20% or so and get it to fit with a little rtv at the cut. Ghetto, but better than rtv on the whole thing.
EDIT: It's the same size for 325 or 330, apparently.
Also, check out germanautosolutions.com. they sell rebuild kits and should have a gasket.
The felpro gasket only works for the 323/328. I just ordered the correct one from GAS.
FYI this http://shop.advanceautoparts.com/p/d...38.1/3490890-P part will work as a temp until you can order the right one. (Note only for a 325/330)
If you want ot add DO NOT USE rtv silicone gasket maker on it. Use a rubber gasket, (it has to expand and contract with heat to get a good seal.
Old 05-23-2015, 01:32 AM
bluebee's Avatar
This related information was asked today ...
> E39 (1997 - 2003) > FYI - DISA VALVE -2003 530i e39, M54
Originally Posted by gary@germanautosolutions View Post
Our kit actually does not the fit the Vaico brand DISA's. I have also seen other forum posts that stated that the molded in silicone rubber seals on the Vaico units start delaminating in a relatively short period of time. We feel from a quality control stand point that it is better to stick with the OEM BMW units.
The GAS Gold Valve is not for everyone. We offer it for the people who either don't want to deal with the rebuild or want the highest quality replacement available and are not too concerned about price.
I want to thank everyone here at bimmerfest again for their support in the launching of this product serveral years ago. It's popularity has exceeded our most optimistic expectations. I could fill a book with the positive feedback we have received on all of our products, but the DISA kit is the what started it all.
Gary
Originally Posted by seemyad View Post
Okay. Can you (or someone) post a pic of a DISA (doesn't matter which) and add an arrow showing where the "molded in silicone rubber seals" look like and are located. This is for my education. Thank you.
Old 03-20-2016, 07:45 AM
PJM361 PJM361 is offline
Mein Auto: 2001 530i
I used Permatex ultra copper RTV about over 3 months ago after replacing the CCV and I was still getting 0171 & 0174 lean codes. (codes were there when I bought the car) After trying several other fixes I finally got a smoke test. Turns out I didn't get one of the CCV hoses on all the way and a cap was missing from the back of the manifold. Also there was a leak at the DISA. I didn't use a lot because I didn't want it to squeeze out into the manifold. When I pull it out yesterday it looked like it was covered all the way around, but most of it was still soft. So I agree with waehrik that an O ring is a better choice because it's putting pressure between the 2 plastic pieces. (DISA & manifold)
