Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 01-19-2011, 01:51 PM
Muerto Muerto is offline
Mein Auto: BMW 535i 1986
Unhappy Transmission Program Switch Problem
Hi,
I got a 1986 535i
When i try to start it it will not turn over. But every time i try to start it there is a click noise coming from the program switch that switches between the E S and the 321 switches. When i place the dial to S or 321 and try to start the car, I will still ear the sound, but it will reset the dial to E
If you could help me it would be greatly appreciated.
Old 01-20-2011, 03:26 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
for a no crank condition, i suggest starting with the battery to make sure it's good. ther is nothing worse than spending hours chasing your tail after ghosts when a weak battery was the source.
df
Old 01-20-2011, 05:14 PM
Done that all ready, even changed the terminal cables and suchs
Been checking all over the dashboard to see if there is no shorts, lighter, lights, fuses and what not
still nothing.....
Old 01-21-2011, 01:50 PM
if no power to the starter, then the neutral safety switch and ignition switch would be the next items in line to check.
df
HTML code is Off
