E36 (1991 - 1999)
Old 01-20-2011, 08:59 PM
B1MM3R's Avatar
B1MM3R B1MM3R is online now
Jesse Moon Bayne
Mein Auto: '93 ///S50 powr'd 318is
Exclamation Vibration In Rear
I just replaced my 2.93 diff with a 3.23 lsd and had to change drive shaft flange and two half shaft flanges. Now when I go between 60-70 if I let off the gas there is a vibration in the rear. Also if I push the clutch in between 60-70 there is a vibration but if I give it gas consistenly then no vibration ( only when clutch in and/or let off gas between 60-70 mph it vibrates ) any Ideas? Could I have over tightened the driveshaft flange when swapped out? Could it just be a coincidence and be my exhaust or something vibrating at this certain speed? Thanks alot
Jesse
Part out.
http://bimmerfest.com/forums/showthr...67#post7418867
"Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI
Stock 2004 X5 3.0i (Wifes)
E30 87 325e
Old 01-20-2011, 09:03 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Could be a number of things. Did you follow the rules when you reinstalled the center support bearing and flex disc?
1998 BMW 328is
1966 Pontiac GTO
Old 01-20-2011, 09:07 PM
B1MM3R's Avatar
Jesse Moon Bayne
I torqued the input nut and turned the side flanges and they turned easily......whats the rules? I couldnt find anything specific.......just seems like if I did something wrong the diff would grab or vibrate all the time
Jesse
Part out.
E30 87 325e
Old 01-20-2011, 09:13 PM
Gooby's Avatar
Gooby Gooby is online now
Kebab Lord / Sexy Sax Man
Mein Auto: 1995 M3
When I swapped my differential flange from 4 bolt to 6 bolt we just tightened the fcuk outa that 32mm nut...Maybe yours is just still loose?
Old 01-20-2011, 09:15 PM
B1MM3R's Avatar
Jesse Moon Bayne
but if you tighten it too much then you cant hand turn the axle flanges..they get tight/stuck
Jesse
Part out.
E30 87 325e
Old 01-20-2011, 09:21 PM
Gooby's Avatar
Mein Auto: 1995 M3
I'm talking bout the driveshaft flange...isn't that what you're talking bout?
B1MM3R's Avatar
Jesse Moon Bayne
yea but when i tightened that too much then the sides wouldnt turn
Jesse
Part out.
E30 87 325e
Old 01-20-2011, 09:27 PM
Gooby's Avatar
Mein Auto: 1995 M3
Was the car in gear and/or e-brake on? Shhiiit I didn't even check to see if mine turned...lol just tightened and left...
Old 01-20-2011, 09:32 PM
B1MM3R's Avatar
Jesse Moon Bayne
well I tightened it out of the car and tried to spin sides and didnt spin so i losened it till it would spin like did before swapped out
Jesse
Part out.
E30 87 325e
Old 01-20-2011, 09:42 PM
Gooby's Avatar
Mein Auto: 1995 M3
I dont know then...lol...maybe someone else can help...sorry...
B1MM3R's Avatar
Jesse Moon Bayne
haha...thanks for the help
Jesse
Part out.
E30 87 325e
Old 01-20-2011, 10:24 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
This sounds exactly like when I had a loose wheel, I know it sounds stupid, but check.
On the highway, it would vibrate unless I gave it gas. Only one lug was tight, and one had completely fallen out.
Turbo Build Here
Parting Out Complete 96 328is
Old 01-20-2011, 10:53 PM
B1MM3R's Avatar
Jesse Moon Bayne
thanks...will check
Jesse
Part out.
E30 87 325e
Old 01-20-2011, 11:01 PM
B1MM3R's Avatar
Jesse Moon Bayne
wheels are tight
Jesse
Part out.
E30 87 325e
Old 01-20-2011, 11:12 PM
Needs Boost
Mein Auto: Red Sled
Did you jack up the car and wiggle them?
If they're still tight, jack the rear of the car up safely, have a friend *drive it* through different gears and see if you can see the diff moving, or anything else not normal happening.
Turbo Build Here
Old 01-20-2011, 11:35 PM
B1MM3R's Avatar
Jesse Moon Bayne
yea they are tight.....if i over tightened or undertightened the nut on the driveshaft flange would that cause this? just seems weird that its only between 60-70 mph......and fine when on gas....seems like if it was the diff it would happen all the time.....damn this sucks...
Jesse
Part out.
E30 87 325e
Old 01-21-2011, 05:21 AM
JoshuaG's Avatar
JoshuaG JoshuaG is offline
Natasha 95M3
Mein Auto: 95' E36 M3
When was the last time ur Dif and subframe mounts were changed? I have a similar problem and my bushings and mounts are shot. Rtabs. Too check it all if it's not all new?
Originally Posted by kaos_325i View Post
Maybe I haven't been here long enough to realize the knowledge you have to share. But, from all I can tell you are just an over opinionated, rude, prick.
My .02
Old 01-21-2011, 06:47 AM
B1MM3R's Avatar
Jesse Moon Bayne
Just got the diff...only have 95k on it...they looked good when out of car
Jesse
Part out.
E30 87 325e
Old 01-21-2011, 12:48 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Lifted Jeep,240z
did you pull your drive shaft apart at the CSB?
if so did you re-install it exactly how it came apart? (they are balanced together)
definitely sounds like a drive shaft issue to me not a diff problem..
the problem you described sounds exactly like what happens when a U-joint starts to go on a truck, , vibrations a certain speeds and when no throttle is applied
(i own a lifted jeep, ask me how i know about driveshaft problems )
(1986 BMW325es -MSD ignition coil/ebach springs/bilstein sport shocks/Ireland Engineering sway bars/K&N air filter/"high flow" cat/dodge shadow radiator/ANSA resonator/3.46 LSD/CERAMIC brakes/Dinan chip/Shaved Head/Ported Intake manifold) = sex on wheels
Old 01-21-2011, 01:00 PM
B1MM3R's Avatar
Jesse Moon Bayne
Yea a guy at my work said it sounds like a u joint too...just weird that I only noticed it after swapping diffs...did not take out driveshaft for swap
Jesse
Part out.
E30 87 325e
Old 01-21-2011, 01:05 PM
East Bound And Down
have you replaced you guibo?
Old 01-21-2011, 01:10 PM
B1MM3R's Avatar
Jesse Moon Bayne
Nope...all I did was swap the Input flange and output flanges on the diff's nothing with the drive shaft
Jesse
Part out.
E30 87 325e
Old 01-21-2011, 03:04 PM
East Bound And Down
inspect it and see if its cracked and retarded looking
Old 01-21-2011, 03:06 PM
B1MM3R's Avatar
Jesse Moon Bayne
Yea im going to tomorrow...just jack up the car and secure it...look around and possibly run in at 60 and see if I see a problem there...ill be back in touch tomorrow...once again I truly appreciate everyones help and input
Jesse
Part out.
E30 87 325e
Old 01-24-2011, 11:57 AM
B1MM3R's Avatar
Jesse Moon Bayne
ok so I still havnt had a chance to check car but ive been google'ing replacing the u joint and some people say that you can't replace it...is this true?
Jesse
Part out.
E30 87 325e
differential, exhaust, lsd, rear, swap
