Old 01-26-2011, 01:42 PM
sparky1524 sparky1524 is offline
Mein Auto: 2008 528xi
Minimum offset for 08 528xi?
I know the M5 wheels (style 166) with a 20 offset won't fit my 08 528xi and that my current wheels (style 138) have a 43 offset.
Does anyone know for sure what the minimum offset required is for an E60 xi without the use of spacers?
Also, PM me if you've used any stock BMW wheels on your E60 xi, I'm trying to get ideas (18s and up only please).
Old 01-26-2011, 02:03 PM
cderr14 cderr14 is offline
Mein Auto: 2007 530xi
I run 35 fronts and 33 rears. 245/35/19 front 275/30/19 rear.
Old 01-26-2011, 02:22 PM
estrov estrov is offline
Mein Auto: '08 535i + '03 Z4 3.0i
talking about offsets without wheel width is pointless.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old 01-26-2011, 04:45 PM
I know what you mean, not necessarily. I know that regardless of the width a 20 offset won't fit. And it's rare to find a quality wheel that's 19" and only 7" wide. So 19x9 with 32 offset may not fit, true, but 19x8 may...
Old 01-27-2011, 09:42 AM
punch in the combinations into the above website and you can get the clearances on each side of the wheel.
Punch in the ones that will not work and then the OEM info and you can get a range of what will work.
