Old 01-20-2011, 04:34 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
Still Tramlining
If you've been following my threads, you know what I've been up to. Last spring, I replaced my front control arms and CABs. Then recently I replaced rear springs and trailing arm bushings. I have Sumitomo htr z3's with about 5k miles on them. I even replaced the steering guibo twice. The rear control arms were replaced 25k miles ago just before I bought the car.
I had the alignment checked yesterday, and now everything suspension and steering related is in great shape and properly adjusted.
But it's still tramlining. Do our cars "just do that"? Is it maybe my tires? The guy who did the alignment noticed it. We talked about it and all we could come up with was maybe, the tires are a little to square edged.
It's an 03 325i touring with ZSP suspension. Just over 70k miles.
Any thoughts?
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 01-20-2011, 06:46 AM
banneddevice banneddevice is offline
Mein Auto: '01 330ci
I had a similar problem with a set of Kumho MX HP Summer tires and they started tramlining very badly when the temperature started to cool down. I switched off to a set of Pilot AS and it stopped tramlining and road perfectly. I know its not the same set of tires but they are both HP-S tires and react in a similar fashion to temperature changes.
Old 01-20-2011, 07:20 AM
Cogito Ergo Zoom
Mein Auto: 325iT
Hmmmm... the literature on these tires does say they shouldn't be used under 40 degrees. Is this maybe the result?
Old 01-20-2011, 07:44 AM
Could be due to the rubber stiffening, I know snow tires are extremely soft compound even in cold temps while my HP-S tires were extremely hard in cold temps. They also started making a lot of noise at low speeds when the temperatures dropped. All of this went away when I changed over to my A/S tires.
The HP-S tires didn't make noise and they didn't tramline much except at low speeds when I drove on really poor road surfaces in warm temperatures. Both of these became much worse with cooler temperatures, the tramlining even began to happen at highway speeds which drove me nuts. Hope this helps. Might be worth it to get a set of cheap A/S tires to put on the front.
Old 01-20-2011, 08:18 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Any thoughts?
Johnathan,
I just took my vert out yesterday to run it before the cold sets in this weekend, and I too noticed the tramlining. From the moment I got my car it has done it, and I have round shouldered Continentals. It's just normal for these cars. I'm sure the square edge of your tires are making it a bit worse. The tires being stiff will also contribute to it. Be careful driving with summer tires when it's very cold. I have noticed that my handling feels greasy when it is cold out, and I have to be careful not to push it.
Old 01-20-2011, 08:39 AM
Cogito Ergo Zoom
Mein Auto: 325iT
Originally Posted by SJBimmer View Post
Johnathan,
Yeah, I think the car has always done it. I think I'm maybe noticing it more because everything is tight now, maybe the loose steering and broken spring helped to mask the effect . I do take it easy on my tires in cold weather. My car is not a commuter, I don't drive to work, so I made the decision to get tires that would be more fun when the weather was good. I have noticed that on very wet roads, and particularly on snow, they change from tires to flotation devices pretty quickly.
Next time I need tires, I'll try something a bit different. The Sumitomo's give great grip but maybe something else won't get bounced around as much. But at the rate I put on miles, these will be on for at least two more years. Guess I'll just get used to it.
Old 01-20-2011, 09:22 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Well, your brand of tire isn't good IMO. Where's JVR826? He is an expert on this stuff.
Old 01-27-2011, 08:17 AM
Cogito Ergo Zoom
Mein Auto: 325iT
Does anyone think a strut tower brace would help eliminate tramlining. I've done everything else that needs to be done to the front, and nothing is loose or worn anywhere. I don't think I'll need new struts for the next couple years so this would be the last piece.
Anyone????
Old 01-27-2011, 08:59 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
If you get a strut tower brace, get it for the added protection against strut tower mushrooming; I wouldn't expect it to have any impact upon tramlining if it's added to a suspension that is in good condition.
Old 01-27-2011, 09:18 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
No.
Some tires just tramline. I don't notice it much at all with my current RE760 Sports.
Old 01-27-2011, 09:52 AM
tomjrau tomjrau is offline
Mein Auto: 03 ZHP,02 540i,06 530xiT
My tramlining significantly improved when switching from Dunlop SP Sport Maxx to the Hankook ventus v12 evo k110 (couldn't they come up with a shorter name?).. noise significantly improved too.
Old 01-28-2011, 05:53 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Any thoughts?
Just a thought, maybe boost your tire pressure up to 40-42psi to see if it makes a difference. And / or swap wheels from front to back to see if that makes a difference.
Or, even better, if you have any friends in the area with an e46, ask to swap wheels for a test drive. At least you might be able to pinpoint if its a tire problem versus a strut/mechanical problem.
Old 01-29-2011, 11:54 AM
HutchMHK's Avatar
HutchMHK HutchMHK is offline
Mein Auto: 2002 330Ci
My 330Ci tramlines quite a bit with Dunlop Direzzas, especially on I95 where the right lane is rutted from semis. Disappears completely when I put my snow tires on.
2002 330Ci 5MT / Sport Pkg / Orient Blue / Tan leather / Prem Sound
AFE CAI / UUC TSE by Corsa / Short Shifter / Mystery Chip
2002 540i 6MT / Sport Pkg / Convenience Pkg / Black / Black Leather
Dinan 5 Package ( CAI / Throttle body / Intake manifold / Chip / Catback /
Front Strut Bar / Rear Strut Bar / Springs / Koni Adjustables )
2003 330xi 5MT / Convenience Pkg / Silver / Black leather
Old 01-29-2011, 08:56 PM
marinekilz's Avatar
marinekilz marinekilz is offline
Noone Special
Mein Auto: 01 E46 330 xi
My first thought was if they chekced with the correct specs for your veh. ie tire size, touring, and sport suspension or just did a generic e46 alignment
01 E46 330Xi
06 E92 328i ZSP
07 E92 335i ZSP
E9 One Day It Will Be Mine
Old 01-30-2011, 06:17 AM
mawana's Avatar
mawana mawana is offline
Mein Auto: Yaris (6sp) CC
Yes, check your alignment specs - you should be running zero (0) toe on each front wheel or at least very close to 0.
Tires are usually the main culprit but in this case, I don't see the thread pattern of the sumi's contributing to tramlining. Unless, if they were wearing out unevenly.
"Common sense is the collection of prejudices acquired by age 18." ~ Albert Einstein
BMWCCA 405578
Garage
1. 2015 k46 S1KRR
2. 2008 e90 M3
past: 2003 e46 ZHP
Old 01-30-2011, 07:07 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
It's the tires. Also larger wheel size seems to promote it as well in my experience
mujjuman
Old 01-30-2011, 08:07 AM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
My tramlining went away after I switched to a square setup of kumho tires all around.
Btw, did you notice any change with the steering guibo?
