Vibration In Rear - Page 2 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 01-24-2011, 12:46 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yep. It's an integrated unit, so you need to replace the entire drive shaft. Stupid design...
1998 BMW 328is
1966 Pontiac GTO
Old 01-24-2011, 12:48 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Wow so if thats the culprit im screwed then...does it sound like it could be that to you?
Vibration on accel and decell and when clutch in between 55-70?
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
Old 01-24-2011, 12:53 PM
ZeGerman's Avatar
Warm Leatherette
Sure, it's definitely possible, but there are a number of other things down there which can cause the same symptoms. You really need to have somebody who knows what to look for get under the car and do an inspection.
1998 BMW 328is
1966 Pontiac GTO
Old 01-24-2011, 01:05 PM
B1MM3R's Avatar
Jesse Moon Bayne
Yea...me and my dad are going to check this weekend....im thinking it might be uneven torque on the bolts that attach to the diff and driveshaft because never had problem before diff swap...no noises or poor running from diff so pretty sure its not the diff...my dad is a mechanic but just been too damn cold here to look....
Jesse
2007 328i DD
Old 02-01-2011, 08:58 AM
B1MM3R's Avatar
Jesse Moon Bayne
So my dad and I checked every thing under the car and everything looked good under car...diff..bushings..mounts...driveshaft..axels.. ..so we took it to my dads friend who works on 4x4s..performance cars diffs and driveshafts looked at it and drove it....he said it sounds more like a roar from my tires and everything looks good...said some treads will do that...its prolly been doing this the whole time and i was just being very observant and paranoid after swapping diffs....because there is no noise from rearend whine or anything and zero play in driveshaft
Jesse
2007 328i DD
Old 02-01-2011, 05:43 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
I thought it was a vibration, not a noise?
Turbo Build Here
Old 02-01-2011, 05:45 PM
Killjoy's Avatar
Killjoy Killjoy is offline
OEM Hoe....
Send a message via AIM to Killjoy
Mein Auto: 1999 M3, 2002 tii
Seconded.
Originally Posted by Cmy_bimmer View Post
Oh your talking about THAT hole.. yeah thats an inspection hole
Old 02-01-2011, 05:48 PM
B1MM3R's Avatar
Jesse Moon Bayne
Well that's what I thought at first but then I parked it and now that I drove it again its more like a roar
Sent from my SCH-R880 using Bimmer App
Jesse
2007 328i DD
Old 02-01-2011, 06:56 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
^ put different wheels on the back and see if it fixes it
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 02-01-2011, 07:04 PM
B1MM3R's Avatar
Jesse Moon Bayne
Yea good idea...will do this weekend
Jesse
2007 328i DD
Old 03-07-2011, 11:12 AM
B1MM3R's Avatar
Jesse Moon Bayne
So finally after a month of setting I got around to removing the diff from the car....the nut was slightly loose so i tightened it up and drove her....no more noise/vibration! super happy that the diff is ok!bc I was soooo afraid that I wasted $400 bucks on it!
Jesse
2007 328i DD
differential, exhaust, lsd, rear, swap
