Old 01-18-2011, 11:08 PM
bmw74me bmw74me is offline
Mein Auto: 750i
Question check engine.. system to lean at idle..help
what up guys i had check engine light came on today so i checked it with inpa and here are the results ..any one knows what could be the problem the car seems to not idle right. while on red light i would say +-75 rpm.
E R R O R M E M O R Y Date: 18.01.2011 22:31:55 ECU: ME9E65_6 JobStatus: OKAY Variant: ME9E65_6
RESULT: 4 error in error memory
278A CDKTUM - Ambient temperature
Error counter: 1 Logistic counter: 40
Mileage 230976 km Engine temperature (tmot) 100.50 degrees C Intake air temperature (tans) 36.00 degrees C Ambient temperature (tumg) 30.00 Grd C Supply voltage (ub) 12.15 V
Implausible signal or value Test conditions fulfilled Error present now and already stored Error would not cause a warning lamp to light up diagnose active
27D5 CDKLLR - failure within the idle-speed control
Error counter: 3 Logistic counter: 39
1. Umweltsatz Mileage 230976 km Engine speed (nmot) 840.00 /min rel. air filling (rl) 12.00 % Supply voltage (ub) 14.04 V Angel DK or DK at stop (wdkba) 1.57 % DK
2. Umweltsatz Mileage 231000 km Engine speed (nmot) 760.00 /min rel. air filling (rl) 12.00 % Supply voltage (ub) 13.94 V Angel DK or DK at stop (wdkba) 1.18 % DK
3. Umweltsatz Mileage 231024 km Engine speed (nmot) 880.00 /min rel. air filling (rl) 12.00 % Supply voltage (ub) 13.94 V Angel DK or DK at stop (wdkba) 1.57 % DK
Signal or value above threshold Test conditions fulfilled Error not occurred yet Error would cause a warning lamp to light up diagnose active
272C CDKRKAT - LR-Adaption add. per time
P2187 System Too Lean at Idle (Bank 1)
Mileage 230992 km Engine speed (nmot) 1680.00 /min rel. air filling (rl) 35.25 % gas level (tfst) 5.00 l Regulator factor bank1 (fr_u) 1.02 -
Signal or value above threshold Test conditions fulfilled Error present now and already stored Error would cause a warning lamp to light up MIL on
272D CDKRKAT2 - LR-Adaption add. per time (Bank2)
P2189 System Too Lean at Idle (Bank 2)
Mileage 230992 km Engine speed (nmot) 1680.00 /min rel. air filling (rl) 39.75 % gas level (tfst) 5.00 l Regulator factor bank2 (fr2_u) 0.98 -
thanks guys
Old 01-19-2011, 08:36 AM
Mein Auto: 750i
Anyone !!!
Old 01-19-2011, 10:50 AM
Baijern motor w Baijern motor w is offline
Mein Auto: E65
Originally Posted by bmw74me View Post
Anyone !!!
It look like you have air leak.
Old 01-19-2011, 12:16 PM
Mr.///Matt's Avatar
Mr.///Matt Mr.///Matt is offline
Wrencher
Mein Auto: 97 ///M3, 89' is, 87 vert
hey guys ive also got an idle problem as well. the car idles at 900 sometimes then suddenly drops and picks back up to 900. its a 2004 745i, the code im getting from GT1 is 27d5 idle speed faulty (p0507), 27b8 differtial pressue sensor (intake manifold), last but not least 2783 Hot Film mass air flow.
i have smoked tested the car and found no leaks.
e30 325is 65k miles...
e30 327i vert.... hehehe weekend whore
E36 ///M3- UUC exhaust, Custom CAI, AA clutch, JB race Flywheel, and a 3.38 lsd diff...
Old 01-19-2011, 12:50 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Maybe try bmw_tech for this one.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 01-19-2011, 04:26 PM
us_sailor79 us_sailor79 is offline
Freedom isnt free!
Mein Auto: 745i
Anyone !!!
+1, air leak.. i've had a similar problem with same indications.
Old 01-19-2011, 05:06 PM
Mein Auto: 750i
Ya thanks guys alredy got it figured out and fixed ..simple bitch
Old 01-20-2011, 01:43 PM
kjruben kjruben is offline
Mein Auto: BMW 760Li V12
BMW74me, how about letting us know what was the problem and what solved the issue?
Old 01-20-2011, 06:24 PM
Mein Auto: 750i
Sure
After the check engine came on, checked it with inpa reset it to see if it will come back, and sure enough after 1 day it cam back , I looked online and they all point at air leak some where , the hint was to look for hissing noise and sure enough it was coming from Part 13
http://realoem.com/bmw/showparts.do?...58&hg=11&fg=15
Took it out and sure enough there was a cut inside the rubber ..changed it and the car was good to go idle is perfect ...hope that helps
Part cost $23
Old 01-20-2011, 08:10 PM
Thanks for the update... I'm sure this will help a couple of us out here...
Old 02-22-2011, 10:07 AM
mrringtone mrringtone is offline
The same thing just happened to me. But mines is from bank 1 and 2. I will check tonight. If that's the issue I owe you a huge favor!!!
Old 03-10-2012, 11:57 AM
bal2ifal bal2ifal is offline
Mein Auto: Black on Black 745i
I had the same exact problem. Checked the parts that bmw74me recommended and sure enough they were bad. Replaced both sides.
BOOM, problem solved! Thanks!
Old 03-10-2013, 11:55 AM
Kalil147 Kalil147 is offline
Account closed at users request
Mein Auto: BMW 545i
Hi
I am having the same exact issue. P0507. Rough idle at times, but then car stabilizes itself and drives fine. I erase the code, one week later check engine comes back on.
I checked the Crankcase valve and cleaned it. I checked it thoroughly, no cracks or cuts. I checked for vacuum leaks and nothing. What else can cause this issue?
Old 03-11-2013, 05:38 PM
SS102310 SS102310 is offline
Mein Auto: 2006 750LI
Is this easy to fix and install? I have same problem. How long did it take u guys?
