Old 01-18-2011, 07:23 AM
wade_wilson530i wade_wilson530i is offline
Mein Auto: 2007 BMW 530i
Smoke coming from the grill area?
I just recently parked my '07 530i coming into work. As I lock the car and do a walk around I notice smoke coming out in spurts of the grill area (I'm not sure "grill" is the correct term, it's the the area where the trademark, I guess grill is)....anyways, is that suppose to happen. I should note that, I'm in the NJ area where today's weather is really crappy (snow, sleet, and rain)....am I just paranoid or is this "smoke" something that should worry me. I should also note that the drive into work was fine, I didn't notice anything wrong with the car. Thanks guys.
Old 01-18-2011, 07:48 AM
TerraSlug's Avatar
TerraSlug TerraSlug is offline
excluded from the Rapture
Mein Auto: '07 530i
My '07 530i did the same only once. I briefly saw it while stopped at a traffic light, following a several hundred mile trip on an Interstate. The outside temp was in the 50's. I lifted the hood at home, about 10 miles later. There was a very small amount of a white residue, which I'd never noticed before, on the top surface of the coolant expansion tank. After the engine was cold, I checked the coolant level and it was in the normal range. That was about 2,000 miles ago and the car has since been in to the dealer service dept for an unrelated issue, and the SA said the cooling system was normal.
Old 01-18-2011, 07:50 AM
omaralt omaralt is offline
Mein Auto: 2013 550i
I noticed that once in my car as well. A few months later I had valve cover gaskets replaced as I was leaking small amounts of oil. Never saw it again
Old 01-18-2011, 11:35 AM
Timon5435 Timon5435 is offline
Mein Auto: 2004 530i
Unless it actually smelled like smoke it was probably steam. Mine did it coming out of a car wash. I wouldn't worry about. She was probably just letting out a sigh of relief she was in a garage.
2004 530i
2003 X5(wife's)
1991 318is (gone but not forgotten)
Old 01-18-2011, 11:44 AM
fredderf4444 fredderf4444 is offline
Mein Auto: 2006 | 525xi | Silbergrau
hah....Mine just did that on friday, right after I washed my car. I figured it was because of the difference in Temp, didn't see or smell anything leaking.
I will keep watch on it.
F
2006 | 525xi | 6-speed Manual
Silbergrau Metallic | Black Dakota Leather | Anthracite Bamboo | Comfort Access | Cold Weather | Navigation | Xenon | Sun Shades
1993 | Honda Civic Del Sol | 221k+ WoooHooo
1985 | Buick Regal | 120k dead
1984 | Toyota Tercel 4WD Wagon | 221k dead
1976 | Buick LeSabre | 83k dead
1979 | Oldsmobile Wagon | 91k dead
Old 01-18-2011, 01:04 PM
Bart001's Avatar
Bart001 Bart001 is offline
Hofmeister kink ftw!1!!1!
Mein Auto: 2012 X5 35i Premium
You might be able to tell from the smell what it is. Steam coming from a coolant leak has a very characteristic smell. That's a good candidate for what it is.
If you didn't JUST go thru a carwash, there really shouldn't be steam coming from under the hood. And, it won't smell like coolant.
Old 01-20-2011, 10:37 AM
steveo90290 steveo90290 is offline
Mein Auto: '11 X5d & '07 328xi wagon
Check your coolant return line, it is a small hard plastic pipe that has been known to crack on 545s, I don't know if it is a problem from other models,
Old 01-20-2011, 05:05 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
I do notice that on mine as well, had to look twice as it was raining and cold out about 40F. Thought it was the tailpipe of the car in front, but as he sped off I could still see it lightly coming from the front of my car. I also see it after i spray water towards the grille to wash it. May just be the cooling lines of the radiator between the fins reacting to the difference in temperature.
Old 01-20-2011, 06:50 PM
TRS550 TRS550 is offline
Mein Auto: 2007 550i
My 550 does it all the time in cold wet weather. It's simply steam created when the radiator gets wet externally.
Water + hot radiator = steam.
Old 01-20-2011, 06:59 PM
jesimmons jesimmons is offline
Mein Auto: 2008 535i
+1 If water spray from cars in front of you gets sucked into the radiator through the grills, it will give off steam as it evaporates off the radiator once the engine and cooling fans shut off. Next time you see it, just pop the hood and make sure thats what it is.
2008 535i Platinum Bronze | Black Dakota | Light Poplar | Steptronic | Premium | Multi-Contour | Logic7 | Sirius | iPod |
Old 01-20-2011, 07:16 PM
Slaymaster's Avatar
Slaymaster Slaymaster is offline
Mein Auto: 2011 528i Sport Package
Actually I thought you were having a BQ based on your title. I agree with the above posters, more then likely nothing to worry about. Cold spray from weather, car in front of you, and car washs will create steam from your grill......as so would a nice porterhouse!
BMWCCA Member #458528 www.bmwcca.org
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
Old 01-21-2011, 06:42 AM
so, i've been keeping an on eye on the grill and i think everyone is right, it was mostly likely from the rain and melting snow, as the day it did steam there was alot of snow and melting...anyways, all is good and i'm happy again...although this crappy North Eastern NJ weather is starting to suck. anyone for a porterhouse tonight, bring the steak and i'll grill em up
2007 BMW 530i- Sports/Prem. package
Old 01-21-2011, 09:16 AM
Slaymaster's Avatar
Easy now, I may take you up on your offer being you're less then 30 minutes away! Looks like another dose of winter and steaming grills on Tuesday with a much worse storm in the forecast then last night.
Mario Andretti
Old 01-21-2011, 12:18 PM
richietherocket richietherocket is offline
Mein Auto: 2006 530xi wagon
To the OP: do you smell anything coming from the vents like a candle has just been blown out? If so, you need to have the valve gasket replaced on the car. It is leaking oil onto the exhaust system and creates that smell.
I just saw smoke from the grill area and from under the hood on the drivers side and had that smell. Took it in and it was leaking. The dealer replaced the valve gasked and cover since the bolts were also broken. They have been the only ones to do any work on it. Covered under CPO to boot.
2006 530xi Touring - Titanium Silver Metallic with Black Leather interior - Cold Weather Package - Sport Package - Premium Package - Logic 7 audio - Comfort seats - Ventilated cooling seats - PDC - Adaptive Xenon lights - Navigation - Heads Up Display - 35% Tint all around - Full Thule roof rack - Child seat and baby seat
Winter setup - Rubber mats - rear trunk mat - Thule box - 17" wheels
