E36 (1991 - 1999)
Old 01-21-2011, 08:04 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
E36 M3 Aluminum Underpanel DIY
Ok, so as promised, I have made my own aluminum underpanel and DIY. I started off the project at the local metal fab shop to purchase my raw aluminum. I got a 2'x4' piece of .100 aluminum sheet. When I got home, I found a piece of cardboard to make a template.
(Free add for Pelican 'cause they rock!) I then took the template under the front bumper to sketch and cut my template for one side. Then I transfered one side to the sheet of aluminum, and marked my adjustment (see cardboard template).
Next I crawled under the front to check the dimension from end to end of the underpanel. Then, I transfered the dimension to the sheet of aluminum and created a control line:
Mine measured at 45 inches. After I created my control line, I flipped the template over to the other side and copied the design.
I used my grinder to cut the straight lines:
Then I used the jig-saw to cut the round parts:
And finally I touched it up with the sanding wheel on my grinder:
Now would be the time to paint if you so wish. I went to home depot and bought some hardware to attach it with, then simply held it up and drilled the holes through 6 points and attached the underpanel. I used nylon nuts to ensure vibration wouldn't cause my creation to fall off at 70 mph
Here is the finished product:
Overall, it seems plenty strong enough, and now I don't have to worry about my brake ducts falling out I didn't weigh the piece of aluminum, but it was about equal to the weight of the underhood insulation that I removed The piece of aluminum was about $40, and I spent about $5 on hardware, so this project offers a big savings over the underpanels out there on the market.
Feel free to ask any questions or critique my project.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 01-21-2011, 09:48 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Nice job.
Turbo Build Here
Old 01-21-2011, 11:38 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Nice work. No reason to buy one of the pre-made ones for something that's going to spend its entire life underneath the car getting hit by rocks, sticks, and other debris.
1998 BMW 328is
1966 Pontiac GTO
Old 01-22-2011, 12:46 AM
Hellawut??
Mein Auto: who knows?
When i get my next car. and if its worth it.
Ill do this. :P
-Franklyn
Old 01-22-2011, 05:52 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
what, no carbon fiber film??
nice job!
df
Old 01-22-2011, 08:04 AM
crisscross's Avatar
no carbon fiber.....I like the business over looks
Thanks everryone
-Alan
-2000 F250 V10
Old 01-22-2011, 08:05 AM
EROC_328 EROC_328 is offline
Mein Auto: '96 328is
Nice, I have been wanting to do this for my non-m bumper.
Do you know what alloy the aluminum you used is?
Any reason you drilled new holes rather than using the factory mounting holes?
Sport pkg./ADR version II wheels/H&R sport springs/Bilstein shocks/K&N CAI/OEM M3 exhaust/Shortshift
Old 01-22-2011, 08:09 AM
crisscross's Avatar
I'm not sure what alloy the aluminum is, I just got it out of the drop pile at the fab shop. I drilled the holes so that I could pick my mounting points and use larger than stock hardware. I put washers on both sides and used locking nylon nuts so they would hold better.
-Alan
-2000 F250 V10
Old 01-22-2011, 08:16 AM
Ok, thanks. I just looked for a piece of al. on mcmaster and it costs over $200 to get a 2x4 piece from them, so that is a really good deal on the al. you got.
http://www.mcmaster.com/#aluminum/=ap9czm
And yes, mcmaster usually overcharges compared to local places because their prices include next day shipping.
Old 01-22-2011, 08:17 AM
crisscross's Avatar
Wow! I was thinking 40 bucks was a little much, but I guess I got a deal
-Alan
-2000 F250 V10
Old 01-22-2011, 09:45 AM
ZeGerman's Avatar
Warm Leatherette
You should be able to get aluminum for around what Alan paid. Just gotta find the right source, which shouldn't be too hard.
1998 BMW 328is
1966 Pontiac GTO
Old 01-22-2011, 10:00 AM
hornhospital's Avatar
D'oh, You Kids!
Sheet metal/machine/fabrication shop will have it. Most likely 6061-T6 grade.
Nice work, CC! I'd paint or clear coat it, though, just to keep it from corroding.
Quotes to live by:
Old 01-22-2011, 01:29 PM
Hellawut??
ill just use cardboard when i do mine.
-Franklyn
Old 01-22-2011, 01:49 PM
EuroDriven EuroDriven is offline
Account closed at users request
Mein Auto: White 1995 325i
6061 would be over kill for this. You can just grab the cheapest alloy you find, in terms of a skid plate, I cannot imagine alloy would affect it by any significant amount, in terms of life or durability. I pick up a plate of aluminum about that size for about 30$ a few years ago. I just went in and said I need your cheapest aluminum plate. They would love to make money off their scrap since they are just gonna well...scrap it. Call a few metal suppliers in your area.
Old 01-22-2011, 06:42 PM
JoshuaG's Avatar
JoshuaG JoshuaG is offline
Natasha 95M3
Mein Auto: 95' E36 M3
im gonna do it with MDF.....
Old 01-22-2011, 06:49 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
My cousin has a fatass road sign in his garage that I want so I can do this...lol
Instagram | @randytheus
Old 01-22-2011, 06:53 PM
Hmm...I have a "Do not enter" road sign....
Old 01-22-2011, 06:55 PM
JoshuaG's Avatar
Natasha 95M3
a big stop sign would be money
Old 01-22-2011, 07:03 PM
Yeah, some guy on the audi forum I am on has one, its nice because you don't have to trim the corners. I want to put it facing up so you can see it from under the hood.
Old 01-22-2011, 07:22 PM
D'oh, You Kids!
I didn't say you needed 6061. I said that's what you're likely to get if you buy from a machine shop, since it's the most commonly used grade. I machined and welded that stuff for 27 years.
Quotes to live by:
Old 01-22-2011, 07:24 PM
Sorry, thought you mean you will most likely need 6061. No worries, I have been welding and knowing how to use a maching shop for 5 years now...
Old 01-22-2011, 07:25 PM
crisscross's Avatar
Drive up here and I'll help you make and install one
-Alan
-2000 F250 V10
Old 01-22-2011, 07:27 PM
Gooby's Avatar
Mein Auto: 1995 M3
Old 01-22-2011, 07:39 PM
crisscross's Avatar
No seriously
-Alan
-2000 F250 V10
Old 01-22-2011, 09:35 PM
Los's Avatar
Los Los is offline
Too soon Junior
Mein Auto: Elise<3
Nice. I should do this with that speed limit sign that I "found."
It's only a 20 anyway.
@hanloso. '98 328i/'09 Tahoe LTZ
