The X5 SAV Forum
Old 01-23-2011, 06:32 PM
cburr22 cburr22 is offline
Mein Auto: 2002 BMW X5
Blower not working
I've got a 2002 X5 and the blower isn't working. I did some reading on other threads and found that it was probably the final stage resistor - I replaced the resistor but the problem was not solved. Any other suggestions?
Old 01-24-2011, 07:50 AM
AkaBear AkaBear is offline
Mein Auto: BMW X5
Did you check all breakers?
Hope you blower motor isn't burned, changing the motor is very complicated procedure.
Old 01-24-2011, 10:21 AM
Yes, I've checked all the breakers/fuses and they seem fine. Is there anything else it could be or does this mean the motor is probably burned?
Old 01-24-2011, 10:50 AM
Mein Auto: BMW X5
As I remember a huge 50A breaker in a glovebox is protecting a blower circuit
Some possible problems: a bad contact is somethere, AC control is broken.
I would recommend to ask a dealership or indy to make a diagnostic and check the circuit, you may save some money later and replace a broken part himself.
The problem is that in order to get access to blower motor you will need remove central concole (a lot of work!)
Old 01-24-2011, 11:27 AM
Alright, I think I'll take it in and have them diagnose the problem for me. Thanks for your help.
blower, climate control, fan, heater
